Welcome to the North American Subaru Impreza Owners Club Friday June 5, 2020
Old 11-01-2002, 12:35 AM   #1
go go go
Member#: 2784
Default New Impreza details
Images are linked from from impreza-net
http://www.impreza.gr.jp/masa/subaru.../peage001.html
The bottom right STi has all the factory optional items loaded including the BBS rims.
changes on WRX STi:
aside from obvious exterior and interior changes,
Engine has been modified extensively.
This is the exhaust manifold. It is equal length and note that it is 4-2 not 4-2-1. The turbo is bigger and it is "twin scroll turbo" The exhaust comes in from two pipes.
Internal is stronger and the TGV has been eliminated from the intake manifold.
This is my favorite pic
can't see the front!!
DCCD is optional on STi and standard on Spec-C
DCCD has auto mode this time.
Regular WRX gets smaller turbo for faster spool up.
The car is actually faster in 0-62mph by 0.5 sec. (about 6.5sec.)
It's got inverted shocks
front 4pot/rear 2pot combo
and 17 inch Euro WRX/NB-R/ex-B4 wheel
go go go is offline   Reply With Quote
Old 11-01-2002, 12:43 AM   #2
Raxy
Member#: 8220
Default Re: New Impreza details
Thanks for the cool details!
BTW, since its the JDM model, is the redline still at 8000 RPMs? I can't tell from the picture.
Raxy is offline   Reply With Quote
Old 11-01-2002, 12:55 AM   #3
LinuxGuy
Member#: 17270
1998 Fender Bender
Holds 1000lbs.
not to offend anybody, but I just cant buy that front end, i am bug eyes forever!
LinuxGuy is offline   Reply With Quote
Old 11-01-2002, 12:59 AM   #4
go go go
Member#: 2784
looks like redline 8K
this meter is cool BTW. It is black faced meter and when the lights are off, it's completely black
Old 11-01-2002, 01:12 AM   #5
shirokuma
Member#: 5489
2013 FR-S
AVO Orange
All I can say right now is the differences in the engine department are nigh unbelieveable. That alone was fantastic -what happened with the suspension setup verges on pure magic.
The change to the new WRX/STi is not cosmetic - in many ways, this is a completely new car. STi called it a "level up". It's not. It's about 3 levels up.
Cheers,
Paul Hansen
shirokuma is offline   Reply With Quote
Old 11-01-2002, 01:13 AM   #6
Raxy
Member#: 8220
Another good source for details on the New Impreza, specifically what's available in each model:
http://www.japanvehicles.com/newcars...model/main.htm
Old 11-01-2002, 01:56 AM   #7
PPower
Member#: 22146
2012 Acura TSX wagon
Thanks for the info, guys. Too bad japancars.com doesn't have info for the WRX wagon. Also, I noticed that leather is not listed as an option for some reason. I'm getting it, and I know that I've seen it written in other places. Too bad I didn't know about the HID option though. Hooray for aftermarket!
PPower is offline   Reply With Quote
Old 11-01-2002, 02:16 AM   #8
go go go
Member#: 2784
HID has never been a standard item on Impreza in Japan. It is $2000 option. Also I have never seen Impreza with leather seats in Japan. There is Recaro bucket seat available from STi but not leather.
Old 11-01-2002, 03:58 AM   #9
bemani
Member#: 5673
05 LGT, 02 bug eye
16 Hellcat, 19 CTR
Damn, that's a lot of changes (even the wiper!). But even if you don't read Japanese, all you need to know is this
(blue is old car, red is new)
bemani is offline   Reply With Quote
Old 11-01-2002, 08:33 AM   #10
robmarch
Member#: 18713
06 CRV
04 STi
wonder if all of these upgrades to the regular WRX will make it here?
robmarch is offline   Reply With Quote
Old 11-01-2002, 09:22 AM   #11
beachbum
Member#: 457
---- Smells like
weed and rampage
That can't be right... It says the WRX wagon comes with a 6-speed?? That'd be great if so, though!
Edit: Nevermind, need to read the whole page before posting.
beachbum is offline   Reply With Quote
Old 11-01-2002, 10:20 AM   #12
Cefiro26
Member#: 25287
1998 Impreza Outback
Blak/beige
The best new feature on STi to me is this
"When you turn on the ignition, the STi logo comes up and Tachometer revs up to its maximum rapidly and comes down" (according to Subaru release)
Some entertainment, huh?
"T"
Cefiro26 is offline   Reply With Quote
Old 11-01-2002, 10:24 AM   #13
Jon [in CT]
Member#: 2992
02 WRX Sedan
This is big news. Subaru, until now, has always used a constant-pressure type turbocharger. In constant-pressure turbocharging, Subaru uses a relatively large volume uppipe to damp out the mass flow and pressure pulses so that the flow to the turbine is essentially steady. It appears the turbocharger used on the new STi is a pulse type turbocharger, which is specially designed so that much of the kinetic energy associated with the exhaust blowdown can be utilized. Relatively small volume header pipes are used. The small cross section maintains the desired high gas velocity and concomitant kinetic energy to the turbine inlet. If all four cylinders fed into a single pipe, the separation between the pulses (180 crank-angle-degrees) would be too tight and they would interfere with each other. To solve that, the four cylinders feed into two pipes and the turbocharger has a divided turbine inlet with the division maintained throughout the turbine housing all the way to the end of the nozzle section. This keeps the cylinder exhaust events within each half of the divided housing spaced apart 360 crank-angle-degrees. The net benefit of pulse turbocharging is faster spool up and a steeper boost curve. Pulse turbocharging is rarely seen in gasoline powered cars but I do know that the Mitsubishi Lancer rally car uses one.
Jon [in CT] is offline   Reply With Quote
Old 11-01-2002, 10:36 AM   #14
Cefiro26
Member#: 25287
Blak/beige
According to the Subaru release, STi now have 40.2kg m Torque...that means 290.8lb ft (if my conversion is right...). That's a lot of Torque, isn't it?
Also, it is first time in Subaru history, STi now have Electronically controlled AWD on stick shift model (6MT) (Driver's controlled Center diff with "AutoMode") .
"T"
Old 11-01-2002, 10:56 AM   #15
kage
Member#: 25101
Chapter/Region: HIIC
2002 PSM WRX Wagon
1999 Twilight Blue Miata
Are these numbers for the STi or for the regular WRX?
kage is offline   Reply With Quote
Old 11-01-2002, 11:04 AM   #16
robmarch
Member#: 18713
06 CRV
04 STi
"T"
Is this just the gauges moving, or the computer redlining the engine upon startup? Either way, I could do without.
Old 11-01-2002, 11:20 AM   #17
Fido
Member#: 1867
Yummy
Fido is offline   Reply With Quote
Old 11-01-2002, 12:15 PM   #18
NeoGeo
Member#: 3776
Take a wild guess
That instrument cluster is WAY WAY cool!! If you open up your own WRX instrument panel, you'll see the trademark NS, which stands for NipponSeike. What does NS make? Defi gauges. And anyone w/Defi gauges will tell you that when you start the car up, the needles do an automatic full sweep for system check. Also Defi has that black out gauges that some vendors here are selling. So apparently they made it to the OEM line. Very cool. (so no, the engine itself isn't revving, just the gauge self check).
I wonder if the new header/pulsating turbo system can be used on our cars?
Looks like STi is really going after the evos this time
NeoGeo is offline   Reply With Quote
Old 11-01-2002, 12:41 PM   #19
PPower
Member#: 22146
I hope that I'm not sick that I didn't wait for an STi. As for the gauge cluster, I wonder how visible those are in the daylight. Anybody with experience using the black out dephi gauges?
Old 11-01-2002, 01:09 PM   #20
kage
Member#: 25101
2002 PSM WRX Wagon
The "black out" gauges are similar to Optitron gauges, which have been offered in Japan and Europe in various brands for a couple years now. They are basically back lit behind the numbers, rather than lit from in front. The numbers and markers are nearly transparent, and thus can't be seen with no power. But when the power is on, it's brighter than normal gauges.
290 lb ft of torque. Wowee zowee!
Old 11-01-2002, 01:54 PM   #21
bemani
Member#: 5673
05 LGT, 02 bug eye
16 Hellcat, 19 CTR
Blah. All that lit-up gauge crap is just wasting precious engine power
Old 11-01-2002, 02:39 PM   #22
Jewbaru
Member#: 1994
2018 STI
DCCD, is that the adjustable center diff?
[Edit] Yup, translated.
Jewbaru is offline   Reply With Quote
Old 11-01-2002, 03:35 PM   #23
CloNeGTS
Member#: 23341
04 Rex STi
WRB/Gold
What in the world is a Handstand Dumper???? It's available on the WRX and standard on the STi.
CloNeGTS is offline   Reply With Quote
Old 11-01-2002, 03:40 PM   #24
alfredob1
Member#: 23850
Something was probably lost in the translation.
alfredob1 is offline   Reply With Quote
Old 11-01-2002, 03:44 PM   #25
TuxedoCartman
Member#: 23054
2003 Subaru
WRX Sedan
AHHHH!!!!! I CAN'T TAKE THE SPECULATION ANYMORE!!!!! I WANT ONE, WANT IT NOW!!! gimme, gimme, gimme, gimme....
<whew> Sorry, but damn that looks great! I knew there were a lot of differences other than just hp, but I never realized there were that many!
Now I'm going to have to reconsider whether or not I'm getting one.
TuxedoCartman is offline   Reply With Quote
Australian imporeza page updated!! impreza details lostprophet86 General Community 1 09-01-2007 03:19 PM
For those who don't leave the NWIC forum....New legacy details have been released! sovereignmk1 North West Impreza Club Forum -- NWIC 12 01-06-2004 03:37 PM
New Legacy details username News & Rumors 1643 01-06-2004 02:53 AM
Check out Some new Legacy details here sovereignmk1 Legacy Forum 5 01-06-2004 02:25 AM
Impreza Detail Diagrams/Manual STi-Nismo Dood Newbies & FAQs 1 02-14-2001 04:31 PM
