Welcome to the North American Subaru Impreza Owners Club Friday April 3, 2020
Old 02-17-2020, 10:43 PM   #1
4eat05
Member#: 378421
2005 Cobb Stg2+ Wrx
Platinum Silver
Default Na run hotter than turbo?
Hey guys, something thats been buggin me, do the na ej's typically run hotter than the turbo ej's?
I have a 2005 Wrx turbo ej205 and a 2004 Forester Xs na ej251 (i think) and the Forester runs hotter than the Wrx, but doesnt overheat. No leaks that i can find, coolant is never low. No matter how long or hard I drive, my Wrx coolant temp never goes above 204* before dropping back down according to my scangauge, and my Forester coolant temp never goes above 211* according to the same scan gauge.
Is this normal for the na ej to run hotter than the turbo ej? Its always bugged me and almost worries me that my Forester runs hotter than my Wrx.
4eat05 is offline   Reply With Quote
Old 02-19-2020, 03:06 PM   #2
subaru_gc8
Member#: 29292
2004 WRX wagon
probably has a hotter thermostat to keep the emmision down
Old 02-20-2020, 03:29 PM   #3
Allabaster
Member#: 486361
2017 WRX
Pearl White
It is 7 degrees difference which is around 4% difference which is within the margin that most electronics are built with. While you are using the same tool to test the temperature the gauges are different which could be causing variances as well. Also the radiator size can cause the difference in temperature.
I would not worry about since both vehicles are running within safe operating temperatures.
Allabaster is offline   Reply With Quote
Old 02-20-2020, 06:35 PM   #4
WhiteZombie
Member#: 338863
PSM 05 WRX WGN 5MT
95 Caprice 6spd Track Rat
AND/OR the cooling fans could be programmed to kick on at slightly different temps. Hotter engines run more efficiently and produce less emissions, within reason.
NA motors at normal RPM operating ranges will also likely build coolant temp at a much less rapid pace when compared to a turbo car, especially one that cools the turbo with engine coolant. Basically turbos can build heat much more rapidly and go kaboom in a much shorter time span, whereas you could romp on your Forester for probably twice as long before it increased the coolant temp to the same level as a WRX.
Either way, that's a very negligible difference between two totally different animals, and you're 100% ok.
WhiteZombie is offline   Reply With Quote
Old 02-21-2020, 10:19 PM   #5
speedyHAM
Member#: 48377
1996 Gutted, built
XP class Impreza L
Not just for Subaru engines, but across the industry- NA engines are typically tuned to run a bit hotter than similar turbo engines. While they can do this to increase efficiency, a turbo engine is more likely to experience damaging knock at the onset of positive boost pressure. To lower the significance of that effect turbo engines are tuned to run just a few degrees cooler.
speedyHAM is online now   Reply With Quote
