04-26-2009, 08:33 PM | #1 |
Member#: 134093
rpm drop after new wires
so i installed new plugs a month ago and then had to order some wires, I threw on the new wires today and all is well except if i tap the gas my rpms drop to nearly nothing then go back up. This happens every time I stop. All the wires are connected tightly>? This also happened when i just put plugs in but then went away. Any suggestion what it could be?
2005 rs new rallitek wires installed
04-26-2009, 09:51 PM | #2 |
Member#: 80465
RMIC
Vehicle:2001 2.5RS Black Diamond Pearl |
you tap the throttle every time you stop?
04-26-2009, 11:01 PM | #3 |
Member#: 134093
uh no? the rpms just go down when i DO tap it
04-28-2009, 11:40 PM | #4 |
Member#: 168862
Vehicle:2007 ej253n/a 5speed Red Sox Nation Lifer |
i tap the throttle everytime i stop . you dont?
less wear on the clutch when engaging it . |
04-28-2009, 11:42 PM | #5 |
Member#: 168862
thats a wierd situation though . sounds like you crossed the wires up or something .
try some dielectrode grease as well . |
04-29-2009, 04:31 PM | #6 |
Member#: 173007
RMIC
Vehicle:2005 2.5RS...AW 05RS-RIP...avenged by AW! |
At night time, open up your hood while the car is started, and see if the wires are arcing. I had this problem on my old Jetta, it was like frankenstein **** in there man!
EDIT: oh this was after aftermarket wires as well, i will forevermore use oem wires for now on |
04-29-2009, 04:35 PM | #7 |
Member#: 143094
SCIC
Vehicle:08 LGT DBM |
I had this issue when I installed a grounding kit. It'll eventually go away, the ECU has to reset and relearn timing. Should clear up after a 50 miles or so.
04-29-2009, 10:57 PM | #8 | |
Member#: 102984
Vehicle:2005 2.5RS 4EAT Platinum Silver |
I'm going with rechecking the wiring. |
Similar Threads | ||||
99 2.5 rs clunking sound when rpms drop from 2700 rpm HELP!! | s4bones | Normally Aspirated Powertrain | 0 | 05-27-2008 04:48 PM |
RPMs increase then drop after accelerating... is this normal? | tibor75 | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 12 | 06-15-2007 07:38 PM |
RPM Drop after small rev | Seke631 | Service & Maintenance | 1 | 03-08-2003 08:30 PM |
RPMs drop when thottle is pressed | imprez25 | Normally Aspirated Powertrain | 5 | 04-04-2002 08:27 PM |
Installed Cobb CAI, rpm drop when shifting? | tymax | Normally Aspirated Powertrain | 5 | 03-22-2002 03:09 PM |
