Welcome to the North American Subaru Impreza Owners Club Saturday June 24, 2017
View Poll Results: Year/model of the car the failure happened
04 STI 34 11.56%
05 STI 19 6.46%
06 STI 87 29.59%
07 STI 20 6.80%
08 STI 11 3.74%
05 LGT 6 2.04%
06 LGT 9 3.06%
07 LGT 3 1.02%
08 LGT 0 0%
02-05 WRX 55 18.71%
06 WRX 17 5.78%
07 WRX 12 4.08%
08 WRX 9 3.06%
04-08 FXT 12 4.08%
Voters: 294. You may not vote on this poll
Old 12-16-2015, 03:38 PM   #851
Myblack2006sti
Member#: 391159
- 2006 sti
- 89,000
- turbo gone engine rebuild
- nope said it wasn't a problem with the oil pick up tube breaking
- spt intake
Myblack2006sti is offline   Reply With Quote
Old 04-12-2016, 10:37 AM   #852
suburrito
Member#: 384053
2006 STI
SGM
- 2006 sti
- 110K
- none, was changing proactively, and noticed 3 cracks forming
- no warranty
- pro tuned stage 2
suburrito is offline   Reply With Quote
Old 09-21-2016, 08:29 PM   #853
KIMCHEE
Member#: 430003
2015 STI Limited
2015 STI Limited
18,500 Miles
Stock
My wifes commuter car.
Oil tube pickup issue. CEL came on about 100 miles ago. Subaru is ordering the parts.
KIMCHEE is offline   Reply With Quote
Old 11-23-2016, 11:29 PM   #854
hondaeater69
Member#: 60324
1998 RS
Originally Posted by KIMCHEE View Post
2015 STI Limited
18,500 Miles
Stock
what was the CEL for?
hondaeater69 is offline   Reply With Quote
Old 11-23-2016, 11:32 PM   #855
hondaeater69
Member#: 60324
1998 RS
wow i'm glad i found this thread. i have an 06STi motor in my rs conversion! seems 06sti motors are failing dis-proportionally. hot dam. why isn't this sticked? i'm coming up on 30K miles, so i'll be getting the killerb and getting it installed before driving it any more. this thread is what nightmares of made of. i'm not sure i'll be able to sleep until this gets fixed !!
Old 12-15-2016, 12:33 PM   #856
todd_fuller
Member#: 79004
2005 Impreza WRX STi
Crystal Grey
- 2005 STi
- 127k miles
- R&R pickup tube while doing oil pan gasket since I was in there
- pickup tube had no cracks.
todd_fuller is offline   Reply With Quote
Old 12-15-2016, 05:04 PM   #857
Silver VR4
Member#: 240625
This was a few years ago, but:
2006 STI
85k(I forget exactly when I replaced it, but I know it was under 100k when I did it)
Oil pressure light would flicker on start up, no damage otherwise
Noticed cracks near the top flange on pick up tube
Replaced with KillerB pick up tube
Silver VR4 is offline   Reply With Quote
Old 12-16-2016, 10:31 AM   #858
CHR1S H4NSEN
Member#: 330050
I'll be putting in the KillerB in the next few months.
2017 STi
CHR1S H4NSEN is offline   Reply With Quote
Old 12-19-2016, 09:37 AM   #859
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
We've been making our pickup since 2009. Over the years I've heard more stories than I can count. It's always saddening when a $20 part destroys a several thousand dollar engine :/ To date our 'failure is not an option' design had zero failures. Very proud that we can provide a part that helps instill confidence in the cars we love so much!
Thanks so much for the support guys!!
Old 03-24-2017, 11:52 AM   #860
NoobaruSubaru
Member#: 457635
2015 WRX STi
World Rally Blue
2015 STi
25,xxx miles
100% Stock
Dealer is replacing my engine and everything oil related. They placed emphasis on the oil pick up tube and pump. Will be ordering a KillerB pick up and see if my dealer will use that instead lol.
NoobaruSubaru is offline   Reply With Quote
Old 03-24-2017, 12:12 PM   #861
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Originally Posted by NoobaruSubaru View Post
2015 STi
25,xxx miles
100% Stock
We sell the pickup to many dealers. If they have any issue with it (and they are not already using ours), have them give us a call.
Old 06-13-2017, 06:21 AM   #862
RexKwonDo
Member#: 404751
2017 WRX STi
Crystal White Pearl
kind of insane that I did this on my 2007 STI and ten years later, I will probably have to do it again on a 2017 STI.
SMFH SUBARU
RexKwonDo is offline   Reply With Quote
Old 06-14-2017, 12:04 AM   #863
motoman399
Member#: 270808
SMFH SUBARU
After the warranty period of course! Subaru should have to replace all the failures!!
motoman399 is offline   Reply With Quote
Old 06-15-2017, 02:28 AM   #864
RexKwonDo
Member#: 404751
2017 WRX STi
Crystal White Pearl
That's what I was thinking...I usually only tend to keep cars for 2-3 years tops, if it goes before then at least it won't be at my expense. Still, pretty absurd that the company would rather just keep replacing blown motors than just fix the f'ing problem.
Old 06-15-2017, 07:00 AM   #865
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Well, they tend to stick to the contract; if it fails before warranty period, they cover it.
There is likely some bureaucracy involved as well since Subaru sources them from another OEM. Also, in Japan where new car ownership is much shorter than here in the US, this is next to non-existent in the JDM.
Old 06-19-2017, 02:23 AM   #866
Abismo
Member#: 99707
2010 WRX (in spirit)
Curious what the oil pickups for the 15+ wrx / sti look like. have you guys cracked those open yet?
granted different motor I know of course.
Abismo is offline   Reply With Quote
Old 06-20-2017, 08:07 AM   #867
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
All 2006-current MY STi pickups are the same part number.
FA pickups are different, and we do make a pickup for those as well. The tubes don't fail, but we have see screen failures that have caused the pump, crank, etc. to be destroyed by allowing larger debris into the pump. The OEM FA pickup has spot welds that cause the screen wires to break very easily. Ours has a larger screen area and uses a different process to hold the screen in place... among other changes to improve oil flow
Old 06-20-2017, 11:35 AM   #868
Abismo
Member#: 99707
intriguing. has there been any reports of those screens breaking and grenading engines. As always that pickup looks beefy.
Old 06-20-2017, 02:05 PM   #869
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
I and a couple others have had similar experiences, but this is going to be a chicken and the egg argument. Did the pump failure cause the engine to blow, or did the engine blowing cause the pump to fail. Either way, the screen lets go. Here are some pictures of OEM, the failure we had... that led to creating our own pickup.
Oil pickup tube failure mikeb01453 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 03-24-2009 09:39 AM
Oil pickup tube torque spec? LeeC Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 4 12-11-2008 12:15 PM
oil pickup tube. jstam Built Motor Discussion 26 09-04-2008 05:56 PM
Oil pickup tube torque spec? LeeC Built Motor Discussion 0 07-24-2008 05:54 PM
oil pickup tube, need help asap please ihadmail Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 7 07-10-2008 11:25 PM
