Welcome to the North American Subaru Impreza Owners Club Friday April 20, 2018
Old 03-16-2002, 09:52 PM   #1
roybfr
Member#: 14456
09 BMW 335i Sedan
69/72/01 Corvettes
Default Help with Autometer A/F Gauge and TurboXS Stage 1
I did a search in the forum before I went to install my Autometer A/F gauge, and read that I needed to tap into the B17 wire on the factory ECU. Well I have the TurboXS Unichip and harness. In this situation where is the best place to tap the signal. The B17 wire on the factory harness or the corisponding wire on the TurboXS harness. I will be easier to get to the TurboXS wires as there are already exposed where as the factory ones are covered up.
Also for those who have done this, did you just pull some of the sheeting back on the B plug, cut the B17 wire and crimp in the A/F signal wire, when connecting the B17 back together.
Troy
roybfr is offline   Reply With Quote
Old 03-17-2002, 10:07 AM   #2
scooby
Member#: 13085
i didn't run it off the ecu i just ran one single wire under the car to the rear O2 sensor clip and tapped into the single blue wire. I would rather tap there for the signal then near the ecu personal preference i guess.
scooby is offline   Reply With Quote
Old 03-17-2002, 12:30 PM   #3
mrtrex
Member#: 12223
2005 WRX
I DONT THINK THAT THE AF GAUGE IS THE WAY TO GO IF I REMEMBER CORRECTLY THEY READ OFF OF A DIFFERENT VOLT ON OUR CARS AN EGT GAUGE WOULD BE THE WISE CHOISE.
mrtrex is offline   Reply With Quote
Old 03-17-2002, 12:48 PM   #4
Kevin.T
Member#: 13638
2002 WRX Sedan
Rally Blue
No the A/F gauge will not work as it uses the conventional 1 volt.
The WRX uses a digital signal of around 10 volts on the O2 ahead of the cat conv. It will sortof work on the downstream of cat conv. but activity on gauge wont be much in my opinion.
The A/F gauge works on a sine wave signal. Better of with a EGT gauge.
Kevin.T is offline   Reply With Quote
Old 03-17-2002, 05:19 PM   #5
roybfr
Member#: 14456
09 BMW 335i Sedan
69/72/01 Corvettes
I installed 3 gauges at the same time, Boost, EGT and this A/F gauge. Others are using the A/F gauge so I am sure that there is some way to make it work that is not a total PITA. But if that is the case I will just get rid of it and put some thing else along side the other two gauges.
Old 03-17-2002, 07:24 PM   #6
SW00P_G
Member#: 5591
EJ257 Gt35r
Jesus people the rear O2 sensor is a conventional 1 volt. And I tapped mine right up at the ECU. Much easier than crawling under the car. I've used it for 35,000 miles and have not had a problem. I know it works becuase I can adjust my AFC and see the change in the gauge for all the doubters.
SW00P_G is offline   Reply With Quote
Old 03-17-2002, 07:43 PM   #7
roybfr
Member#: 14456
09 BMW 335i Sedan
69/72/01 Corvettes
Thanks for the clarification, I had read a post about the voltage being 1 volt so I was pretty sure that the 10 that scooby is saying is off.
I am going to just call Mark tomorrow at TXS to see weather I should tap the wire on the factory harness or the TXS harness.
Old 03-17-2002, 08:59 PM   #8
bobgrice
Member#: 10627
2002 WRX Sedan
Platinum Silver Metallic
I mounted a dedicated O2 sensor 4" after the turbo on the downpipe (my BPM downpipe already had a bung).
This way, you get a reading before the cat, give some more accuracy. I would say that this is still not the most accurate measurement of A/F, but the combination of an EGT gauge and the A/F gauge is the way to go for the sake of redundancy.
I think I will be adding an O2 bung to the up-pipe soon to move the sensor further upstream, which I understand is better for accuracy.
bobgrice is offline   Reply With Quote
Old 03-17-2002, 09:27 PM   #9
WRXnFX
Alaskan Mafia
Member#: 10398
Will the rear 02 sensor fit the Vishnu uppipes? Or is there a different type/brand of sensor needed?
Winslow
WRXnFX is offline   Reply With Quote
Help with Autometer Oil Press and Oil Temp Install - Bad Ground? MattSTi Electrical & Lighting 3 07-06-2005 11:25 AM
Need help with Autometer boost gauge Takumi.wRx Motorsports 4 02-16-2004 10:30 PM
help...wiring autometer lunar series boost and egt gauge for lighting Jon Cox Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 08-21-2002 02:51 PM
Need help with Autometer EGT gauge wrxlvr Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 07-31-2002 06:10 PM
MPG and Turboxs stage 1? entropy111 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 11-30-2001 11:42 AM
