Welcome to the North American Subaru Impreza Owners Club Monday March 30, 2020
Old 07-19-2011, 07:20 PM   #1
wantinaSTI
Member#: 185578
Default Hood won't open
Cannot get my hood open on my 98 OBS. I had it open earlier today. I pulled the release and go to open as normal and nothing. The cable i think is fine cause there was and is tension on it. I have been having trouble with it closing normally so i've had to let it drop further than normal to get it to stay closed. Did i bend something? I had a friend pull the release while i tried the manipulating the hood latch. Any and all suggestions are greatly appreciated.
wantinaSTI is offline   Reply With Quote
Old 07-21-2011, 10:59 AM   #2
leecea
Member#: 37359
2003 WRX
Sorry, no suggestion on how to get it open but I did have problems with my hood latch sticking. WD-40 solved the problem. Once you do get it open, spray it while moving it through the full range of motion.
leecea is offline   Reply With Quote
Old 07-21-2011, 12:42 PM   #3
eviladam
Member#: 37033
11 wrx
my 02 routinely had problems with the hood latch. it would release, but would get stuck in the release position and not latch closed again. spraying wd-40 or pb blaster on it and moving all the parts would get it working again.
eviladam is offline   Reply With Quote
Old 07-22-2011, 10:59 AM   #4
NY2007Impreza
Member#: 289079
The latch on my '07 Impreza Wagon wouldn't lock this past winter when the temperature was around -5F. I had to open the hood because one of the belts was squealing in the cold and I wanted to see which one. When I tried to close the hood the latch was all frozen and gummed up. WD-40 and a screwdriver to work the latch eventually freed it up. I would spray it out good while working the release and then lube it with some good oil.
NY2007Impreza is offline   Reply With Quote
Old 02-10-2014, 04:30 PM   #5
Just13lazeNW
Member#: 352557
2002 wrx wagon
my hood release is completely jammed. the cable wont move at all. is wd gonna do the trick for that? or am I gonna have to brake my grill out and undo some bolts?? I don't mind that cause I like the no grill look anyways..
Just13lazeNW is offline   Reply With Quote
Old 01-28-2020, 10:09 PM   #6
scmadm
Member#: 511069
Default Stuck hood remedy
I have a 2015 Subaru Impreza. The hood would not open, despite any jiggling, pressing/hitting down on the hood while someone worked the latch. It was really stuck. My solution was getting pliers on the wire near the inside latch and pulling on the cable far enough...and sure enough the hood popped open. The issue was that there was too much slack on the hood cable. It needed to be attached better so it couldn't slide inward when the release was pulled. So...after lubricating the latch liberally, I pulled the cable as far from the engine as I could and used wire ties to hold it there. Now....works like it should.
scmadm is offline   Reply With Quote
Did STI TMIC and Hood swap on my wagon - Now hood won't latch? barryj Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 5 06-08-2008 09:17 PM
My garage won't open.. tora Vancouver Impreza Club Forum -- VIC 9 05-06-2002 12:14 AM
Sunroof won't open, but will close ecfitzgerald Interior & Exterior Modification 3 10-23-2000 05:40 PM
