Welcome to the North American Subaru Impreza Owners Club Saturday January 19, 2019
Old 06-03-2004, 10:06 AM   #76
superg
Member#: 3385
Default Benzene
I was interested in the product until I saw the Material data Safety Sheet that indicates a major ingredient is benzene. As someone has already pointed out, benzene is a carcinogen. Exposure to benzene is risky.
superg is offline   Reply With Quote
Old 06-03-2004, 10:34 AM   #77
dwx
Member#: 8343
2005 2012 Jeep
2013 DGM BRZ
Default Re: Benzene
All gasoline contains Benzene to some degree.
Old 06-03-2004, 12:59 PM   #78
SlideWRX
Member#: 3803
07 Mustang GT
Ford Crappy Paint White
And several other carcinogens as well. Some argue the leaded gas is safer. 'Course, without going to unleaded we couldn't clean up the smog/emissions, so we picked the lesser of two evils.
Tom
SlideWRX is offline   Reply With Quote
Old 06-08-2004, 08:54 AM   #79
MK19_
Member#: 49148
Dogs are forever in
the pushup position...
Originally posted by jgavin
We should get a group buy going and get the price lowered
I am attempting to organize one as we speak
MK19_ is offline   Reply With Quote
Old 06-08-2004, 09:33 AM   #80
Kenneth2000
Member#: 6375
2004 STi
Java Black Pearl
You guys realize that the price was lowered from $77 + 10.50 shipping ... all the way down to $66 + 10.50 shipping .... (and that's their everyday price now)
if you haven't looked lately ... here's the link ...
http://www.need4speedpower.com/torco.html
Kenneth2000 is offline   Reply With Quote
Old 06-16-2004, 03:32 AM   #81
MK19_
Member#: 49148
Dogs are forever in
I have a GB setup from those guys, but not being a vendor- not too sure how we can set this up- basically, if we get 30+ cases sold, we can get them for $65.00 shipped... DAS CHEAP!!!!!!!!!!!!
Old 06-16-2004, 03:50 AM   #82
remowgn
Member#: 41149
09 FXT
SSM
gotta be careful... you need to be a vendor to do group buys on here.
remowgn is offline   Reply With Quote
Old 06-16-2004, 03:52 AM   #83
MK19_
Member#: 49148
Dogs are forever in
Didn't I just state that fact?
Old 06-16-2004, 05:15 AM   #84
Big Turkey
Member#: 32118
Just a quick update. I've been using Torco for about 2 tank fulls and a day at the drags. It's pretty good. 1.6bar of boost and no knock. That's a full 32oz. can in a full tank of 93. Approximately 100octane. I didn't lean it out and left timing the same because I didn't know the limits of it. I tried to get it to knock with boost but it wouldn't.
I changed my spark plugs shortly after. The tips of them are a reddish-orange color. What is that again? MMT deposits? Kenneth2000, are you getting those too? And are they harmful?
And if you guys are going to do a group buy, then contact me. I'll purchase 2 cases, maybe even more.
Big Turkey is offline   Reply With Quote
Old 06-16-2004, 10:01 AM   #85
Kenneth2000
Member#: 6375
2004 STi
Java Black Pearl
MMT will leave an orangish sediment/carbon type stuff ....
As long as it is not on the electrode, it should be fine ....
I wouldn't use the TORCO in the 1 can to 5 gallon concentration, as there will be much more MMT ... causing more of a build up .....
I have never got and miss fires, and my last 2 oil analysis reports are all within normal specs .......
Old 07-22-2004, 03:18 AM   #86
andyw318
Member#: 20935
2005 MINI Cooper S
I still miss my WRX!
This is in a WRX, not an STi, but still relevant to the discussion...
Last week I added one can of Torco unleaded race gas
concentrate to about 12 gallons of 92 octane. According to Torco,
this should get me in the neighborhood of 100 octane.
Using the UTEC, I started adding timing to my agressive street map.
This map is on the edge enough that if I have two people in the car
with me, I will get occasional detonation.
I created a few more maps with 1 degree more timing each to see what
the Torco would get me.
I ended up with +5 degrees more timing. At this point, I didn't
feel I wanted to push it anymore, but I did pull a half point of
fuel across the board as well.
Here are my results from the local dragstip on Saturday night:
Street map: 14.500 at 94.56, 2.152 60ft
Torco map (+5T, -.5F): 13.808 at 97.46, 1.918 60ft
The Torco map was quite a bit more bog resistant due to the extra
timing advance, thus the better 60ft. But look at the mph. +3 mph!
This stuff works and I didn't even find the limit, but I was getting nervous because my timing was getting into C16 territory.
Highly recommended for track use.
-AndyW
Last edited by andyw318; 07-22-2004 at 12:55 PM. Reason: I have a WRX, not an STi and this discussion in the 2.5 forum
andyw318 is offline   Reply With Quote
Old 07-22-2004, 03:37 PM   #87
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
hey, anyone try the leaded version?
Old 07-22-2004, 11:45 PM   #88
Red Rocket
Member#: 10507
'04 Ex STi Owner
'97 4Runner
Yummy, I'm thinking about getting my car tuned on this stuff. I guess 1 can to 10 gal ratio. Sounds worth it.
Kevin
Red Rocket is offline   Reply With Quote
Old 07-23-2004, 12:05 AM   #89
Big Turkey
Member#: 32118
I use half a can of torco in a full tank of 93 and it gives me about 95-96oct. It works wonders during this summer heat on my pump gas map.
Old 07-23-2004, 04:37 PM   #90
Red Rocket
Member#: 10507
'04 Ex STi Owner
'97 4Runner
I found a source for torco concentrate, and ordered up a 5 gallon drum for a hair under $150 shipped (ups hazmat). That works out to about $7.50 per quart (32oz). Sweeeeet. 55 gallon drums are about $1200, plus around $200 shipping, if anybody wants to do a "group buy"...... That works out to $6.36 a quart, so that's almost not worth the trouble, unless you ran it all the time.
100 octane all the time baby.....wooooot! At $2.42 a gallon! (32oz per 15 gal = 100 oct). At that mix, the drum will be enough to treat 300 gallons of gas, for aproximately 6000 miles of driving.
Kevin
Old 07-23-2004, 04:37 PM   #91
Kenneth2000
Member#: 6375
2004 STi
Java Black Pearl
I use the leaded all the time, it seems to work even better, but I wouldn't suggest using it if you still have cats ....
My 02 sensor is still OK, and my oil analysis reports are still coming back fine, that's after running Torco every day for over 17,000 miles ....
Old 07-23-2004, 06:32 PM   #92
JScoob
Member#: 48163
2003 wrx
Where??? Me want.
JScoob is offline   Reply With Quote
Old 07-23-2004, 06:42 PM   #93
Red Rocket
Member#: 10507
'04 Ex STi Owner
'97 4Runner
Originally Posted by JScoob
Where??? Me want.
PM cronic.
Kevin
Old 07-23-2004, 06:49 PM   #94
V6TurboTA
Member#: 9090
09 Forester Gump
02WRX->04STi->09Gump
Kevin you interested in selling some? If so PM me, I know some people that want some.
~v6
V6TurboTA is offline   Reply With Quote
Old 07-23-2004, 08:09 PM   #95
Red Rocket
Member#: 10507
'04 Ex STi Owner
'97 4Runner
~v6
Ehhh, I would, but I'll be running it 100% of the time, so this will only last me 6000 miles or so. Sorry.
Kevin
Old 07-23-2004, 08:12 PM   #96
cronic
Member#: 9749
Originally Posted by Red Rocket
PM cronic.
Kevin
Ha! Dont say that or everyone will think i am the Torco hookup!
cronic is offline   Reply With Quote
Old 07-23-2004, 08:20 PM   #97
Red Rocket
Member#: 10507
'04 Ex STi Owner
'97 4Runner
I just don't want to have tons of people PM'ing me!
Kevin
Old 07-23-2004, 09:47 PM   #98
Big Turkey
Member#: 32118
Hey Dave, lemme in on some of this!
For $150 for a 55gallon drum, treating 6000 miles of 100 octane.. HOOK ME UP. I'll buy 2 of them.
Wally
Old 07-23-2004, 10:38 PM   #99
eightballrj
Member#: 18520
2005 L GT Limited
Can we get intouch with this hookup?? Then you guys wouldnt have to worry with people iming you.
eightballrj is offline   Reply With Quote
Old 07-24-2004, 01:14 AM   #100
Red Rocket
Member#: 10507
'04 Ex STi Owner
'97 4Runner
PM'ed both you jokers, so people can bug you now!
Kevin
Torco race fuel concentrate dwaynesti Vancouver Impreza Club Forum -- VIC 0 06-29-2007 07:33 PM
FS: Half Case Torco Mach-1 Unleaded Race fuel concentrate godai Accessories & Misc 4 09-21-2006 10:54 AM
Torco Race Fuel Concentrate in Phx? AaronB South West Impreza Club Forum -- SWIC 25 04-19-2006 12:26 AM
Oil analysis after 3k of using Torco Race Fuel Concentrate The Deliverator Service & Maintenance 8 05-19-2005 01:51 PM
NY: 4.5 gallons of Torco Race Fuel Concentrate The Deliverator Private 'For Sale' Classifieds 2 09-13-2004 01:55 PM
