Welcome to the North American Subaru Impreza Owners Club Saturday February 22, 2020
Old 05-24-2012, 01:24 AM   #1551
punchjamesarnol
Member#: 284835
2014 Hyundai Equus
White Pearl Mica
Originally Posted by dexterous View Post
I have been researching how to better read spark plugs and I came across this picture. All I can say is damn, I thought my plugs looked bad! I have no idea what did that but whoever owns that motor is screwed!
WTF???
punchjamesarnol is offline   Reply With Quote
Old 05-24-2012, 01:57 AM   #1552
silver arrow
Member#: 25859
1965 MGB yellow
2008 Black Miata
I'll bet the piston had some chunks missing.
silver arrow is offline   Reply With Quote
Old 05-24-2012, 02:13 AM   #1553
kakarot09
Member#: 182375
08 Sti
Wrbm
Originally Posted by alcoolaid View Post
What are the chances 2 injectors on the same side are spraying more fuel. Still think it's something else. Swapping both left and right will rule that out.
1 in 6? But it's not like that's the only possibilty. Just one I thought he could check.
kakarot09 is offline   Reply With Quote
Old 05-24-2012, 08:16 AM   #1554
dexterous
Member#: 23553
2005 STI - Insanity!
2014 WRX - Daily
I had the injectors flow tested 500 miles ago and they all came back good. I looked at the flow sheet and sure enough, two of them flow a bit more than the others. I dont have the sheet in front of me but i know that it was about an 8cc difference. I am going to Swap the injectors very soon.
dexterous is offline   Reply With Quote
Old 05-24-2012, 08:57 AM   #1555
maxpowr
Member#: 159243
5/01 bugeye
Hakt Ecu is back!
Just because they tested good, doesn't mean a bit of debris or something didn't get through and mess em up, right? I mean I certainly hope a fuel filter does what its supposed to but in your case, wouldn't it be nice if it was just a dirty injector? I bought new ones and they sat. 6 months later I sent them out again for service and they came back with better numbers. Not by much but slightly better!
maxpowr is offline   Reply With Quote
Old 05-24-2012, 04:02 PM   #1556
kakarot09
Member#: 182375
08 Sti
Wrbm
The 8cc difference isn't the issue. 8cc out of 1260 is less than 1%. That's at high flow rates anyway not at idle. The issue is that the low pulsewidth variation in flow can be much much higher unless the set is dynamically matched.
This explains it better than I could ever hope to.
http://www.injectordynamics.com/dynamicmatch.html
It still may or may not be the issue. I just thought it was worth a look. I don't think many people would notice this issue if they had it because they just don't have the same attention to detail that you do. Most people do not remove the spark plugs at 500 miles and check them if there are no obvious issues.
Old 05-24-2012, 06:09 PM   #1557
kellygnsd
Member#: 32669
2007 2.34LR, EFR7670
LINK G4+ hybrid STi
I was just thinking about the stock ROM and their per cylinder injector compensations. Maybe its time to start tuning fueling on a cylinder by cylinder basis. I'm sure the Hydra has the technology.
Old 05-24-2012, 08:53 PM   #1558
dexterous
Member#: 23553
2014 WRX - Daily
I followed Phil's instructions and went for a drive at 3000-4000 RPM and here's the results:
The left plug is from Cyl 4 which still looks a touch rich but much better. The right plug is from Cyl 3 which looks like its been running very lean.
Old 05-24-2012, 08:57 PM   #1559
n2xlr8n
Member#: 18960
02 WRX MBP
It lives! ; )
Are those new?
Give us side shot showing the ground strap, and a above shot showing the fire ring / electrode. The only thing the porcelain portion of the plug is good for is looking for signs of detonation.
If you're going to read plugs over 40, you're going to need a 10x eye loupe, as well
S.
n2xlr8n is offline   Reply With Quote
Old 05-24-2012, 09:01 PM   #1560
kakarot09
Member#: 182375
08 Sti
Wrbm
what was the injector pulse width during the cruise?
Old 05-24-2012, 09:15 PM   #1561
Layvon
Member#: 195711
PART OUT. PM ME
02-07 Goodies
Just out of curiosity, and ease of experimentation cause my motor is in my living room... I ran some tests, since my ground strap might not be in the "ideal" location.
Since I pulled my motor apart in a whirlwind motion trying to get the motor out of the house for another NASIOCer, I dont even know where the "right" position is, easily found though.
On the passenger side, I have my strap tucked into the bottom of the intake manifold where the fuel rail used to mount, nice clean virgin aluminum.
I tested the resistance between this location, and the valve cover - 0.3Ω
Not bad.
Tested the resistance across the valve cover itself - 0.3Ω.
Didn't believe it, so I tried it again, switching probes around for S&G. Same result.
Either I found a good alternate location, or the mounting location is not that important as long as a good solid connection. The thing with the IM mount I was worried about was that I am using phenolic spacers. But clearly the 8 bolts secured to the frame are diong a good job as a conductor. ... Thoughts?
I just feel like this would take away the argument of GND strap.
Thanks,
Layvon
Layvon is offline   Reply With Quote
Old 05-24-2012, 09:15 PM   #1562
Layvon
Member#: 195711
PART OUT. PM ME
02-07 Goodies
Not bad.
Thanks,
Layvon
Old 05-24-2012, 09:57 PM   #1563
dexterous
Member#: 23553
2014 WRX - Daily
Not bad.
Thanks,
Layvon
I had very similar results when I tested the same thing a few weeks ago.
Old 05-24-2012, 10:06 PM   #1564
dexterous
Member#: 23553
2014 WRX - Daily
Old 05-24-2012, 10:16 PM   #1565
dexterous
Member#: 23553
2014 WRX - Daily
The only real change that I made prior to driving the car was to lower the minimum pulse width to .3ms. It was previously set at .5ms and I couldn't get the car to lean out at idle. The best it would idle was 11.2:1 and now it idles at 13.2:1. As far as I can tell, it has also eliminated any visible smoke that the car was producing at idle and while driving.
I am not sure how to convert the duty values in the Hydra 2.6's base fuel map to pulse width. Any suggestions?
Old 05-24-2012, 10:16 PM   #1566
n2xlr8n
Member#: 18960
02 WRX MBP
It lives! ; )
3 looks lean, for sure...though I'm not sure what a 3k to 4krpm plug is supposed to look like...I usually read them immediately after a full pull / pass.
By "ground strap", I was referring to the spark plug...not engine / chassis grounds.
Ground strap=heat range
Fire ring=mixture
Porcelain=bad stuff
S.
Old 05-24-2012, 10:26 PM   #1567
dexterous
Member#: 23553
2014 WRX - Daily
Originally Posted by n2xlr8n View Post
Are those new?
S.
I assume the ground strap is the hook thing at the top, right?
Old 05-24-2012, 10:35 PM   #1568
dexterous
Member#: 23553
2014 WRX - Daily
Cyl 3:
Old 05-24-2012, 10:35 PM   #1569
dexterous
Member#: 23553
2014 WRX - Daily
Cyl 4:
Old 05-25-2012, 12:22 AM   #1570
Bariga
Member#: 179846
07 STi Limited
EFR 8374 TS EWG
you idle at 13.2 and before at 11.2 wtf loooloooooooooooooool
idle has to be 14.6 , 13.2 is bad for your cylinder walls
Bariga is offline   Reply With Quote
Old 05-25-2012, 12:37 AM   #1571
n2xlr8n
Member#: 18960
02 WRX MBP
It lives! ; )
This^^
Makes it tough to seat rings, huh?
Old 05-25-2012, 12:54 AM   #1572
Bariga
Member#: 179846
07 STi Limited
EFR 8374 TS EWG
to seat rings you need 10 psi for about 6 pulls
mine not seated yet i'm running at 5psi
Old 05-25-2012, 11:41 AM   #1573
bboylocob
Member#: 151809
2007 WRX
If he followed phils break in then he should be fine. Which he has 500 miles on it now so im sure he did like so.
bboylocob is offline   Reply With Quote
Old 05-25-2012, 11:46 AM   #1574
Layvon
Member#: 195711
PART OUT. PM ME
02-07 Goodies
Imagine that, Bariga knows more than everyone here again! Anton when you going to start your own shop cause you know it all brotha!?
Old 05-25-2012, 11:51 AM   #1575
NW2TONE
Member#: 212509
unde your hood makin
your **** go faster
lol its in his nature lol. if he started a shop it would stripping them down right anton lol
NW2TONE is offline   Reply With Quote
VF37 Twin Scroll Turbo and New Tomei Twin Scroll headers/Up pipe arco SCIC Private Classifieds 11 10-22-2010 02:09 AM
Picture of my new Ultimate Racing twin scroll kit blowbyu24 Member's Car Gallery 682 08-24-2010 09:12 AM
VF37 Twin Scroll Turbo and New Tomei Twin Scroll headers/Up pipe arco Engine/Power/Exhaust 9 10-02-2009 02:04 PM
FS VA: JDM manifold, Twin Scroll kit, JDM Genome and more quadzilla Engine/Power/Exhaust 38 09-18-2008 11:22 PM
Pros and cons of twin-scroll turbo! Carisma Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 59 07-04-2005 06:06 PM
