Welcome to the North American Subaru Impreza Owners Club Thursday November 14, 2019
Old 06-23-2013, 02:52 AM   #176
jdpsearcher
Member#: 291214
2011 STI Sedan
PBP
Great build man......More and more people building high horsepower Subaru's.....You are in great company....
jdpsearcher is offline   Reply With Quote
Old 06-25-2013, 09:51 PM   #177
osirissirhc
Member#: 144670
05 WRB STi
11 SWP limited STi
End tanks painted.
Just so you know where the kit was made ;-)
osirissirhc is offline   Reply With Quote
Old 06-25-2013, 10:10 PM   #178
stretchedk7
Member#: 170602
06 Wrx RWD Auto
76MM-AEM-2200's
wow looking great!! more pics
stretchedk7 is offline   Reply With Quote
Old 08-27-2013, 07:42 PM   #179
osirissirhc
Member#: 144670
05 WRB STi
11 SWP limited STi
Moving along. Radiator,ic pipes, catch can with -an lines, fuel lines/rails/fuel psi reg, and opened the bumper up a bit more. AEM v2 showed up as well. Waiting on heat wrap, turbo blanket, and foil tape to show up. Here in the next few weeks he will be ordering materials to do the roll cage.
Old 08-27-2013, 08:23 PM   #180
bebesito21
Member#: 176128
5862 ...baby boosted
Are you worried at all about heat with the turbo so close to the engine/timing covers/cam gears?
bebesito21 is offline   Reply With Quote
Old 08-27-2013, 08:39 PM   #181
osirissirhc
Member#: 144670
05 WRB STi
11 SWP limited STi
No the turbo blanket/heat wrap/heat foil will do its job.
Old 08-29-2013, 10:53 PM   #182
osirissirhc
Member#: 144670
05 WRB STi
11 SWP limited STi
4" SS intake to go through the headlight by the man himself at JC FAB.
Old 08-29-2013, 10:56 PM   #183
stretchedk7
Member#: 170602
06 Wrx RWD Auto
76MM-AEM-2200's
looks great, what tb is that?
Old 08-29-2013, 11:22 PM   #184
osirissirhc
Member#: 144670
05 WRB STi
11 SWP limited STi
Boomba dbw
Old 08-29-2013, 11:32 PM   #185
TDagen
Member#: 163648
V9 6mt R180 Brembos
Awesome build.
I'm lookin forward to seeing what this thing does.
TDagen is offline   Reply With Quote
Old 08-30-2013, 12:25 AM   #186
osirissirhc
Member#: 144670
05 WRB STi
11 SWP limited STi
Thanks hopefully here in 3 weeks or so we should be starting it and getting some break in done. Then gotta pull motor and install the inner valve springs as per the cam break in. Then once the motor is out I will have the engine bay shaved and painted.
Old 08-30-2013, 12:58 AM   #187
reemwrb04sti
Member#: 254796
04 Sti
Nice setup!! I have Gsc s3 cams with same supertech spring kit...never saw someone install inner spring after break in...I think you be fine installing both while breaking I'm the motor...you plan on wrapping your downpipe ? It's close to the I/C piping and could make the intake temps rise
reemwrb04sti is offline   Reply With Quote
Old 08-30-2013, 01:06 AM   #188
osirissirhc
Member#: 144670
05 WRB STi
11 SWP limited STi
Ill have to do the research again I suppose. That is correct down pipe/exhaust will be wrapped. I/C pipes will be wrapped with gold heat foil along with my timing covers.
Old 08-30-2013, 01:12 AM   #189
reemwrb04sti
Member#: 254796
04 Sti
Oh ok! Those are real close !
Old 08-30-2013, 08:23 AM   #190
stretchedk7
Member#: 170602
06 Wrx RWD Auto
76MM-AEM-2200's
I didnt do all that either with mine. I always just install both and roll out. ANd thanks for the info on tb
Old 09-02-2013, 02:33 PM   #191
Irv Weissmanhowerton
Member#: 278519
30r E85 sti 450+whp
kb'izzle
Nice fab'n , is the maf still in the intake? I ask because I thought it was tricky to tune unless there was a decent straight section between the sensor and the filter . Like 6-10"
Irv Weissmanhowerton is offline   Reply With Quote
Old 09-02-2013, 02:39 PM   #192
stretchedk7
Member#: 170602
06 Wrx RWD Auto
76MM-AEM-2200's
Id imagine with the aem he is going to run speed density so even if the maf was in intake pipe which i bet it isnt it wouldnt matter. the maf would just provide the ecu with an inlet temperature.
Old 09-03-2013, 02:50 AM   #193
osirissirhc
Member#: 144670
05 WRB STi
11 SWP limited STi
Speed density is correct.
Cole at JC FAB does some sexy work I do agree.
Old 09-03-2013, 12:15 PM   #194
osirissirhc
Member#: 144670
05 WRB STi
11 SWP limited STi
In reference to the "outer springs only",
I messaged GSC and here is the response:
Hey Christopher,
Which spring kit do you have? Do you know the seat pressure? Typically you need to run just the outer spring for break in, and I would recommend that. I know it’s a huge PITA, but its what needs to be done to do it right.
Keep the revs around 2-2500 for the first 20 minutes or until the oil temp is all the way up, don’t let it idle. You need to keep the oil pressure/flow high in the heads.
Thanks,
__________________________________
Travis Brodie
Old 09-04-2013, 12:04 AM   #195
osirissirhc
Member#: 144670
05 WRB STi
11 SWP limited STi
And then ........ Chris,
For the super techs I would say you are fine for the break-in with both springs. They will work fine and donít have crazy seat pressure. Just make sure that there is assembly lube on all the moving parts and that the oil pressure is high-keep the revs up off idle.
Thanks,
Travis Brodie
So should I or shouldn't I hahahahahah
Old 09-04-2013, 12:23 AM   #196
stretchedk7
Member#: 170602
06 Wrx RWD Auto
76MM-AEM-2200's
idk. its up to you obviously. if your worried about it dont risk it
Old 09-06-2013, 12:20 AM   #197
project_skyline
Member#: 153880
03 Evo VIII
2011 STI
I'm appalled you think we would run a MAF on a build of this caliper. We're running 5 bar map sensor.
project_skyline is offline   Reply With Quote
Old 09-10-2013, 09:11 PM   #198
osirissirhc
Member#: 144670
05 WRB STi
11 SWP limited STi
Some of these pics may seem repetitive but there is minor differences :-).
Old 09-10-2013, 09:56 PM   #199
scby rex
Member#: 104878
02 wrxbastardchild
aw, MPS 2.34 breaking in
I hope that vaccum block works for you. For some reason subys don't like them.
scby rex is offline   Reply With Quote
Old 09-10-2013, 11:58 PM   #200
subyswamper
Member#: 91049
2008 wrx wgn
charcoal grey
I like your build very much.
subyswamper is offline   Reply With Quote
