10-04-2010, 06:54 PM | #1 |
Member#: 259877
Vehicle:2005 WRX STI Aspen White |
STI GT35 motor rebuild question. (AMS KIT and more)
Hello all. After my search for the perfect STI i found my 05 STI. I purchased it with a long list of mods and needed some experienced guidance.
the main mods to worry about are my Garrett GT35 Turbo, Turbo XS rotated mount kit, Turbo XS FMIC, Turbo XS down and mid pipe, DC sports cat back, Koyo Radiator, Zero Sports Thermostat, TiTek 850 cc injectors, Walbro fuel pump, Perrin fuel rails and lines, Perrin light weight crank shaft pulley, JDM TGV deletes, Custom oil cooler, braided lines, sandwich plate, Cusco catch can, Sun Auto Hyper voltage system GT & Hyper ground wire kit, Cusco and Stant coolantcaps, Whiteline anti-lift kit. there is more suspension work done but not really relevant. to the point. i'm looking at rebuilding the bottom end to hold a solid 500 HP. i found the AMS rebuild kit AMS EJ25 Advanced Engine Rebuild Kit - Automotosports, Inc. Includes JE Pistons + Upgraded JE Wrist Pins Clevite Main and Rod Bearings OEM Subaru Engine Gasket Kit Manley H-Beam Rods ARP 11mm EJ Head Studs it states that the kit will support 600WHP "Developed for power levels from stock to 600whp and a 8500rpm" (not looking to rev that high) My question is this. What do i need to do to the head or other components to support this type of power?(keep in mind i'm looking at making 450-500 whp DD) and any other mods that are needed for this motor to handle this. springs, oil/water pump ext. thanks for your help even if you can point me to a forum with the info. thank you much
10-05-2010, 03:21 PM | #2 |
Member#: 251606
Vehicle:2003 Wrx Wr blue |
Stronger head studs for sure an cams since your build is pretty deep already, I'd go for cosworth 280s. Port an polished heads with titanium valves and springs for sure an retainers, local tuner shop should be able to do it, it'll cost you but with Tht build your gonna need reliable stuff to hold up on power, heads should take Tht over 475 maybe 500 depending on tune and how your timing gets placed
10-05-2010, 03:43 PM | #3 |
Member#: 136396
MWSOC
Vehicle:2020 STI, 2022 WRX |
Good suggestions, if you are going this deep the heads really should get some treatment. Pnp with cams sounds like a good plan along with all the fixings, and do some ARP studs.
Who are you having tune the car? Have you looked into smaller supporting mods to fill out your build?? Phenolic spacers, Boost control solenoid/MBC, and does that turbo XS have a header? Will |
10-05-2010, 05:27 PM | #4 | |
Member#: 259877
http://garagetuning.com/inhouse.html |
10-05-2010, 06:46 PM | #5 |
Member#: 201972
Tri-State
Vehicle:07 WRX TR crystral grey |
have you looked into possible turbo switch i know the GT35 turbos are nice but i have also heard the FP red turbo is like having Chuck Noris kick your car in the backside all the way down the highway
10-05-2010, 06:48 PM | #6 | |
Member#: 259877
right now im just trying to get every thing bullet proof at 450 HP thats it. im not looking for crazzy numbers |
10-05-2010, 07:35 PM | #7 |
Member#: 201972
Tri-State
10-06-2010, 05:46 PM | #8 |
Member#: 27854
MWSOC
Vehicle:STI, WRX, GTR, EVO, BMW, Porsche, + More! |
The heads do not need to be rebuilt to hold more power, however you will need new stronger valvesprings to rev higher than 7500rpm. I would suggest doing cams at the same time as it won't take much more once it's all disassembled.
If you have any questions please let me know! -Ty |
10-07-2010, 05:20 PM | #9 | |
Member#: 259877
so do you think the GT35 is to big for those numbers? the GT35 is fairly new and i dont see much reason for doping $1000+ for a new turbo to achieve the same thing. |
10-07-2010, 05:21 PM | #10 | |
Member#: 259877
10-08-2010, 01:53 AM | #11 |
Member#: 37389
NWIC
Vehicle:2003 gt35r wrx Built not bought |
don't get the turbo xs rotated kit! save your money and get the ams or p&l kit
10-08-2010, 11:46 AM | #12 |
Member#: 259877
10-08-2010, 02:08 PM | #13 | |
Member#: 201972
Tri-State
is yours a twin scroll or just a normal one? |
10-08-2010, 05:01 PM | #14 |
Member#: 153880
RMIC
Vehicle:03 Evo VIII 2011 STI |
10-08-2010, 05:22 PM | #15 |
Member#: 201972
Tri-State
10-08-2010, 10:38 PM | #16 |
Member#: 153880
RMIC
That has nothing to do with the rev limit. IF you miss a gear the rev limit isn't going to do anything because the gear is physically forcing the motor to rev higher.
You could rev 7500-8000 if your motor is balanced and your valve train can handle it. Bigger turbo needs more anyway to keep a better power band. |
10-08-2010, 10:45 PM | #17 | |
Member#: 201972
Tri-State
10-09-2010, 11:05 PM | #18 |
Member#: 259877
10-09-2010, 11:11 PM | #19 |
Member#: 259877
I'm on a bit of a budget but still want to do it right. so trying to live within my means.
this is what im looking at from garagetuning http://www.garagetuning.com/inhouse.html this is installed 2.5 STi engine rebuild All installation labor included Oversized Mahle forged pistons ACL Race Bearings Subaru 08 STi high flow oil pump Gates Racing Teflon timing belt Subaru water pump Subaru timing belt tensioner 3 angle valve job/head rebuild NGK iridium spark plugs fluids $4500.00 +Forged rods option $400 |
10-09-2010, 11:22 PM | #20 | |
Member#: 259877
i picked up the car and it does have Borla heders. I LOVE THE F#$!ING CAR!!!!! |
10-10-2010, 12:56 PM | #21 |
Member#: 201972
Tri-State
ah yeah the twin scrolls are nice but will make you go broke after you have to install the custom set up. Like i said im not familar with your turbo to much but here is a few things to keep in mind
you dont wanna push your turbo to much to reach your #s try to keep it safe and conservitive. sometimes is better to over build and down tune a bit then it is to have an agressive tune. also to i would work closely with the tuner that is going to be tuning your car they will know alot about there dyno and what you need to do to reach the target numbers you want |
10-10-2010, 11:32 PM | #22 | |
Member#: 259877
10-12-2010, 02:39 AM | #23 | |
Member#: 82147
SCIC
Vehicle:2005 WRX Sedan Aspen White |
Similar Threads | ||||
Need Help. 04 STi built motor fueling question | Converted STi | Built Motor Discussion | 10 | 05-06-2010 12:39 PM |
Tons of Motor Parts, Exterior, Clutch Kits, and More. MUST GO | AlineDriver | SWIC Private Classifieds | 0 | 11-12-2009 07:17 PM |
FS - MA - 2005 STi Stock Stuff (Intake, Downpipe, TMIC, VF39 and More) | ZOMG.STi | NESIC Private Classifieds | 79 | 09-01-2009 06:10 PM |
04 STI Cylinderheads with Cams (ALSO- AVCS Gears and More) | 02Toyowrx | Private 'For Sale' Classifieds | 7 | 07-24-2006 01:28 AM |
Motor Rebuild questions | E30M3Pilot | Normally Aspirated with bolt-on Forced Induction Powertrain | 6 | 11-18-2004 04:52 PM |
