Welcome to the North American Subaru Impreza Owners Club Sunday May 31, 2020
Old 12-06-2006, 03:26 PM   #51
turboL
Member#: 111735
97 Impreza L
Rust and White
the car is on stands right now. Im draining the coolant and replaceing the thermostat. Hopefully i wont find any oil in the coolant.
turboL is offline   Reply With Quote
Old 12-07-2006, 09:32 AM   #52
kheff46
Member#: 66739
2002 WRX wagon
fingers crossed!
kheff46 is offline   Reply With Quote
Old 12-07-2006, 10:38 AM   #53
turboL
Member#: 111735
97 Impreza L
Rust and White
coolant was dirty but there wasnt any oil separation like you see when oil and coolant mix. Car overheats now. The suttering problem was a lean condition. My RRFPR stopped working i guess. I installed STi injectors last nite and tuned for 15psi, it runs great. AFR's are at around 11.5.
But yeah now it overheats bad, Im wondering if the thermostat isnt opening. There is no white smoke in my exhaust which is why im having trouble believing its the headgaskets
Old 12-07-2006, 02:09 PM   #54
kheff46
Member#: 66739
2002 WRX wagon
do you have another t-stat or diff pressure one to test?
i wonder if theres so little h2o leaking into the cylinder it's being recirculated and not noticed?
did you have a good MAF to turbo tube? thats what the rest of us had.
--keith
Old 12-08-2006, 01:23 AM   #55
turboL
Member#: 111735
97 Impreza L
Rust and White
headgasket blew tonite, figured that was the problem. AAA FTW
Old 12-08-2006, 02:02 AM   #56
turboL
Member#: 111735
97 Impreza L
Rust and White
hhah
Old 12-08-2006, 09:16 AM   #57
kheff46
Member#: 66739
2002 WRX wagon
well the search is over. at least you know WHAT to fix now! what's in store for the shortblock? just new HG's and check your heads and slap it back together?
nice car! mine is same color, just sedanified.
--keith
Old 12-08-2006, 09:47 AM   #58
turboL
Member#: 111735
97 Impreza L
Rust and White
yeah im just gona throw WRX headgaskets in (picked them up 30 mins before it blew) and hope for the best.
Old 12-08-2006, 02:29 PM   #59
kheff46
Member#: 66739
2002 WRX wagon
keep us posted!
Old 12-08-2006, 11:49 PM   #60
turboL
Member#: 111735
97 Impreza L
Rust and White
engine is almost ready to be taken out....didnt want to do it so late at night (11pm), the neighbors wouldnt appreciate it. 7am it comes out.
Old 12-10-2006, 09:46 PM   #61
sense of nature
Member#: 112759
2004 Stock OEM AsFu*
FoZZY SexyRP
Sorry , just curious is this a 2.0 or 2.5 ?
regards
sense of nature is offline   Reply With Quote
Old 12-10-2006, 11:13 PM   #62
turboL
Member#: 111735
97 Impreza L
Rust and White
for me it was a 1.8, lol. im in the wrong forums, dont tell.
Old 04-17-2007, 02:25 AM   #63
2002t-wrex
Member#: 37729
2004 WRX Wagon
I know this thread is a but old but I am having the same problem. Bruce, you have the blue V4 swapped wagon with the STi seats that was done at Planet right? (if so, one of the first times I headed up there your car was on a flat bed, I think part of the harness was damaged by the heat from the downpipe). I have a STi V4 Type R swapped RS and have the exact same problem as you did. I remember Nam and Iain were telling me your car was acting just like mine (after 14psi the boost gauge would just start going nuts and car would stop pulling), 1/2 throttle I could go all the way to redline with no issue at all (around 10psi of boost). Well shortly after that starting happening I went up to Planet to test the MAF and coil from the white V4, while we were testing the different parts my oil pressure dropped near 0 psi and the motor was knocking at anything over 2500rpm. So another $3k later I now have a STi Ver8 block and internals and cometic head gaskets. The major stuttering issue is gone but I still get missfires frequently if I go anything past 1/2 throttle. The plugs are maybe 1 month old. I am going to Planet on thursday to test different plug wires but for some reason I dont think thats the problem. I am also running the stock jdm ecu. I have no idea what is causing it and I really dont want to see another block go down because of it. It is just so frustraiting to have an STi swap that you cant really enjoy because once you hit 14.5psi you are most likely going to be getting more then a few missfires. Really takes the fun away from the car. According to my friends my car shoots fireballs when I shift sometimes (I am also running a very annoying venting BOV that came on the swap), any way that could be related?
For reference, my induction hose is fine and has no holes at all.
Any help or input would be greatly appreciated guys.
Thanks,
-Jason
2002t-wrex is offline   Reply With Quote
Old 04-17-2007, 11:50 AM   #64
linsavy
Member#: 11620
1997 GF4-STiV3 clone
sent you a pm
linsavy is offline   Reply With Quote
Old 04-17-2007, 01:56 PM   #65
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
If you want people to read your posts, try using some paragraph breaks on something that long...
Old 03-28-2020, 11:01 AM   #66
Godislove321
Member#: 475695
Default i know this is a really old post but i have same iissue 02 wrx ej20
[quote=linsavy;16196887]Turns out that the induction pipe into the turbo was borked. All good for now.
Hi,saw this have the exact same issue have new maf, 02 wide band front, plugs coils, no boost leaks, new bpv new vacuum hoses, 2002 wrx ej205. was the inlet the fix for this problem. I have after market cylicone inlet. can't figure it out any help would be appreciated.
Godislove321 is offline   Reply With Quote
Old 04-01-2020, 03:00 PM   #67
contaminatrix
Member#: 435611
2002 SG5-2.0-XT-JDM
45A, originally 18L
[quote=Godislove321;46274848]
try running on wastegate pressure and see if it is stuttering or not.
contaminatrix is offline   Reply With Quote
Leaked all my oil ! Now my motor stutters under boost and wont accelerate ! eMoneyyy Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 04-09-2009 03:24 AM
"creaking" or fluttering noise under high boost/throttle...?? vokalize770 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 04-06-2008 03:38 PM
Clutch slips under high boost gatts Transmission (AT/MT) & Driveline 6 03-19-2007 08:20 PM
Odd sound under high boost RexSex Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 08-03-2005 10:11 PM
Annoying Two Stroke Sound under high boost SpooledRex Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 04-18-2002 09:30 PM
