Welcome to the North American Subaru Impreza Owners Club Tuesday November 19, 2019
Old 11-02-2019, 10:02 PM   #11826
subywag
Member#: 239731
90s ejs
rainbow
whats the best option for sourcing a v7 ej207? I have a 04 wrx wagon and want to buy a motor that I can just drop in and go. ej205 has a burnt valve and just does not seem worth it to rebuild...
subywag is offline   Reply With Quote
Old 11-02-2019, 11:36 PM   #11827
subaru_gc8
Member#: 29292
2004 WRX wagon
Originally Posted by sdh7711 View Post
So I have an EJ207 V7 dropped into my 04 WRX with the JDM 6 speed and R180 rear differential, 4 pot 2 pots for brakes with the sti axles and knuckles on the rear.
Was on the throttle good heading up the Route 2 WB hill out here and bam lost power started blowing white smoke out the rear. Towed it over to the mechanic and will do compression test tomorrow but its burning oil and he thinks I may not be getting compression on one or two cylinders the way it sounds when cranking.
Tryinging to weigh my options right now. Continue trouble shooting the block or just weigh options of dropping in another V7 or V9? Thoughts suggestions would be appreciated.
2.1 all the way!!
subaru_gc8 is offline   Reply With Quote
Old Yesterday, 02:47 PM   #11828
Gerald81
Member#: 34226
Originally Posted by mrsaturn7085 View Post
I'll just do the whole list; it looks like the oil feed pipe is the only part unique to specific turbos and not just features of the turbo -
The correct VF36 parts are:
15192AA470 - oil feed [green]
15194AA130 - oil feed bolt [blue] - this is the bolt that fits ball bearing turbos
803910050 - oil feed bolt washer (2) [yellow] - same across most motor/turbo combinations
99078AA341 - water hose [yellow] - this is the hose that fits twin-scroll turbos
805918010 - water hose clamp (2) [blue] - same across most motor/turbo combinations
The correct VF37 parts are:
15192AA480 - oil feed [green]
15194AA110 - oil feed bolt [blue] - this is the bolt that fits journal bearing turbos
I know this was an old post, but I was just doing some research on this while fitting my VF42 (a ball bearing twin scroll turbo) and found something interesting.
Since the VF42 is a ball bearing turbo like the VF36, I expected it would be paired with the same oil feed pipe and bolt (15192AA470 and 15194AA130) as the VF36.
However, I have found that Subaru uses the same oil feed pipe and bolt (15192AA480 and 15194AA110) witht he VF42 as the ones used with the VF37.
In other words, the S204 which comes with the VF42 (ball bearing, twin scroll) uses the same oil feed system as the standard JDM STI which comes with the VF37 (journal bearing, twin scroll). Only the JDM Spec C which comes with the VF36 (ball bearing, twin scroll) uses a different oil feed.
I thought the ball bearing turbos need less oil pressure hence the different parts for the VF36, but it is interesting that the VF42 uses the same parts as the journal bearing VF37? Any ideas why?
Gerald81 is offline   Reply With Quote
Old Yesterday, 09:44 PM   #11829
murrdogg24
Member#: 50586
2017 Tacoma
TRD 4x4
Yeah the banjo bolts have a different size restrictor/hole that causes less flow...
murrdogg24 is offline   Reply With Quote
Old Today, 12:12 AM   #11830
Gerald81
Member#: 34226
Yup I guessed as much too, but don't you find it strange that the S204 (with a ball bearing turbo) has the same pipe and banjo bolt as a standard JDM STI (with a thrust bearing turbo)? I would have thought the S204 turbo would require less oil pressure.
ej207 owner wants opinions adbramsay Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 02-26-2011 08:29 PM
Ej207 V6 AndrewFD3 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 06-03-2010 05:53 PM
JDM Sti EJ207 V9 crank 75mm or billet crank (K1, Manley) VENDORS ??? L'frise Private 'Wanted' Classifieds 7 06-03-2010 10:24 AM
08 ej207 JDM dual AVCS heads on a built v7 ej207 icev7 Built Motor Discussion 17 02-21-2010 04:21 PM
Ver 8 EJ207 Owners Check In spoolinsuby Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 21 10-17-2005 02:56 AM
