Welcome to the North American Subaru Impreza Owners Club Tuesday March 26, 2019
Old 02-20-2019, 08:47 PM   #26
PDXREALTOR
Member#: 468393
2017 STI
Originally Posted by Scuby04STi View Post
If the SB has miles and you aren't touching those internals that makes sense.
What I am missing is the value in a leak down test before you have the rings properly seated? (OP)
If you don't know what you start with and end up with numbers that leave questions, knowing what you started with could potentially help rule out some otherwise unknowns.
PDXREALTOR is offline   Reply With Quote
Old 02-20-2019, 08:51 PM   #27
PDXREALTOR
Member#: 468393
2017 STI
Originally Posted by Homemade WRX View Post
Ignoring their chart, where the rates aren't the same, you have 6.67% on 75 psi and 8.00% on 100 psi.
I'm no math expert but I get 8.33% as the difference between 75 and 69
Old 02-20-2019, 09:30 PM   #28
Homemade WRX
Member#: 33782
96 in the garage
search FIRST, then PM!!!
Looks like 75/70 to me.
Old 02-20-2019, 09:32 PM   #29
PDXREALTOR
Member#: 468393
2017 STI
It's very close. It's amazing how the camera can mess with the needle and the marks. I took multiple pics several times because it would appear to be 1 or 2 marks off from actual.
Old 03-09-2019, 09:34 PM   #30
PDXREALTOR
Member#: 468393
2017 STI
Delete.... Delete
