Welcome to the North American Subaru Impreza Owners Club Thursday October 18, 2018
Old 12-05-2017, 07:29 PM   #1
confuzled
Member#: 464718
Default RCE Yellow - Camber Bolts/LCA
Are camber bolts needed to properly align the 2015+ WRX to specs?
I've read threads on NASIOC but there seems to be mixed input on whether or not its needed.
I believe the LCA are optionally but not 100% on the camber bolts.
confuzled is offline   Reply With Quote
Old 12-05-2017, 07:49 PM   #2
Harey
Member#: 270569
'15 Foz XT & GT86
From the factory your car already has camber bolts on the front (top bolt). That is all you need unless you want to run more than around -1.4ish degrees of camber. You will need aftermarket camber bolts if you want to run more than that (bottom bolt).
If you are installing RCE yellows then yes the LCA's are optional. Most people get about -2 degrees of rear camber after fitting those springs. If you want more or less than that you need to purchase LCA's. There is no way from the factory to adjust the rear camber.
Harey is offline   Reply With Quote
Old 12-06-2017, 12:07 PM   #3
uofime
Member#: 421271
2015 WRX
Galaxy Blue Pearl
You'll gain a couple tenths of negative camber at the rear with yellows and that will throw your rear camber out of factor spec in most cases.
It's nothing to be overly concerned about.
It will make the limit cornering balance worse than factory by some marginal amount, but it's the plowing understeer kind of worse so its "safe" and you're unlikely to notice it street driving.
That said if you still have the factory alignment in the front (typically -0.8deg camber) and have the negative camber maxxed out with your alignment afterwards (roughly -1.3 deg when lowered), overall your balance will be better.
uofime is offline   Reply With Quote
Old 12-07-2017, 03:14 AM   #4
MedicDG
Member#: 329822
2016 STi
My opinion I would replace OEM control with adjustable one and would replace toe arm along with it.
MedicDG is offline   Reply With Quote
Old 12-07-2017, 10:23 PM   #5
Harey
Member#: 270569
'15 Foz XT & GT86
Just because? do you want to reduce negative camber on the rear with the lowered springs? toe is already adjustable, why a toe arm as well?
Old 12-08-2017, 09:54 AM   #6
uofime
Member#: 421271
2015 WRX
Galaxy Blue Pearl
The stock rear toe adjuster has limited range if you go less than about -1.6 deg camber in rear you'll no longer be able to keep zero toe.
If you want to optimize performance by playing with your alignment it's worth doing, but if you just want to look cool and drive safely it's not necessary.
