Welcome to the North American Subaru Impreza Owners Club Thursday July 18, 2019
Old 10-07-2018, 04:21 PM   #1
2slofouru
Member#: 90539
My BOV goes
COVFEFE!
Default One off zinc plating, any shops that do it?
Sorry if it's the wrong forum, just trying to find a place to zinc and chromate a part or two. My fuel hanger is getting modified and I want it to be as good or better at resisting corrosion than the oem coating, especially since I will be running high ethanol fuels. It's one of my daily vehicles and I am wanting it to be one of the parts I don't have to worry about.
I'm not trying to start an argument or discussion on the validity of the subject, just trying to find a place to do the work.
There are so many companies to plate and coat metals, but most of them do work on an industrial scale. Their sites are not set up for consumer level inquiries and I've already wasted time asking a few.
If you know of a company who will accept work from consumers with a low quantity order, down to one piece, please let me know. If I can't find a legitimate company to do the job, I will build my own zinc plating setup. Was trying to avoid doing it for one or two pieces though.
Thanks for reading and for any help.
Old 10-07-2018, 10:43 PM   #2
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Silver Sleeper BK, 5MT
Not sure if the catalog is still around, but for a lot of industrial stuff, I used to use Thomas Register, sorta a yellow pages for industrial supplies and related companies.
Maybe look online and see what they show locally to you and/or anywhere?
They had a US catalog as well as regional versions.
Old 10-08-2018, 09:37 AM   #3
rtv900
Member#: 428511
2016 STI
there's no doubt little platers that do small jobs
For one piece you'll end up paying a minimum charge of $80-100 bucks, but it's that or get set up yourself.
I don't live near you but I use several platers that would do that for sure.
That can be tough to find online because places like that don't typically get work from the general public, but if you have local machine shops somebody there will know of platers.
rtv900 is online now   Reply With Quote
Old 10-08-2018, 01:36 PM   #4
Wayne Suhrbier
Member#: 144044
2006 STI
The online version is thomasnet
Wayne Suhrbier is offline   Reply With Quote
Old 10-08-2018, 08:54 PM   #5
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Thanks. Been 15 years or so since I used it, I have a regional print copy from....welllll......likely 25 years ago. I haven't been in facilities for quite a while, but still use some of my old suppliers.
Old 10-09-2018, 06:14 AM   #6
rtv900
Member#: 428511
2016 STI
It's been well over 15 years since anyone has used it, thomas register or thomas net.
Old 10-09-2018, 01:11 PM   #7
[email protected]
Member#: 67
1999 Outlasting
the competition.
https://www.eastwood.com/ have anything?
We do electroless nickel on our shifters. minimum is around 100 bucks if i remember right.
tom@kartboy is offline   Reply With Quote
Old 03-19-2019, 10:38 PM   #8
Betarambo
Member#: 277872
I found some DIY setups online for zinc plating rusty gas tanks. I was shocked how easy it was. Some washing soda, some plated chain and a battery charger and I was in business.
Betarambo is offline   Reply With Quote
Old 03-19-2019, 11:04 PM   #9
2slofouru
Member#: 90539
My BOV goes
COVFEFE!
I have supplies for plating and for chromate dip, just haven't had the motivation or time yet. Hopefully it's worth the effort, especially since I decided to run a surge tank, which makes the AN fitting mods to the fuel hanger not especially helpful at this stage.
Old 06-12-2019, 10:23 PM   #10
Ferretts
Member#: 416087
2015 WRX
WR Blue
Manco plating in newark nj does yellow and black zinc plating... Yellow zinc is best for corrosion resistance.
Ferretts is offline   Reply With Quote
Old 06-13-2019, 08:23 PM   #11
2slofouru
Member#: 90539
My BOV goes
COVFEFE!
I found a place in Houston that does electro-less plating and they did it in nickel. The plate goes inside every surface, so no chance of corrosion. Electroplating can't get inside all of the tubes and fittings, so this ended up being my choice. Thanks for the suggestions.
