03-27-2012, 03:41 PM | #1 |
Member#: 301679
NWIC
What do you guys think? headgasket?
97 imp L 2.2
Oil level stays high unless it gets low on coolant. As soon as it gets low its down 2 quarts of oil. Happens about every 3k mikes. Motor has 226000 on it. T |
03-27-2012, 04:19 PM | #2 |
Member#: 294461
NWIC
Vehicle:2006 San Remo Wagon Under construction |
That's weird. How often does the coolant get low?
03-27-2012, 04:30 PM | #3 |
Member#: 311373
Vehicle:2009 impreza 2.5i dark grey metallic |
if u check ur dipstick does it have kinda look like it has chocolate milkshake on it? do u have white smoke coming out of the exhaust?
03-27-2012, 05:12 PM | #4 |
Member#: 301679
NWIC
Happens about every 3k, oil looks like its not contaminated, no white smoke.
T |
03-27-2012, 05:12 PM | #5 |
Member#: 301679
NWIC
T |
03-27-2012, 05:47 PM | #6 |
Member#: 300551
SCIC
Vehicle:2002 FOZ STI 2.34 Fullers Garage |
Use some subaru coolant additive.
03-28-2012, 10:45 AM | #7 |
Member#: 141373
E. Canada
Vehicle:2022 Crosstrek Sport 6MT |
Can you spot an oil leak? First and foremost though, why do you get low on coolant?
03-28-2012, 07:43 PM | #8 |
Member#: 301679
NWIC
03-28-2012, 11:55 PM | #9 |
Member#: 300551
SCIC
No idea on the coolant except that maybe I get low from it keeping my oil level high
T[/quote] ? Last edited by mod maniac; 03-29-2012 at 12:34 AM. |
03-28-2012, 11:59 PM | #10 |
Member#: 226864
The question here that needs to be asked is how often do you get low on coolant? Leaks? Recent radiator, heater core, water pump, or coolant leak work done to the car? This would just be air purging out of the system and no big deal.
Look on the bottom of the oil fill cap. Does it have a white milky paste on it? Oil look black or fresh? Or does it look white ish with signs of coolant contamination. No smoke? No oil problems? Recent work done on any of the things I listed above? If no no and yes, then you don't have a problem. Put some coolant in it and be on your way -Dave |
03-29-2012, 12:01 AM | #11 | |
Member#: 226864
? Wut? The coolant system is totally separate from the oil system. The only way the would mix is from a failure of some kind, usually headgasket failure. In this case there would be coolant in oil or visa versa. If you dont see this then your oil level has nothing to do with your coolant level. |
03-29-2012, 03:33 AM | #12 |
Member#: 311823
What? Your coolant does not get low because your oil is high. You either have not put enough coolant in your car or it may have looked like you did because of air in the system or you have coolant leaking from somewhere probably a hose or the radiator. It could possibly be leaking at the head gasket but if you do not have white smoke, etc then that probably rules that out. As for your car burning up a lot of oil if there is no oil in your coolant then your head gasket is probably fine and your car is just running like *****
Similar Threads | ||||
What do you guys think of a SPT intake? What do you have? | chomponthis231 | Newbies & FAQs | 28 | 07-07-2009 09:01 AM |
Thinking of going wingless, what do you guys think?? | Calitri-Boost | Member's Car Gallery | 66 | 09-30-2006 02:42 PM |
What do you guys think I should do?? | evokiller04 | Proven Power Bragging | 13 | 06-13-2006 07:28 PM |
Thinking about bidding on this eBay car, what do you guys think? | Cjchaps | Mid West Subaru Owners Club Forum -- MWSOC | 18 | 01-04-2002 01:42 AM |
