Welcome to the North American Subaru Impreza Owners Club Tuesday June 2, 2020
Go Back   NASIOC > NASIOC Classifieds > Vendor Announcements
Old 11-23-2014, 01:20 PM   #26
BtSsm
Vendor Sales Rating: (0)
Member#: 400888
Here's a quick video capture of BtSsm running on an Android phone for those who are wondering what it looks like in action
__________________
[SIGPIC][/SIGPIC][B]
[/B] - Android app/Bluetooth adapter. LV, logging, gauges, and more! For 02-14 WRX, 04-14 STi, 05-14 Legacy (GT, 2.5, 3.0, 3.6), 04-14 FXT, 05-09 OBXT
BtSsm is offline   Reply With Quote
Old 11-28-2014, 07:44 PM   #27
BtSsm
Member#: 400888
For the hardcore nerds out there, here's a preview of a new feature that will be included in the next update in the coming days. If desired, you can add your own custom fields. This assumes that you know the address defined in the ECU that represents what you want, as well as the length in bytes, the formula to use to display the data, etc.
__________________
Old 11-28-2014, 08:59 PM   #28
hekler
Member#: 388366
2016 SUBARU WRX(cvt)
CBS w/eyesight
Originally Posted by Perscitus View Post
Please PM or post when support is added (unless already there) for 2010+ Legacy/Liberty/Outback and 2015 WRX. Thanks.
2015 wrx here.....bring it!!
hekler is offline   Reply With Quote
Old 12-01-2014, 01:04 PM   #29
BtSsm
Member#: 400888
An update has just been published to Google Play, and should be available within a couple of hours. It includes:
  • new feature: CUSTOM FIELDS can be added
  • new field: "closed loop", 0=open loop, 1=closed loop (fibble)
  • enhancement: deleting a log now asks for confirmation (magnusonsubie)
__________________
Old 12-19-2014, 12:04 PM   #30
djpast
Member Sales Rating: (6)
Member#: 31016
2016 Focus RS (blue)
2005 WRX Wagon (white)
How is the sample rate with the 02-05 16bit ECUs?
djpast is online now   Reply With Quote
Old 12-19-2014, 12:54 PM   #31
BtSsm
Member#: 400888
I just chose 10 fields, and sampling rate averaged 74ms (about 13 samples per second). It depends on how many fields are chosen though. Less fields=faster, more fields=slower
Please let me know if you have any other questions
__________________
Old 12-19-2014, 01:40 PM   #32
djpast
Member#: 31016
How about lag from realtime? Is it pretty instant? Coming from OBDII BT adapter with Torque running at ISO9141-2-5-BAUD, so the lag is pretty terrible on that, which limits me to displaying only parameters that are slow changing (voltage, temps, fuel trims, etc). Logging was pretty much out of the question unless I hooked up the Tactrix and my laptop, so I am pretty excited about this.
Old 12-19-2014, 02:15 PM   #33
BtSsm
Member#: 400888
There's no noticeable lag See post #11 above for a sample log file from the app. It logs as fast as the ECU sends it out via SSM protocol (much faster than generic OBD via an ELM327 device like you mentioned)
It's really fun to watch the gauges on the BtSsm app as you goose the throttle. The boost gauge on the app is actually more responsive than my mechanical (albeit stepper motor) gauge!
__________________
Old 12-19-2014, 02:35 PM   #34
djpast
Member#: 31016
Last question, I promise. Any plans in the near future to bundle the software with dongle?
Old 12-19-2014, 03:14 PM   #35
BtSsm
Member#: 400888
No problem, ask away Regarding bundling, since google play (where you need to purchase the BtSsm app from your device) is a separate entity, I'm not sure how it could be bundled with the physical adapter. But all suggestions are welcome.
__________________
Old 12-19-2014, 05:10 PM   #36
djpast
Member#: 31016
Buy adapter bundle, include a $10 play gift card? Just a thought, though I could see that being a pain.
https://play.google.com/intl/en-US_us/about/giftcards/
Old 12-19-2014, 06:26 PM   #37
BtSsm
Member#: 400888
wasn't aware of those
__________________
Old 12-20-2014, 06:33 AM   #38
BtSsm
Member#: 400888
An update to BtSsm has just been published to google play:
  • now optionally supports wired ecu connection (pyro, fibble)
    • wiring: android device->*usb/otg adapter->*kkl cable->obd port (*=additional hardware reqd)
    • to enable, go to Settings/ECU interface, select as appropriate
  • LV images are now retained in a list for review like logs (xt2005bonbon)
  • added multiselect to logs dialog for delete/share (fibble)
  • also added multiselect to new LV list
  • bug fix for new android version 5.0.1 (xt2005bonbon)
__________________
Old 12-20-2014, 11:07 AM   #39
Layvon
Member Sales Rating: (146)
Member#: 195711
PART OUT. PM ME
02-07 Goodies
I don't have a use for this but man if I was open sourcing... Thus would be great
Layvon
Layvon is offline   Reply With Quote
Old 12-21-2014, 09:44 PM   #40
BtSsm
Member#: 400888
Another update just published... A bug was fixed for certain devices using android 5.0.1
Also included is a new feature to allow custom ecu firmware in some cases. Before the app would just say "Unsupported ECU found. ID=xxxx" and close. The new feature offers a new button "Create Alias" that, if clicked, will ask you to "Enter original ECU ID for alias". Entering that will use that ECU ID instead going forward. Note that this only works if the custom ecu firmware has all the same address mapping as the original firmware.
__________________
Old 12-26-2014, 04:48 PM   #41
BtSsm
Member#: 400888
Published a small update to google play:
  • added a hands-free feature if touch screen not avail: key-on, engine-off, floor throttle for LV. Floor again to close
  • attempt to handle OTG cable made by winchiphead
__________________
Old 12-28-2014, 12:33 PM   #42
redheat86
Member Sales Rating: (3)
Member#: 54479
2006 STizzlllee
black
Can this read TCU/DCCD parameters?
Individual Wheel speeds,
Yaw rate etc..
redheat86 is offline   Reply With Quote
Old 12-28-2014, 12:44 PM   #43
BtSsm
Member#: 400888
Yaw rate etc..
Currently, it cannot. It only reads the ECU.
__________________
Old 01-07-2015, 01:44 PM   #44
BtSsm
Member#: 400888
FYI - an update to BtSsm has just been published to google play to add support for usb/otg connection with newer KKL cables having a CH340 chipset
__________________
Old 01-07-2015, 01:52 PM   #45
djpast
Member#: 31016
Does your app support Multi-Window for Samsung devices?
http://forum.xda-developers.com/show....php?t=2024399
Seems like a pretty easy feature to add, just a line added.
Are there any parameters that cannot be viewed via your product vs the full laptop w/ Tactrix?
Old 01-07-2015, 02:00 PM   #46
BtSsm
Member#: 400888
Advanced questions!
Currently, it does not support multi-window for samsung devices. It takes over the whole screen. However, I'll have a look at that
As-is, the app has a subset of fields that I believe are the most commonly used. So there are a lot of other fields that are not included. This being said, there is now support to add your own custom fields for power-users such as yourself if you can supply the field definition (address, length, format, etc)
__________________
Old 01-07-2015, 02:31 PM   #47
djpast
Member#: 31016
Advanced questions!
You would be surprised on how well multi-window works to re-size applications.
I would be running your app on my Samsung tablet or my Note 3. On the note, it may be a bit smooshed, but you would likely be able to have a couple parameters up while having Waze or Google Maps up.
On my tablet, I would run it in landscape, like I am currently doing with Torque.
http://i.imgur.com/0Bb57tF.png
You can see that Maps loads up fine (search bar is slightly cut off), but basically looks like how it does in portrait mode on a phone. I would be more than happy to test this with you if you decide to implement this.
Old 01-07-2015, 03:28 PM   #48
BtSsm
Member#: 400888
wow, you were right, that was easy It'll be included in the next update (probably within a week)
Sorry for the small phone-based screenshot, but it demonstrates the feature at least.
__________________
Old 01-08-2015, 10:04 AM   #49
BtSsm
Member#: 400888
btw, if that's your current setup with an elm327 adapter, I think you'll really like the responsiveness of the BtSsm gauges and values (about 10 to 25 refreshes per second, depending on how many fields are selected)
__________________
Old 01-08-2015, 12:02 PM   #50
djpast
Member#: 31016
Yeah, that was a lot of my reasoning for asking the questions above. I can really only use Torque for monitoring things that are not "real-time" critical.
I see the different styles you have of gauges (LGT/STi). Any plans to do a green gauge style theme?
