Welcome to the North American Subaru Impreza Owners Club Saturday June 24, 2017
Old 06-20-2017, 10:15 PM   #11376
Titter
Member#: 416107
2002 WRX Wagon
EJ207 Spec C 4EAT
Default EJ207 Owners?
my mishi cap is fine. over a year no issues.
it has to go on the expansion tank not the rad.
Titter is offline   Reply With Quote
Old 06-21-2017, 12:16 PM   #11377
Samurai Jack
Member#: 21145
2002 Enemy of Aku
Originally Posted by Gigs90 View Post
or just Mishimoto is crap works lol
Haven't had a problem yet with my Mishimoto radiator
Old 06-21-2017, 12:20 PM   #11378
Gigs90
Member#: 306719
2003 Sti Wagon
@jn_garage
I have seen a bunch start leaking unfortunately
Gigs90 is offline   Reply With Quote
Old 06-21-2017, 12:34 PM   #11379
BlueSTI4Me
Member#: 34361
04.7 STI
Originally Posted by D-Rodman View Post
I've been having an issue with my car that I considered to be related to the idle air control valve. On hot days sitting on idle or when sitting in traffic for a bit the car would start idling high. the idle would start rising above 1000 rpm and get up to 3-4000 rpm. Once I'm able to get the car moving on the highway for a bit the idle would return to normal. Other times the condition manifest when I've been driving the car, everything normal, I make a quick stop and turn the car off. When I get back to the car and fire it up the idle will be high, once again, getting on the road for a bit and the idling returns to normal. Saturday I installed a brand new OEM Idle air control valve but to my surprise after driving the car and it operating perfectly normal I made a stop and turned the car off for about 10-15 minutes. When I fired it back on it started to idle just above 1000 rpm. Now I don't understand what is happening, why the issue ? Seems to be related to the coolant temperature. Could it be that I installed the thermostat upside down ? Your help input is always appreciated.
Have you changed the IAC? Or cleaned the port?
BlueSTI4Me is offline   Reply With Quote
Old 06-21-2017, 02:10 PM   #11380
D-Rodman
Member#: 110078
05 Saabaru JDM STi
Black Ver 7 18G 6sp RA
Yes, I installed a brand new oem IAC, today the car started to high idle, I pulled over and opened the hood to take a look at the throttle body mechanism where the throttle cable is attached. I think I just need to slack the cable, I pushed the mechanism to the closed position and the idle normalized. I'll report back after I adjust the cable.
D-Rodman is online now   Reply With Quote
Old Today, 08:12 AM   #11381
D-Rodman
Member#: 110078
05 Saabaru JDM STi
I rerouted the cruise control cable and gave the throttle cable a little more slack. No more mysterious high idling, problem fixed.
ej207 owner wants opinions adbramsay Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 02-26-2011 07:29 PM
Ej207 V6 AndrewFD3 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 06-03-2010 04:53 PM
JDM Sti EJ207 V9 crank 75mm or billet crank (K1, Manley) VENDORS ??? L'frise Private 'Wanted' Classifieds 7 06-03-2010 09:24 AM
08 ej207 JDM dual AVCS heads on a built v7 ej207 icev7 Built Motor Discussion 17 02-21-2010 03:21 PM
Ver 8 EJ207 Owners Check In spoolinsuby Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 21 10-17-2005 01:56 AM
