03-28-2012, 07:16 PM | #1 |
Member#: 289159
E. Canada
Vehicle:2007 Impreza 2.5i SE CGM |
Sway bar troubleshooting
Just installed a 22mm white line adjustable rear sway bar and on my first drive I hear clunking whenever I roll over bumps. I used kart boy end links too. Had to reuse the bottom bolt from the old end link and the top one I got at a hardware store that had similar play to the original bolt in the end link. So I figured it would be ok.
I also did the subframe outrigger bushings too. Not sure if that's causing any of it. Any chance the end links have different hardware required? Safe to drive?
03-28-2012, 09:15 PM | #2 |
Member#: 197937
E. Canada
Vehicle:2016 Golf R Under the radar silver |
Should be ok to drive.
Recheck all the nuts & bolts now the car has been driven a bit, and do it with the weight of the car on the suspension i.e not jacked up. I had a similar issue with a front sway bar, it was a loose endlink nut. And you should post in the suspension forum, this is N/A Powertrain.... |
03-29-2012, 01:57 AM | #3 |
Member#: 289159
E. Canada
oh man sorry... didnt realize it only covered powertrain...
i realized the bolt i used didnt have a washer or a large enough head so the endlink bushing slipped right over the end.. one little washer and shes good to go... AMAZING upgrade to anyone thinking about it! |
03-29-2012, 09:13 AM | #4 |
Member#: 217257
Vehicle:2008 2.5i hatch Satin White Wrap |
good to hear, I've got a whiteline 22mm rear sway on the way!
Similar Threads | ||||
FS : (NY) JDM STI Rear sway bar (SOLD) | zeedeveel55 | Suspension/Brakes/Handling | 5 | 04-04-2012 01:24 PM |
A sway bar is a sway bar is a sway bar?? | eightballrj | Brakes, Steering & Suspension | 7 | 07-06-2004 07:58 AM |
please post picture of FHI 18mm sway bar next to stock Forester sway bar | FormerSubTech | Forester Forum | 6 | 11-15-2001 05:56 PM |
please post picture of FHI 18mm sway bar next to stock Forester sway bar | FormerSubTech | Brakes, Steering & Suspension | 0 | 11-10-2001 07:52 PM |
Should I buy the sway bar mounts with my new sway bar and links? | Derres Catalano | Brakes, Steering & Suspension | 1 | 03-22-2001 06:59 AM |
