Welcome to the North American Subaru Impreza Owners Club Sunday February 23, 2020
Go Back   NASIOC > NASIOC Technical > FA Series Factory 2.0L Turbo Powertrain
Old 02-24-2017, 12:22 PM   #1
gn4rwhals
Member#: 453427
2017 WRX
Crystal White Pearl
Default FA20 COBB Logs - Post Yours Here!
Hello all,
I wanted to keep this to just the FA20 turbo motor in general, but I like looking at logs and learning about what is good vs. bad from a log standpoint in regards to tuning at different levels.
I did not see any threads started for general data log review for the FA20 so I figured I'd start one.
From simpleJ:
Originally Posted by simpleJ View Post
for the last time.
LOG YOUR COMMAND FUELING.
Map or command fuel final. better yet both. If not.... We cannot tell you how or unsafe your map is without this value. We cannot tell you if you are running lean or rich as it is relative to your map. We cannot tell you if your map is lean or rich. We cannot tell you if you have a leak. We cannot tell you if your intake is causing problems. We cannot tell you if your maf might be dirty. We cannot tell you if your timing is OOC because of your intake. Help us help you.
at minimum also log...
-ignition timing
-af learning 1
-calc load
-maf g/s
-td boost error
-target boost
-intake temp
-fine knock lrn
-feedback knock
Regarding Knock (GlarryHoodDIT):
Originally Posted by GlarryHoodDIT View Post
It isn't necessarily a learned correction. It can be a result of repeated Feedback Knock Correction, but it is often independent. Typically Feedback Knock Correction is more active during rapid load changes- like mashing the throttle or building up through a pull. Fine Knock Learn Correction is typically more active during steady load and upper RPM ranges.
These are invaluable.
http://www.romraider.com/RomRaider/H...ndKnockControl
http://www.romraider.com/forum/viewt...hp?f=40&t=1840
IAM = DAM.
Post Format:
- Year and model
- Power Mods
- 6MT or CVT
- Fuel Used
- Tune Used
- Gear used for pull.
I'll start!
2017 WRX
Invidia N1 Catback
6MT
93 Octane
COBB OTS Stage 1 91
4th Gear
http://datazap.me/u/gn4rwhals/log-14...12-14-18-20-21
gn4rwhals is offline   Reply With Quote
Old 02-24-2017, 01:57 PM   #2
simpleJ
Member#: 391748
2015 WRX CWP (sold)
2019 STi CWP
Holy rich.
Please please please please log command fueling guys. We have no idea exactly how forked your engine/intake/tune is in open loop without logging this parameter
simpleJ is offline   Reply With Quote
Old 02-24-2017, 01:57 PM   #3
ericdet
Member#: 327563
2018 Civic Type R
2008 N54 335i
Originally Posted by gn4rwhals View Post
Hello all,
Post Format:
- Year and model
- Power Mods
- 6MT or CVT
- Fuel Used
- Tune Used
I'll start!
2017 WRX
Invidia N1 Catback
6MT
93 Octane
COBB OTS Stage 1 91
4th Gear
There's probably more than a hundred FA logs already here. I could see a thread in that section but this one already serves its purpose pretty well.
https://forums.nasioc.com/forums/sho....php?t=2760402
ericdet is offline   Reply With Quote
Old 02-24-2017, 02:01 PM   #4
gn4rwhals
Member#: 453427
2017 WRX
Crystal White Pearl
Holy rich.
Well it is COBB OTS, they tend to do that.
Old 02-24-2017, 02:31 PM   #5
simpleJ
Member#: 391748
2015 WRX CWP (sold)
2019 STi CWP
Ahhh no, not really.
That's about .6-.8 afr too rich up top.
Unless you're going WOT uphill in 4th with a load of bricks in the trunk, in which case, carry on.
Old 02-24-2017, 02:56 PM   #6
gn4rwhals
Member#: 453427
2017 WRX
Crystal White Pearl
Interesting, does having a trunk full of air ride count lol? Possibly running 93 on a 91 tune causing this?
Edit: The pull may have been slightly uphill, in 4th gear, and yeah trunk full of air ride. I believe 4th puts more load on the engine, I now see that everyone wants 3rd gear.
Old 02-24-2017, 03:07 PM   #7
Schoat333
Member#: 452248
2017 Base WRX
I really like this datazap format. Agree that you are a bit rich, but like you said, this is an OTS map, and not a custom tune.
I'd really like to see some more of these from different tuners.
Schoat333 is offline   Reply With Quote
Old 02-24-2017, 03:16 PM   #8
gn4rwhals
Member#: 453427
2017 WRX
Crystal White Pearl
Datazap is life man, I started the engine tuning discussion on the MQB VW platform a few years back and got everyone hooked.
Old 02-24-2017, 03:17 PM   #9
simpleJ
Member#: 391748
2015 WRX CWP (sold)
2019 STi CWP
Or just log your command fueling so we actually know wtf is happening to your afr
Old 02-24-2017, 03:21 PM   #10
gn4rwhals
Member#: 453427
2017 WRX
Crystal White Pearl
Will do, if it doesn't get crappy rainy later today I'll go log.
Old 02-24-2017, 03:31 PM   #11
tegxsi
Member#: 446029
Looks about right for an OTS map....garbage.
tegxsi is offline   Reply With Quote
Old 03-01-2017, 01:53 AM   #12
Sandlsk
Member#: 431110
2015 wrx
Crystal White Pearl
Default Knock Learning Issue
Starting off from a stop to do a pull I had a large knock learning of 9.84 caused by what looks like the feedback knock of 1.41. I have no idea why this would happen should timing be lowered to correct or is this some other issue. Thanks
- 2015 Wrx
- Nameless Muffler Delete, Egr delete
- 6MT
- 91 octane fuel
- cobb ots stage 1 hwg
- started 1st gear went up to 3rd
https://docs.google.com/spreadsheets...it?usp=sharing
Sandlsk is offline   Reply With Quote
Old 03-01-2017, 02:39 AM   #13
GlarryHoodDIT
Member#: 460907
2016 WRX
Gotta imagine driving around with unsupported EGR deletes has something to do with that.
You are super lean at WOT for an OTS map, something is very, very wrong I would think. OP is running several full points lower AFR than you on like the same map. Wait until Simple and ericdet can see this but, but Id say stop WOT immediately.
GlarryHoodDIT is offline   Reply With Quote
Old 03-01-2017, 07:32 AM   #14
simpleJ
Member#: 391748
2015 WRX CWP (sold)
2019 STi CWP
- 2015 Wrx
- 6MT
- 91 octane fuel
Gee you mean I took the exhaust gas recirc system off and didn't make any changes to the timing, avcs, etc to account for the differences in air/fuel ratio, cylinder temp, or mixture patterns in the cylinder and that may cause problems? Who woulda thunk it.
You're running lean. Maybe you're underboosting too, idk, I can't tell because there's no target boost or intake temp logged.
That's too many lines of data to take the time to sift through. 3rd gear 2000 to as close to redline is safe please on a flat road and just flatten the loud pedal.
Please log command fueling and target boost at minimum here if you're going to post a log. I'll poke over the rest of what you have when I have a moment at work
Old 03-01-2017, 12:18 PM   #15
uofime
Member#: 421271
2015 WRX
Galaxy Blue Pearl
IMO TDBoostError is better to look at than target because it takes whatever compensations the ECU is using into account then tells you at any instant how far off you are.
Never bothered to look at commanded fueling, why do you believe that is better than looking at the output, the AFR?
DataZap is awesome, got a bunch all organized there, here's some highlights:
Here's some beating on it on a stage 1 93 ots (15 wrx, 93, MT, AP only, 3-4-3) and the car knocking a little:
http://datazap.me/u/uofime/transient...96-353-458-415
Here's an OTS stage 2 93(15 wrx, 93, MT, AP + catted J, 3-4) also knocking a little
http://datazap.me/u/uofime/ots-s2-11...&zoom=762-2125
same time, trying to roll into it a little more see if that helped knock:
http://datazap.me/u/uofime/ots-s2-11...zoom=2192-2779
Protuned, the weather gained 40 degrees and I replaced a clutch that may have been slipping during tuning( 15wrx, 93, MT, AP cattedJ tgvd egrd EBCS, 3rd gear) Having a little bit of a boost control issue, overboosting low and under high getting a little knock
http://datazap.me/u/uofime/post-clut...18-19&solo=3-6
Map updated for boost control ( 15wrx, 93, MT, AP cattedJ tgvd egrd EBCS, 3rd gear) no more overboost, still really light knock, could be crappy winterblend gas on a warm day, keeping an eye on it.
http://datazap.me/u/uofime/bpt-rev-2...18-19&solo=3-6
uofime is offline   Reply With Quote
Old 03-01-2017, 12:32 PM   #16
simpleJ
Member#: 391748
2015 WRX CWP (sold)
2019 STi CWP
The only reason I like target boost is that it shows you the boost curve and then along with TD boost error you can extapolate what the car is actually doing. I believe target boost reflects comp tables as well.
Command fuel final reflects target fueling the ecu wants at any given time. it gives context to an AFR value.
If your car is running 11.6 under boost maybe it is lean, or maybe that's what the ecu wants. I can't tell that just from looking at the afr
Old 03-04-2017, 02:08 AM   #17
aziankingz
Member#: 268301
2016 Forester XT
2016 FXT, stock with only protune:
http://datazap.me/u/chrisy783/highwa...og=0&data=5-20
Just a simple cruise around highway and city streets. Just wanted to log normal driving to see if everything is ok.
I got a revision shortly after this and have not logged since. I will probably do it this weekend with some pulls and share with you guys.
aziankingz is offline   Reply With Quote
Old 03-05-2017, 03:27 AM   #18
dkkwon
Member#: 440117
2016 WRX
Default 2016 WRX - TP Tune
Here's my log. I'm on a 6th revision of a TP tune with just a grimmspeed EBCS and an ETS cat back. I'm pretty new to all of this so I'm not sure how to interpret the data. Can anyone provide feedback on how the log looks? Thanks!
http://datazap.me/u/dkkwon/log-14886...a=3-7-12-18-19
dkkwon is offline   Reply With Quote
Old 03-05-2017, 11:23 AM   #19
simpleJ
Member#: 391748
2015 WRX CWP (sold)
2019 STi CWP
for the last time.
-ignition timing
-af learning 1
-calc load
-maf g/s
-td boost error
-target boost
-intake temp
-fine knock lrn
-feedback knock
Old 03-05-2017, 02:33 PM   #20
dkkwon
Member#: 440117
2016 WRX
I logged only what the tuner asked. Is it concerning that he's not looking at command fueling? or is that only necessary for others who did not create the map?
Old 03-05-2017, 02:54 PM   #21
simpleJ
Member#: 391748
2015 WRX CWP (sold)
2019 STi CWP
no- he knows what he set the value to in his maps. We don't have your tune so we cannot possibly see his fueling strategies which is why need it
Old 03-05-2017, 07:51 PM   #22
gn4rwhals
Member#: 453427
2017 WRX
Crystal White Pearl
I edited the first post to hopefully make things easier.
Old 03-05-2017, 08:32 PM   #23
simpleJ
Member#: 391748
2015 WRX CWP (sold)
2019 STi CWP
Hahahha I literally lol'd.
Thanks though.
This is not an EJ which lacks visibility to the AFR. You need to log more parameters to get a full picture of your maps
Old 03-06-2017, 09:15 AM   #24
CGumina
Member#: 459394
2015 WRX
Crystal White
Knock yourselves out.
Box stock 2015 WRX with a mediocre Cobb 91 OTS tune using 93 fuel. The first little bit of the graph wasn't full throttle until 2650RPM, so don't let that trip you up. Outside temp was ~20*F when logged.
http://www.datazap.me/u/cgumina/3rd-...4-6-8-10-15-17
No knock learn, DAM is always at 1, only get the occasional BS -1.41 feedback knock from the AC kicking on. Car has been dead nuts reliable on this tune. I plan on putting the 93 octane flash in it once the weather warms up, winter fuel sucks.
CGumina is offline   Reply With Quote
Old 03-06-2017, 09:44 AM   #25
simpleJ
Member#: 391748
2015 WRX CWP (sold)
2019 STi CWP
Car is underboosting and running pretty rich.
Boost leak? Try the hwg tune?
