Welcome to the North American Subaru Impreza Owners Club Saturday April 21, 2018
Old 11-10-2016, 09:36 AM   #801
Clutch Dumper
Member#: 453719
2012 WRX Limited
Dark Gray
No, but I really wish I did. I'm curious myself
Clutch Dumper is offline   Reply With Quote
Old 11-13-2016, 12:47 AM   #802
WelDun1
Member#: 249130
1999 Ver5 STi RA
Car: 99 STI RA
Facility: Horizontal Motorsports
Type of Dyno: Mustang
Boost: 28PSI
Fuel: E85
Target AFR: 11.2
Peak HP @RPM: 396.6 @5920 81mph
Peak TQ @RPM: 388.1 @4728 64mph
Mods:
EJ257 block 9:1 CR
Manley Pistons
Manley Rods
King Bearings
ARP2000 Studs
EJ207 Ver5 RA Heads
BC 272 Cams
BC Ti Valve Springs
BC Retainers
JDM Ver5/6 RA 5MT w/ DCCD
Stage3 CC Clutch
Rotated GTX3071r
TiAl .82ar
Doc Race FMIC
TiAl 50mm BOV
TiAl 44mm EWG
TurboSmart Manual Boost Controler
Open Dump
Custom Rotated Up Pipe
Custom 3" Down Pipe
Custom 3" Mid Pipe
Perrin Catback
IAG AOS
Killer B Pickup & Baffle
Five-O 1200cc Side Feed
Hardwired High Pressure Walbro 450
Radium FPR
WelDun1 is offline   Reply With Quote
Old 11-29-2016, 09:37 PM   #803
WeakSauce2.5i
Member#: 150006
2016 WRX Protuned
2004 WRX
2016 WRX
Phatbotti Tuning, Anaheim, CA
Mustang
~21 tapers to about 11-13
91 octane
311 whp / 334 wtq
Redline "baseline" 280 whp / 310 wtq:
PRL TGVD
GS Catted J Pipe
Invidia Q300 CBE
Cobb AP
Greenline (modifications added/changed):
GS TMIC w/splitter
GS Chargepipe
GS EBCS
GS Intake
Tomei Expreme Ti CBE
WeakSauce2.5i is offline   Reply With Quote
Old 11-29-2016, 11:03 PM   #804
zerowreckoning
Member#: 458961
2004 Impreza WRX/STI
Exclamation
2004 WRX
Facility: Ken Black Motorsports
Type of Dyno: Virtual Dyno Jet
Boost: 23 peak
Fuel: E85
Target AFR:11.5
Peak HP at RPM: [email protected]
Peak Torque at RPM: [email protected]
Mods:VF39, unkown brand FMIC, Tial BOV 11psi spring, 1000cc deastch werks injectors, walboro 255 fuel pump, Mishimoto turbo coolant expansion tank, koyo single core radiator, 05 STi; 6speed trans, rear diff, drive shaft, rear axles, front axles, front hubs, rear hubs, brembos all around, torque solutions solid motor mounts, torque solutions solid pitch stop mount, unorthadox racing p/s, alternator, and crank pulleys.
zerowreckoning is offline   Reply With Quote
Old 12-08-2016, 01:07 AM   #805
barakgt
Member#: 459382
closed deck block
manley pistons
manley turbo tuff rods
sti crank
acl racing bearings
crower stage 2 camshafts
manley valves
crower springs valves
adjustable vernier pulley X4
blouch dominator 3 xtr
cosworth intake manifold
injector dynamics 1340CC
2X AEM fuel pumps
Fuelab e85 fuel filter
Perrin fuel rails
sti in heads coils
aem 5 bar map senso
nirosta custom build turbo intake
big K&N air filter
front xs power intercooler
cusco oil catch can
defi turbo pressure gauge
defi egt gauge
aem wideband gauge
new trust greddy boost controller
tomei equal length headers
tial external wastegate
aem water / methanol injection
haltech sport 1000 ecu
3 exhausts system
Version 5 Temperedgear box, 5 speeds
Act ceramic stage 5 clutch
Act flywheel
Front brakes k sport 6 pistons + ceramics Brake pads
D1 coilovers
Toyo r1r 215/45/17
Super leggera 17 wheels
Morrete headlights
22b tail lights
All Polyurethane
sorry for my English
after a year of building the car for daily / weekend races we done and happy with the results
fully build close deck engine with stock location blouch dom 3 xtr 10cm
if you guys want full car specs / videos of the dyno just ask...
be aware the results is from very low reading mustang dyno, from some reason reading is lower then other mustang dyno we have here...
the result Achieved with e85 fuel and 30~ psi of boost.
barakgt is offline   Reply With Quote
Old 12-26-2016, 10:25 PM   #806
ZerolFaithl
Member#: 448133
2016 WRX Base
Grey
Good numbers for another charlotte local congrats!
Originally Posted by Senior Tortuga View Post
5/4/16 - additional mods and retune:
-TGV
-EGR
Mishimoto TMIC
Mishimoto Charge Pipe
Opened up OEM mufflers (search my other posts for details)
Cleaned dirty intake valves
311.4 WHP
305 Ft-lbs at the wheel
ZerolFaithl is offline   Reply With Quote
Old 02-03-2017, 12:33 PM   #807
The_STI_Killer
Member#: 462345
2004 WRX
Black Gold Flake
Those are nice numbers you guys!
The_STI_Killer is offline   Reply With Quote
Old 02-09-2017, 07:08 PM   #808
GumbyGhost
Member#: 462104
2005 STi
Car: 2005 STi
Facility: Moore Automotive
Facility Website: www.mooreautomotive.com
Type of Dyno: Dynojet
Boost: ~19 PSI
Fuel: 93 Octane
SAE Corrections: Unknown
Peak HP at RPM: 356.51 @ 5440
Peak Torque at RPM: 386.66 @ 4230
Mods:
Crawford Performance: S2 Motor and CP32 Turbo Kit (circa 2004)
STi shortblock with forged pistons and STi crankshaft
APS Cold Air Intake, 3-inch turbo back exhaust, FMIC
COBB 3-Port EBC and AP v3
Samco Intake Hose
Walbro 255Lph high volume Fuel Pump
Unknown upgraded side-feed injectors
GumbyGhost is offline   Reply With Quote
Old 02-10-2017, 11:18 PM   #809
drivingkingwrx
Member#: 76958
Default 2003 Wrx
Car: USDM 2003 2.0 WRX 5 Speed
Facility: R/T Tuning
Type of Dyno: AWD Mustang Dyno
Boost: 18 psi
Fuel: 93 oct.
Target AFR: ?
SAE Corrections: None (Within dyno room all air pressure, humidity and air temperature are put in each run to avoid correction)
Peak HP at RPM: 309.3whp @ 6,200rpm
Peak Torque at RPM: 291.4wtq @ 4,600rpm
Mods:
VF48 Turbo
HKS Up pipe
Injen Downpipe
HKS Turbo Back Exhaust
Perrin Crank Pulley
AEM Short Ram Intake
Cobb EBCS
Spearco TMIC
560cc "blue" injectors
CP Pistons 92mm
Mahle Rods H-beam rods
Cometic Gasket kit
ACL Bearing
New Crank
Open Source Tune
drivingkingwrx is offline   Reply With Quote
Old 02-19-2017, 07:13 AM   #810
Toxicperformance
Member#: 463218
2007 Wrx Sti RB320
Facility:Toxicperformance
Type of Dynoynojet
Baseline # for a stocker at the dyno:230awhp
Boost:30psi taper to 27
Fuel: pump gas shell v power
Target AFR:11.8
SAE Corrections:
Peak HP at RPM: 487awhp
Peak Torque at RPM: 60nm
Mods: Stock Engine Ej257
Parts List:
TMIC Grimspeed
EFR7163 turbo kit Toxicperformance
KILLER B TURBO MANI
SPEC C INTAKE MANIFOLD
ID1000cc injectors
Intank AEM 320 fuel pump
SARD FUEL RAILS
TIAL 44 wastegate
3.5 inch Dp and exhaust
Os Giken Twin disk clutch
Dyno Dynamics also with less boost
Toxicperformance is offline   Reply With Quote
Old 02-25-2017, 03:50 AM   #811
meowy.wowy
Member#: 396381
2011 hatch back
Tune Elevation 5870ft (Parker, Colorado) tuned at macautosports built by 5250 performance.
-Rotated, flex fuel, top mount intercooler setup-
...IAG 2.5 tuff closed deck w/ upgraded wrist pins, +625 head studs, cosworth HG, 11mm oil pump
...Gsc s2 cams, beehive springs, ferrea valves, Supertech guides
...Perrin equal length headers
...Killer B oil pan, baffle, pickup
...Killer B high flow water pump housing
...Garrett Gtx3076 tial .63
...Tial 38mm, 16pound spring
...Grimmspeed TMIC w/ thermal coating and y-pipe
... NGK 2309 (1 step colder) .023 gapped
...Tigwerks rotated kit
...ID1300 IAG rails & lines
...Aeromotive fpr
... Walbro 460lph FP, in tank
...IAG AOS
...TurboXS catback
526whp 509wtq at 28psi, E91, S#
There was room to go higher but I need a bigger fuel setup. Goal is 32psi later on down the road. So far the spool is awesome on the road!
meowy.wowy is offline   Reply With Quote
Old 03-02-2017, 09:15 PM   #812
SinghBillen
Member#: 462344
Post
2016 sti
Facility: Church Automotive Testing
Type of Dyno: Dynapack
Baseline: Never did a stock dyno
Boost: 20.9
Fuel: 91 oct pump
Target AFR: 11.5
SAE Corrections:
Peak HP at RPM: 311 hp @ 5477
Peak Torque at RPM: 365 tq @ 3622
Mods:
Cobb Accessport
Cobb SF air intake
Cobb downpipe
Cobb 725cc injectors
Cobb fuel pump 255 LPH
Cobb fuel pressure regulator
Grimmspeed 3 port EBCS
Grimmspeed Up pipe/Dump pipe
Turbosmart wastegate 40mm (14psi spring)
Tomei Uel headers
SinghBillen is offline   Reply With Quote
Old 03-06-2017, 01:57 PM   #813
no694terry
Member#: 220816
SC Tube Truck
EJ22e 415whp/398wtq
my bad, wrong thread.
no694terry is offline   Reply With Quote
Old 03-12-2017, 12:20 AM   #814
atbwrx
Member#: 447001
2014 WRX
Default 2014 Wrx
2014 WRX
Facility: Drift Office - Auburn, WA
Dyno: DynoJet
Baseline: None
Boost: 17 psi taper to 14psi
Fuel: 92 octane
Target AFR: 11.8
Peak HP: 310 @ 5900
Peak TQ: 344 @ 4300
Mods:
COBB CAI
Process West Verticooler
COBB 3 port boost controller
COBB 725 cc injectors
Perrin small tube EL headers
Perrin small tube up pipe
COBB turbo back
Stock turbo and fuel pump
atbwrx is offline   Reply With Quote
Old 03-20-2017, 09:12 PM   #815
motohegg
Member#: 461704
2017 WRX Limited
Crystal White Pearl
Default 2017 WRX 6mt
2017 WRX, 6mt
281 HP / 314 TQ
Fuel: 93
Grimmspeed TMIC
EGR / TGV deletes
Grimmspeed 3-port boost control solenoid
Mishimoto catted j-pipe
Perrin catback exhaust with resonator
Perrin pitch stop brace
Group N Pitchstop: Subaru Part Number: D1040-FE0000
Cobb Accessport v3
If the image doesn't show, here's the imgur link: http://imgur.com/Dyd7RcA
motohegg is offline   Reply With Quote
Old 03-20-2017, 11:20 PM   #816
squidmaster
Member#: 187011
Originally Posted by atbwrx View Post
2014 WRX
Dyno: DynoJet
Baseline: None
Fuel: 92 octane
Target AFR: 11.8
Peak HP: 310 @ 5900
Peak TQ: 344 @ 4300
Nice numbers! Do you have a graph with boost integrated? I'm curious how quickly the system pressurizes with the verticooler
squidmaster is offline   Reply With Quote
Old 03-21-2017, 12:54 AM   #817
Superorb
Member#: 135252
2002 WRX Wagon
What fuel motohegg?
Superorb is offline   Reply With Quote
Old 03-22-2017, 08:11 PM   #818
motohegg
Member#: 461704
2017 WRX Limited
Crystal White Pearl
Originally Posted by Superorb View Post
What fuel motohegg?
Thanks. 93. I updated the post.
Old 04-02-2017, 09:38 AM   #819
atbwrx
Member#: 447001
2014 WRX
I don't, but I could post an AP data log if that's helpful. I don't do launches (still on stock clutch) but I could do a rolling start from 2500rpm.
Old 04-14-2017, 03:40 PM   #820
jimbosv650
Member#: 261307
04 wrx wagon
Car: 04 WRX wagon
Facility: Machines Gone Wild in Miami, FL.
Boost: 20psi
Fuel: E85
Peak HP: 353.62
Peak Torque: 358.42
Mods: usdm ej257 block, sti crank, 100mm forged JE pistons, forged Manley rods, ARP head studs, ACL bearings, oem master gasket kit, 11mm sti oil pump and cooler, rebuilt ej20 heads, Tomei elh, Grimmspeed up pipe, ported and Cerakoted Forced Performance td06-20g 7cm, Kinugawa 15psi wastegate actuator, bellmouth downpipe, electronic exhaust cutout, SRS 3" exhaust, SPT intake, Perrin turbo inlet, ported/ceramic coated intake manifold, ported throttle body, ported tgv deletes, Torx Racing tmic, Walbro 255, Denso 820cc injectors, Fuelab stainless filter, Grimmspeed aos and 3 port ebcs,
Tune: 93 octane by JRtuning
E85 by Torqued Performance
jimbosv650 is offline   Reply With Quote
Old 04-15-2017, 04:09 PM   #821
Superorb
Member#: 135252
2002 WRX Wagon
^^ What's your CR with the ej20 heads? 205 or 207? Stock cams?
Old 04-15-2017, 06:51 PM   #822
jimbosv650
Member#: 261307
04 wrx wagon
Default Post your Dyno Plot and Mods, see format inside.
Ej205 heads with stock cams. 8.5:1 cr JE hybrid pistons.
Old 04-16-2017, 08:29 PM   #823
Superorb
Member#: 135252
2002 WRX Wagon
Thanks. Is that turbo out of steam past 20psi or is there still some power on the table?
Old 04-16-2017, 10:45 PM   #824
jimbosv650
Member#: 261307
04 wrx wagon
There's still some room to push it some more. Some guys are getting 28-30psi out of them but somewhere around 25 is as high as I would go.
Old 04-17-2017, 11:07 AM   #825
Superorb
Member#: 135252
2002 WRX Wagon
25psi looks like roughly 440whp. Not too shabby. How's the spool?
Post your OLD ride and your NEW ride. MF-DIF Member's Car Gallery 1291 03-02-2016 11:43 PM
Post your dyno results from today. (Mach V) banzai Mid Atlantic Impreza Club -- MAIC 70 03-28-2006 10:08 PM
hey baic folks, post your dyno results LEOSPEED Bay Area Impreza Club Forum -- BAIC 16 11-25-2003 02:22 AM
Utec dyno plots and target A/F ratios and some tuning advice. nmyeti Engine Management & Tuning 39 10-15-2002 02:29 AM
Post your dyno results here! Darryl Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 11-10-2001 05:40 PM
