Welcome to the North American Subaru Impreza Owners Club Thursday April 9, 2020
Go Back   NASIOC > NASIOC Subaru Models > 'Old School' Subaru Forum
Old 07-04-2019, 02:04 PM   #26
rexmix_svx
Member#: 497727
1995 SVX
oxidized red
So the progress on the car has greatly slowed as my schedule has become busier, but since the last post I have started to weld the trans tunnel into the car as well as the pedal box portion of the firewall. Now the work is less noticeable, small details that add up into a drivable car that doesn't fall apart going down the road. I will try to get more active on nasioc as well as working on the car, I don't want something with potential sitting , unfinished, forever.
rexmix_svx is offline   Reply With Quote
Old 07-05-2019, 12:35 AM   #27
noahp
Member#: 503116
What do you plan on doing with the old H6. Is there modding potential for it at all? Currently scoping out an SVX myself and I'm curious what people have done with that motor as far as power upgrades. Currently I'm considering just flex fuel to start with, but I am not sure whether it responds better to turbo or super charger better.
noahp is offline   Reply With Quote
Old 12-09-2019, 06:12 PM   #28
rexmix_svx
Member#: 497727
1995 SVX
oxidized red
Flex fuel on a naturally aspirated motor will probably not increase the power as much as you'd like as well as you would need an aftermarket ecu to deal with tuning changes. The H6 supposedly can take 5-10lbs of boost before blowing to pieces. That little amount of boost is good for about 400hp I think. If I were you, id look to put a manual behind it, remove all the emissions equipment and related parts(ex: tgv on an ej) and you'd have a sweet running na h6. Otherwise its a new ecu for any major changes like fuel or forced induction.
Old 02-04-2020, 11:29 AM   #29
rexmix_svx
Member#: 497727
1995 SVX
oxidized red
I know its been too long, but more important things took my time away from the build and posting. I have made some progress. lots of custom work to get the wrx/sti parts to play nice with the svx.
I decided to replace the strut mounts to allow any wrx or sti coils to bolt right up.
https://imgur.com/p9jkdnk.jpg
For clearance of the uppipe, I decided to use the wrx front subframe.
https://imgur.com/et9eUaU.jpg
