Welcome to the North American Subaru Impreza Owners Club Saturday June 6, 2020
Old 07-21-2014, 06:03 AM   #2426
vicious_fishes
Member#: 158864
2003 SOHC destroker
Originally Posted by TurboLag23 View Post
Just gonna leave this here; thought it would be of interest...
https://www.youtube.com/watch?v=2A47LYAcakg
it's a good channel for those without a clue but the guys in it don't have a LOT of a clue either :/ i mean all that stuff in THAT car? put it in a GD body or something and it'll at least have resale. and R160 rear end for a drag car? sigh.
11 seconds is not "mad fast". fast & fun sure, but not "mad" fast. mad fast is a flat 10/high 9.
vicious_fishes is offline   Reply With Quote
Old 07-21-2014, 08:25 PM   #2427
TurboLag23
Member#: 347343
2004 Outback H6
2008 Acura TL
Anyone who does a swap like that for resale value missed the point completely. And an 11-second quarter mile on stock internals is nothing to scoff at. And personally, I'd rather swap an H6/6MT into a Legacy any day (more specifically, I'd rather swap a 6MT into my '04 LLOB )
Also, at what point did they say they were using an R160?? They never specified a rear diff... that being said, an R160 is a valid alternative for those who don't want to go with hybrid rear axles or a full hub/brake caliper swap.
Edit: update, it's getting an R180. Surprise. https://www.youtube.com/watch?v=rjeuL_Tk0E8
TurboLag23 is offline   Reply With Quote
Old 07-21-2014, 08:31 PM   #2428
Seraphinwolf
Member#: 150922
97 OBS EZ30R
94SVX LSi Bourduex Pearl
The R160 will hold for a little while but the stock axles won't hold at all!!! All that torque!!! I haven't watched the vid yet but I will once I'm done playing with my son.
Seraphinwolf is offline   Reply With Quote
Old 07-21-2014, 09:13 PM   #2429
vicious_fishes
Member#: 158864
2003 SOHC destroker
they're doing it to demonstrate that you can get fast for cheap (ish). last i checked it's not a car that's going to be kept forever, they've got at least two others. it's not a shop demo car or anything so it's going to be sold on at some point.
they've got a long ratio box, so it's a 3.54 rear end. either they find a 3.54 r180 which is rare as hens teeth, and do the entire conversion with brembo's etc etc, or they go with a straight r160 swap. considering this is supposed to be a "go as fast as you can for as cheap as you can" build, the whole R180 rear conversion seems to be totally counter to the build philosophy.
i'm still super interested however.
Old 07-21-2014, 10:42 PM   #2430
Seraphinwolf
Member#: 150922
97 OBS EZ30R
The trans they were talking about sounds to be 3.9 f/r and the long gear set. Not a longer diff set. Though that's my plan after I get mine to move.
Another thing to note is that they are running e85... Makes a large difference and this is proving a point on what can be pushed out in short time with minimal work. And though they talk reliablely holding up they obviously have no real plans on it doing 11's regularly... It wouldn't hold up.
Old 07-21-2014, 10:55 PM   #2431
vicious_fishes
Member#: 158864
2003 SOHC destroker
like i said, they don't really know what they are doing. still good experiment though.
Old 07-22-2014, 02:55 PM   #2432
Seraphinwolf
Member#: 150922
97 OBS EZ30R
So there is a good question they brought up that I've been avoiding sorting out yet... Oil pick up and return locations... I'm not sure about where they stuck the return. Easy and if it screws up a valve cover is WAY cheaper than other options...
Old 07-22-2014, 07:34 PM   #2433
jdogma
Member#: 242350
2013 Carma Wolf EZ30
black
On the EZ30R, here is where we got turbo oil
return from turbo was nipple welded to oil pan.
jdogma is offline   Reply With Quote
Old 07-22-2014, 07:51 PM   #2434
Seraphinwolf
Member#: 150922
97 OBS EZ30R
Any issues from the cam positioning sensor?
Old 07-22-2014, 09:00 PM   #2435
jdogma
Member#: 242350
black
No issues with the cam position sensor.
Old 07-22-2014, 09:26 PM   #2436
vicious_fishes
Member#: 158864
2003 SOHC destroker
new episode out lads. R180 diff, but it had 3.45 written on it XD
also, see how much they were getting on the guys nerves by the end?
i still need to sort out my oil in from my 30D. i was thinking a (small) "out" from an oil filter sandwich plate (i think turbo's are typically -4AN aren't they?) and then just return into the valve cover like the MCM guys?
Old 07-22-2014, 10:31 PM   #2437
jdogma
Member#: 242350
black
The oil restrictor, if you are using a ball bearing Garrett turbo, is so small that I think a -3 line would be more than enough. The oil flow is so low that cam cover return will probably be fine.
Old 07-22-2014, 10:34 PM   #2438
jdogma
Member#: 242350
black
The thing with the wiring connector close to where I am getting oil is the VVL solenoid.
Old 07-22-2014, 11:09 PM   #2439
phil.greiner11
Member#: 388081
2004 H6 STI
I just used a sandwich plate for feed and welded a bung on the oil pan for return. So far so good have about 500 miles on it.
phil.greiner11 is offline   Reply With Quote
Old 07-23-2014, 10:27 PM   #2440
vicious_fishes
Member#: 158864
2003 SOHC destroker
ep 3 is out. tech finally snapped it with him in a perfect passive aggressive maneuver. amazed it took him that long. that guy is seriously annoying.
Old 07-24-2014, 09:45 AM   #2441
Seraphinwolf
Member#: 150922
97 OBS EZ30R
He's not that bad... The tall one is annoying as ****!
Episode 4 actually released too... Welding is actually started finally! I don't like running the header under the PS rack like they did though...
Old 07-24-2014, 10:40 AM   #2442
vicious_fishes
Member#: 158864
2003 SOHC destroker
could've just bought these:
http://www.raptorsc.com.au/subaru6.html
Old 07-24-2014, 11:08 AM   #2443
Seraphinwolf
Member#: 150922
97 OBS EZ30R
They have access to everything... Why wouldn't they make their own...
Old 07-24-2014, 12:22 PM   #2444
vicious_fishes
Member#: 158864
2003 SOHC destroker
time/money?
the raptor ones are a much better collector too.
Old 07-24-2014, 01:37 PM   #2445
Seraphinwolf
Member#: 150922
97 OBS EZ30R
They are doing a massively budget centered build. Plus gains between the designs would be negligible.
Old 07-24-2014, 04:01 PM   #2446
vicious_fishes
Member#: 158864
2003 SOHC destroker
the collector is hopeless. it's on a full 90 degrees to the final flow direction with no transition.
the tech's also spent all day on it so 8x110=$880 + materials.
Old 07-25-2014, 01:08 AM   #2447
phil.greiner11
Member#: 388081
2004 H6 STI
you guys have any idea how much boost the stock internals can hold on the ez30d. I was told by cardoc's tuner that it could hold 12psi. im turning up the boost on monday so i want to know if im gonna blow up or not. ha
Old 07-25-2014, 02:09 AM   #2448
vicious_fishes
Member#: 158864
2003 SOHC destroker
psi isn't psi phil. about 350whp is the reliable limit without cracking it open (you'll snap a rod).
ep 5 is out. gtx3576 turbo. intredasting. 40 minute ep too.
5-30 castrol edge... oh dear.
Old 07-25-2014, 05:41 AM   #2449
Seraphinwolf
Member#: 150922
97 OBS EZ30R
Yeah PSI is just a reference of what's going on. 20 PSI on, let's pick two mostly similar turbos application and fitment wise, a VF48 and a VF52 are NOT the same. All in all those two turbos fit pretty close, spool pretty close, and even go on mostly the same engine, but it's all about the volume of air they produce per unit of time. You can push a TD04 to make, what's max, 19PSI, but that's just how compressed the small volume of air that's being push through it is.
Anywho. The Perrin car snapped a rod in their 3.0R at 14 PSI on their GT28R turbo AND they had done the SuperTech pistons to drop the compression to 8.5:1. The stock compression of the 30D or 30R is gonna be too high to go crazy on. I wouldn't trust those rods to hold at 350whp. You should be a lot safer on the 30D from the 30R since the R is like 11-11.5:1ish and the D is 9.7-10:1ish
Old 07-25-2014, 06:23 AM   #2450
Seraphinwolf
Member#: 150922
97 OBS EZ30R
Oh yeah and HP doesn't break stuff. TORQUE BREAKS ALL THE THINGS!!!!
Vag-Com cable resource thread cooleys04 Open Source Reflashes 283 04-03-2018 01:04 PM
The Impreza @$$ Thread - The Beautiful Impreza Backside! PICS! Upscale_Automotive Member's Car Gallery 8 10-03-2007 04:56 AM
The 2008 Impreza Photoshop thread...post them here adizon Member's Car Gallery 307 09-19-2007 11:36 PM
The 2006 Impreza/Impreza WRX/Impreza WRX-STi thread (merged thread) wrxpeed News & Rumors 938 05-16-2005 11:11 PM
Photo - Anders "loving on" the H6 Impreza Fred South East Region Forum 8 02-23-2004 05:04 PM
