Tire & Wheel Forum sponsored by The Tire Rack |
04-27-2004, 11:40 AM | #1 |
Member#: 52869
would rota formel or attack fit over the sti brembos?
i heard that they wont fit. but i wonder if they would fit the brembos with spacers on. and how thick of a spacer would i need? i am worried about it rubbing the outer fender on the gc8
04-27-2004, 01:32 PM | #2 |
Member#: 13856
Vehicle:04/5 STI white/WRB |
Without any spacers, it will not fit GDB Brembos.
I have not really tried putting on spacers so I would not know how thick a spacer is needed. I'll check it and post again. The next problem is the GC8 will not take anything lower than a 48 offset without some fender modifications |
04-27-2004, 09:00 PM | #3 |
Member#: 52869
that sucks so if i brembos on my gc8, formel and attacks wont be an option?
which rims will fit the brembos in the rota line up? would these fit? the rota torque, tarmac/tarac 2, |
04-28-2004, 01:32 AM | #4 |
Member#: 13856
SDR, Tarmac 2, Torque in 17x8 will clear Brembos.
I suggest the SDR and Tarmac 2 since they are 17x7.5 while the torques are 8 inch wide |
04-28-2004, 03:57 PM | #5 |
Member#: 10852
Vehicle:Then : JDM Ver 7 STi Now : E46 M3 / MKVI GTI |
so is there a way to cram the 8" torques into a GC? I really want to use that wheel.
04-29-2004, 02:56 AM | #6 |
Member#: 52869
how about the downshifts?
they look ok too with the gc8 |
04-29-2004, 11:55 AM | #7 | |
Member#: 13856
In my GC8, I can get away with 17x7.5 offset 48 and 215 tires. This is on an STI RA so it is a little lower than stock |
04-29-2004, 11:56 AM | #8 | |
Member#: 13856
04-29-2004, 04:59 PM | #9 |
Member#: 52869
i am planning to use 235 45 17 tires though.
what rims would have an offset where i can use 235 and clear the ver 8 brembos and not rub the gc8? |
04-29-2004, 06:06 PM | #10 |
Member#: 22879
The rota torques are now available in a 17x 7.5 width with the common 48 offset. I checked with a vendor to see if they cleared the brembos, but they didn't know.
They said i could run a 215 sized tire on a 7.5 inch rim and clear my legacy fenders pretty easy. I think ( but don't really know for sure) if you moved to something like a 52 offset then you wouldn't rub on the fenders, but might on the strut if you're running a wide tire. Brent |
wheels that will fit over the STi brakes | ANZAC_1915 | Tire & Wheel | 319 | 12-17-2015 10:17 AM |
Any 16 inches will fit over the Rear brembo | Mister_wagon | Tire & Wheel | 6 | 01-12-2005 12:57 PM |
SSR designed a very light wheel to fit over the STi Brembos | Nivek-CA | Tire & Wheel | 39 | 12-08-2003 07:50 PM |
What wheels will fit over the sti brembo brakes? | D-I-Z-Z-L-E | Brakes, Steering & Suspension | 7 | 07-07-2003 07:53 PM |
Will 16's fit over the brembos? | Jasonoff | STi Forum Archive | 10 | 02-20-2003 12:49 PM |
