10-22-2019, 07:17 AM | #501 |
Member#: 73805
Vehicle:24 TypeS ZO6 White |
Just noticed MHoward1 posted..o well I’ll hit post anyway
Dyno Test Of The 2020 Chevrolet C8 Corvette Reveals Huge Power Numbers https://jalopnik.com/this-dyno-test-...-hu-1839225233 The folks at Motor Trend strapped the 2020 Chevrolet Corvette to a dynamometer to see if the 6.2-liter Small Block “LT2" V8 actually makes the stated 495 horsepower, 470 lb-ft. The websites findings?: “The 2020 Chevrolet Corvette C8 provided for all our testing produces more power than what Chevy claims.” I’m always hesitant to write things like “Dyno proves that [insert automobile]’s horsepower numbers are underrated,” because there’s a lot that goes into horsepower certification, and there are quite a few factors that can cause results from one particular dynamometer to differ from those of another. But Motor Trend, with input from its brilliant former Chrysler engineer and current technical director Frank Markus, discusses some of these concerns in the story. Motor Trend conducted six dyno pulls on a production 2020 Chevrolet Corvette in fourth through sixth gears. Output ranged from 478 HP and 536 lb-ft at the wheels (that’s roughly 562 HP and 630 lb-ft at the crankshaft assuming a 15 percent drivetrain loss—note that Chevy engineers told Motor Trend that actual losses are lower) tested in sixth gear to 561 horsepower, 515 lb-ft of torque (or about 660 HP and 606 lb-ft at the crank assuming the same 15 percent loss figure) tested in fifth. One possible explanation for the power discrepancy, Chevy apparently told Motor Trend, has to do with how the Corvette’s engine’s official power numbers were obtained. From the article: The other explanation is that Chevrolet certifies most of its engines through the SAE, the Society of Automotive Engineers, which follows a strict set of rules and standards to determine the horsepower and torque ratings. In other words, the SAE acts as an independent party that’s present during the engine tests and is the one who determines the final output ratings. Their testing does not involve a simple pull from idle to redline, either. Rather, rpm are slowly ramped up and allowed to stabilize before accelerating further. This process results in significantly more heat generation than any single pull from our six dyno runs. For that reason, the engineers say, it’s not uncommon for single chassis dyno pulls to register higher output (and it is extremely unlikely any car will ever generate less than rated output). The website even looked at the official SAE results: A quick check of the SAE database reveals that the certification test of the 6.2-liter V-8 LT2 engine with the optional exhaust system took place at the Pontiac Engineering Center in Michigan on April 9, 2019. Jordan Lee, chief engineer of the Corvette’s engine, signed the certification on July 15—just three days before the reveal in Tustin. The engine was rated at 495 hp at 6,450 rpm and 470 lb-ft of torque at 5,150 rpm The vehicle code name 2020 Y2XX underwent three tests, and the power and torque graph looks similar to the one we had at the dyno. Ultimately, Motor Trend isn’t sure why its numbers are so high, saying the dyno it used complied with the SAE procedure, and that this was the same dyno the team had used when testing a 2020 Ram 2500. The torque figure from that test, in case you are curious, wasn’t far from Ram’s claimed (but not SAE certified) peak figure. Still, despite a number of questions still unanswered, Motor Trend concludes that the Corvette tested does indeed produce more power than what Chevy claims. This is all a bit odd, because if the Corvette’s engine is SAE certified to make 495 horsepower, then it’s supposed to make that much power—that’s a requirement. As I’m not as well-versed in the area of power and torque certification as some, I called up Gary Pollak, a Program Manager at the Society of Automotive Engineers. Pollak said when it comes to SAE certified horsepower, it’s “pretty tough to fudge the results,” and that “All production engines must be within 2 percent of the certification claim.” He also said that automakers are allowed to claim an SAE certified horsepower number within 1 percent of the measured result—this might allow an automaker whose result was 499 horsepower to claim 500, for example. “If somebody does run at that same kind of condition in 1349 and they see something that’s wider than that [2 percent] band,” Pollak told me, “they could make an appeal to SAE and we could actually re-test it and either revoke their certification or publish something...” As for the numbers from the Motor Trend test, Pollak told me that this type of discrepancy is exactly what the SAE test procedure hopes to solve. “I’m not sure what conditions Motor Trend used, but the SAE standard basically tries to typify what the consumer would see” accounting for all relevant power draws, he told me, going on to say that while the dyno used in Motor Trend’s tests may have complied with the SAE procedure, “it’s all of the auxiliary conditions that they might not have accounted for.” “There are so many conditions that are involved in the test...the numbers could be all over the map... It’s hard to compare from one dyno test to another,” he said. The SAE J1349 test, then, is meant to act as a sort of “datum” against which all engines can be measured so that they can be fairly compared. You can see the full list of SAE certified engines here. Among the engines on there is the supercharged 6.2-liter V8 found in the 2015 Dodge Hellcats. That engine was rated at a peak power of 707 horsepower, and under the exact same conditions, the Corvette makes 495. Thus, it should be safe to assume that the Corvette’s motor is 70 percent as powerful. But maybe it’s not safe to make that assumption? It’s easy enough to say simply “The test procedure was different,” but there’s always that chance that perhaps the test car really did have a more powerful engine. Motor Trend seems confident of this, though we may never actually know the truth. Definitely check out their full story here. How Much Power Does the 2020 Chevrolet Corvette Really Make? We Take it to the Dyno and Find Out https://www.motortrend.com/news/2020...c8-power-dyno/
10-22-2019, 04:56 PM | #502 |
Member#: 6228
Vehicle:2017 SS |
I always thought the SAE certification just meant the engine had to make at least that much power, not that it was also the max it could make.
Not sure what the benefit of underating an engine is in this day and age, but BMW seems to consistently do it on their turbo motors. |
10-23-2019, 07:33 AM | #503 | |
Member#: 377862
Mid-Engined Corvette Program Reportedly Inching Towards Public Confirmation
Agreed, I assumed it was an “under worst possible case scenarios...bad gas, wear, temps, etc. The engine is guaranteed to make at least XXX HP” rating. That being said, maybe a 5% upswing would be common, but the numbers being spoken about are blissfully confusing to me. |
11-08-2019, 06:06 AM | #504 | |
Member#: 73805
Gm Releases Official Full Performance Stats For 2020 Corvette
11-08-2019, 10:24 AM | #505 |
Member#: 139693
Vehicle:Dura ngo 95 horrorshow |
No manual no sale.
11-08-2019, 03:18 PM | #506 |
Member#: 377862
12-02-2019, 11:48 AM | #507 | |
Member#: 9481
South East
Vehicle:1832 Steam Buggy Wood |
C7 vs the C8
https://www.motortrend.com/cars/chev...-track-review/ Quote:
12-21-2019, 06:03 AM | #508 | |||
Member#: 73805
2020 Chevrolet Corvette C8 Nurburgring Lap Time Is 7:28.30: Report
01-12-2020, 07:38 AM | #509 | |
Member#: 73805
Latest Update From Leading Corvette Salesman Paints A Clearer Picture Of The C8
01-12-2020, 08:24 AM | #510 | |
Member#: 300811
RMIC
Vehicle:1939 International School bus |
https://www.wnky.com/2-gm-employees-...GRnYdqhFHKUJa8
01-12-2020, 11:28 PM | #511 | |
Member#: 46277
Vehicle:H1 Viper LP640 FGT |
01-13-2020, 08:58 AM | #512 | |
Merci Buckets
Moderator Member#: 88606
Vehicle:2018 Grand Cherokee Velvet Red Pearl |
01-13-2020, 09:09 AM | #513 |
Papi Chulo
Moderator Member#: 53794
RMIC
Vehicle:... 2017 BMW M2 2017 F-150 |
Not if that labor union has anything to do with it. Not sure if you remember, but a couple guys on Chrysler’s manufacturing line were caught smoking pot and drinking beer on their lunch break. Guess who fought for them and kept them hired.
01-13-2020, 10:00 AM | #514 |
Member#: 377200
Vehicle:21 Supra 3.0 MSM |
120mph in a 45, these guys are likely facing some jail time and loss of license.
01-13-2020, 04:07 PM | #515 |
Member#: 192568
Vehicle:'23 F150, '23 Camry '21 RAV4 |
Doubtful that these blokes are part of the labor union.
01-13-2020, 05:05 PM | #516 |
Member#: 46277
01-13-2020, 05:55 PM | #517 |
Member#: 67807
01-14-2020, 10:09 AM | #518 |
Member#: 120152
01-14-2020, 06:51 PM | #519 |
Member#: 132389
BAIC
Blue Corvette --> [pussied out]
White Corvette --> 100 mph Red Corvette --> 120 mph --> Baby you're much too fast |
01-14-2020, 07:36 PM | #520 |
Member#: 443545
RMIC
Vehicle:2015 WRX Limited CVT Lightning Red |
01-14-2020, 09:08 PM | #521 |
Member#: 14913
TXIC
Vehicle:2009 Ford Ranger Red |
01-15-2020, 03:33 AM | #522 |
Member#: 46277
delete
01-15-2020, 07:46 AM | #523 | |
Member#: 183032
NESIC
Vehicle:RWD Camry Pull me over red |
01-15-2020, 08:58 AM | #524 | ||
Merci Buckets
Correct. They are non-union engineers. |
01-15-2020, 12:01 PM | #525 | |
n00b Moderator
Moderator Member#: 4263
SCIC
I can think of two reasons per Union and Company CBA’s (speculating here): -One hour of personal time is granted per standard work shift. If off company premises, personal time means exactly that. If returning to work, someone suspected them or claimed to have seen them doing an illegal activity, well, they were on “personal time”. My company’s contract specifically states no drugs, alcohol, weapons/firearms on company property or in company vehicles. That is a separate issue from working while under the influence. If the company has no random drug testing policy, there’s legally not a way to prove they returned to work under influence of drugs or alcohol (because lawyers are good at pointing out that a witness is not a certified drug testing kit). -Two, and the easier one to get out of: The employees who were caught smoking pot and drinking beer went home sick during their lunch break. They got a doctor’s excuse and didn’t finish their shift. So they weren’t on company property. Even if they were on company grounds, generally, one union member shouldn’t be turning in another member. Like for disciplinary actions, it has to be a manager outside of the Union. These are just plausible scenarios, as a few of my coworkers were wrongly terminated by the company. They all were reinstated and got back pay for the time they were off. As disgusting as it seems, wrongful termination happens, and many employees would have their jobs back if they were union members. IMHO, which doesn’t matter, one of my coworkers shouldn’t have been hired back. He assaulted a competitor’s employee. But, agreed to go to anger management counseling. He still had issues after returning to work. The other few guys were playing basketball at a public park while on lunch. The supervisor suspended them and the regional manager fired them. Well, it turns out, playing a pickup game of three-on-three is perfectly fine because it was during their “one hour of personal time”. There is probably verbiage in their Union agreement about driving infractions while using a company vehicle. There has to be. Like, you won’t lose your job if you get a parking ticket or for exceeding the speed limit and get a minor infraction. Being arrested for drag racing...? They should seek legal representation. On topic comment: I can’t wait to see the new Vette on the road! Last edited by Skylab; 01-15-2020 at 12:12 PM. |
