#1 |
Big Ron
Super Moderator Member#: 18062
MAIC
![]() Tuner FAQ: How to pick one, what to ask of them, and how to prepare for a tune
How do I find the right tuner? Sadly, there is no tuner comparison and never will be. Tuning is more art than science so if you lined up 10 tuners with 10 equal cars, you'd get 10 different results. Tuner A would be the safest in terms of long term use. Tuner B would have the highest dyno figure. Tuner C would have the flattest curve. Tuner D would have the best under the curve response. Tuner E would have the quickest spool. So how do I generally find the one right for me? I live in an area where there are choices. This is where you need to do some research in several forums as there is no "tuner review forum". Check the Vendor Review Forum for reviews of that tuner's work. Search for that tuner's name in the Power Proven Bragging forum for reviews of their work. Also search for the tuner's name in your local forum as reviews of their work sometimes occur there. PM people who have been tuned by them for their thoughts. Remember though...there is more to a tuner's skill than peak HP/TQ numbers on a dyno plot. Yes, Bob is happy making 250WHP on his TD04 2.0L WRX via Tuner Jimmy. But without careful interpretation of the dyno plot, you might not be happy with the peaky torque curve or the removal of all knock correction or the lean AFR or the 22PSI he's spinning his turbo at. This is where looking at the whole dyno plot and talking to end users comes in vs. finding the tuner with the best numbers on a dyno plot. Car magazines put Lamborghinis on the cover to sell magazines and live off of Ford Taurus reviews, tuners do the same thing as a typical Stage 2 tune doesn't have the enthusiasm as a GT35R tune. I live in the boondocks and have one option or no options. If there is only one, you really have no options unless you want to do a "mail order tune" or organize with others and fly someone in. A mail order tune can vary between tuners, but there are basically two types. One is a better map than the base maps AKA one size fits all maps on the market. It's basically a plug and play map based on your specifications. The other is where a tuner sends you a map for your mods and you run it to perform some logging to provide feedback to the tuner, then they modify and email you the final map. While mail order tunes are not 100% ideal, they are much better than running base maps are less expensive than a full custom tune, though they require more work on the part of the end user in terms of logging as feedback to the tuner. Some examples of mail order tuners are PDX Tuning, Perrin, and Clark Turner though I'm sure I'm forgetting some others. Flying in a tuner in is much harder as you have NASIOC Vendor rules to contend with. What you'd have to do is contact a NASIOC Vendor tuner or a NASIOC Vendor that has a dyno and have them organize a tuning day. This can get very complicated as you have to account for profits for all parties and airfare/hotel/rental car. This is all usually handled by the Vendors on their end, but in the end it will be added to your tuning costs. As long as you have organized, sane people show up ready to tune it works out without excessive overhead though. It can be done though. So if there is only one tuner in your area, you are pretty much a captive audience to them unless you are comfortable with comparing them against the popular mail order tuners or flying someone in. Though there is never 100% in tuning, a tuner with a dyno should always be able to give you better results based on your input than the mail order option. But in some cases, you may be better off with a e-tune as you have to carefully compare the experience level as well. Also remember that tuners are limited to what they can tune so if you really want Tuner A to do your tune, he may not be able to tune your EcuTek ECU as he does not have the expensive software to do so. Then you have to find another tune or switch engine management systems. How much is gonna cost and how long will it take? Both are questions for your tuner as there is no average. Tuner A may be relatively inexperienced and is looking to make a name for himself, so he may be $50/hour. Tuner B may be a "famous name" tuner, so he can command $200/hour. Tuner C and D may be inbetween in experience levels, but since one lives in Macon, GA he charges peanuts and the other guy lives in Boston, MA so he has to charge bank to survive. Time is usually tied to cost as most tuners can give you a good time estimate and they are usually pretty accurate unless there are problems. Use the tips below to stop problems before they start. Generally speaking a normal tune will take no more than 2 hours, with most "stage 2" tunes taking one hour. A nitrous, meth injected, EWG car with a MoTeC engine management system...yeah, that's gonna take longer. But to their credit, most tuners are damn accurate on their times and they are also famous for "rounding down" their tuner time. ![]() What should I do to prepare for the tune? 1. Talk to your tuner PRIOR TO getting a tune. Ask for their tuning check list and follow it to the letter. P&L Motorsports has a great check list available via this link under the title Caring for your Vehicle for those without an official checklist. 2. Ask for their brand/type/size injector advice if upgrading them and use them. 3. Ask for their brand/type/gap recommendation on plugs and use them. 4. If you want an intake, ask for their brand/type recommendation. Be prepared for your tuner to talk you out of it though as many will depending on your goals. 5. If you want an aftermarket boost control product such as a new boost control solenoid, external waste gate, manual boost controller, etc., talk to your tuner about this and use their recommendation. 6. Perform your scheduled maintenance prior to showing up to your tune and make sure all your fluids are fresh and functional. And by prior to, allow at least a few days for fluids to settle and get topped off as having an air pocket in your coolant will do wonders for throwing off your tune at $200/hour. Two items not on any maintenance schedule that won't hurt and may help are cleaning your IACV (if so equipped) and cleaning your MAF sensor. 7. Double check everything you have done within the last 3 months or so. Vacuum leaks from fittings/hoses/pipes/couplings that move air and gaskets are the big killers. One of the unknown leaking spots is the BPV or BOV gasket as it is frequently removed and not replaced, so if there's any doubt, replace it. Another common leak spot is the stock turbo inlet, ensure you visually check it front and back, top and bottom using an inspection mirror for holes or tears. 8. Show up with 100% of your computer gadgets. Bring all the connectors, switches, CDs, your laptop, etc. Make sure that your engine management system is up to date with the latest firmware, updates, etc. unless your tuner specifically states so. Also bring a disk or thumbdrive to download dyno files or maps to. 9. Do not show up with crappy parts and/or crappy installed stuff. If your Cousin Jimmy did the wiring and you have live wires sparking against the pedals, that's not a good thing. Wiring should be neat and loomed or at least zip tied away from everything. Quality, correct parts should always be used...fuel safe lines, pressure lines...these aren't suggestions folks. Do you honestly expect Home Depot tubing of the incorrect diameter to work on your wastegate? Proper diameter and applicability is what you want to run even if it means delays as your tuner will be ![]() ![]() So what is my timeline for talking to my tuner? Here is the suggested timeline: 6 months prior to tune: Research and choose a tuner. At this point, you should call, email, or better yet visit your tuner and talk to them. Get their checklist and budget/buy NOW for your tune in 6 months. Find out their fees as well as the dyno fees and budget for them, plus an hour extra of each in case of problems. 3 months prior to tune: This is where you want to start purchasing any parts you want added for your tune. Things happen, prices go over budget, items go out of stock, etc. so plan for the worst and hope for the best. This is also the phase where another call with the tuner should occur to verify your purchases. 1 month prior to tune: This is where you want to start installing parts or the planning of your install. This is also where you want to have your tuner send you a "limp map" for your mods and discuss with them any final install or purchase issues. You should also discuss any last minute install items either at the tuning shop or on the shop premises. One that comes to mind that you might do on the dyno or in the parking lot just before the tune is the installation of an aftermarket boost control solenoid. For new turbos and motors, refer to the manufacturer recommended oil type and break-in period. For new clutches, refer to the manufacturer recommended break-in period. Two weeks prior to tune: By now your parts should be installed and any issues related to the parts should have reared their head by now and this allows sufficient time for replacements, repairs, etc. Tune day: Arrive early. Arrive with 100% of what your tuner has told you to bring. Come with your tune game plan to allow your tuner to use as a checklist. This game plan should have already been discussed with your tuner and could include CELs you want defeated, new redline set, top speed governor removed, or other tune variables. A list on paper generated a week prior may save you from getting a CEL 50 miles down the road***8230;.checklists are never bad. Should I seek parts advice on NASIOC? Sure, that's fine but some advice is strictly tuner specific and his advice should be taken even if 35 NASIOC gurus suggest otherwise. Tuners can be very specific on spark plugs, boost control solutions (EWG brand/size, aftermarket BCS, EBCS, etc.), and injectors. Most tuners can tune anything, but do you really want to force your tuner into an unfamiliar product? Imagine this scenario: Your tuner recommends Deatschwerks injectors that flow 750 cc. You get a "deal" on PE injectors that flow 650 cc. Your tuner is unfamiliar with them and spends an additional 30 minutes tuning them only to find out that you didn't get ones big enough. Now you get to spend $150 extra in tuner's fees and dyno time along with the fact that the injectors limit you on power because they weren't big enough. This is a hypothetical situation, but similar circumstances could occur. Always default to your tuners advice, especially with these three components if they have a preference. My car has problems, but my tuner can fix them right? Tuners tune. Yes, they can help troubleshoot simple issues like vacuum tube routing on a boost control solenoid, wastegate adjustment, settings on your boost controller, but don't expect your tuner to be Mr. Goodwrench. You should arrive on your tune date with a 100% operational vehicle unless you have discussed any issues that your tuner can take care of personally or via the shop where he is doing tuning. Mechanics generally charge $80/hour to fix, making a tuner diagnose at upwards of $200/hour is not good. Editors Note This post was created because I wasn't able to find a good tuner FAQ. I came up with the text based on LOTS of searching here. Upon reading this you should have an idea of how to choose a tuner and what to do prior to a tune. My thanks to Dan from www.fastwrx.com, Phil from www.elementtuning.com, Clark from www.clarkturner.com, and Jorge from www.pandlmotorsports.com for their input to this. Anything screwed up about this is my fault though. ![]() If you find an error in this FAQ, please PM me with factual details and I will update this post. Responses such as, "XXX's tune is OMFGBBQ awesome!" or "XXX's tuning skills suck" are not appreciated here, that is what the Vendor Review Forum is for. Last edited by Unabomber; 10-22-2013 at 08:55 PM. |
#2 |
Big Ron
MAIC
![]() Reserved.... a little more work below...please disregard.
![]() Last edited by Unabomber; 08-30-2008 at 08:08 AM. |
#3 |
Big Ron
MAIC
![]() This is still a work in progress as I'm sure I forgot a few things and got a few things wrong. I also want some of my tuning friends to sanity check it for me.
#4 |
Member#: 87358
TXIC
![]() Excellent Stuff.
We get calls on injectors size recommendations all the time, which we do not mind helping with one bit. But in the end we always suggest to defer to what their tuner recommends. Who is going to be tuning the car is one of the first questions we ask when we get tech calls. |
#5 |
Member#: 17355
![]() Nice intro.
#6 |
Member#: 179690
Vehicle:2004 WRX |
![]() Good writeup. I was looking for something like this recently, even though I don't have a lot of choices around my area, but it's good info to have.
#7 |
Member#: 176128
South East
Vehicle:5862 ...baby boosted |
![]() woo hoo! great job unabomber. This is definitely something people should read as soon as the mod bug hits them. I would also advise anyone to ask their tuner what their support will be like after the tune. Will minor fixes/changes require $$$/dyno time or can they send email updates.
Also (this may exist I havent checked and have only seen similar threads in the regional forums) maybe someone could make a master thread with all known tuners and the areas in which they operate. |
#8 |
Member#: 134299
SCIC
![]() how come i've never seen this until now? this should be attached to the Engine Management FAQ or somewhere else more people can see this
#9 |
Member#: 211150
TXIC
Vehicle:2018 WRX CWP |
![]() thanks for the info
#10 |
Member#: 214691
Tri-State
Vehicle:2005 Baja Turbo Blue |
![]() so how can i find a tuner in my area?
#11 |
Member#: 140444
NWIC
Vehicle:05 Stage Free LGT ATP 3076, 6MT, AVO FMIC |
![]() Your area probably has a regional forum here. Go there, read all sticky threads in that forum, then ask if you still need a referral. The search all of NASIOC (and the web, for that matter) for that tuner's name, and see what you find.
#12 |
Member#: 367657
Vehicle:2002 WRX Silver |
![]() Good Stuff!
#13 |
Member#: 389403
Vehicle:2004 WRX Rally Blue |
![]() thanks for the info! actually really good to know
#14 |
Member#: 401854
![]() I need a "tuner", what is the easiest way to find one? I live in a small town and there isn't one here. I'm willing to drive to one if they know what they are doing.
#15 |
Member#: 333964
MWSOC
Vehicle:Juli sti JuliusVetJD |
![]() Do a search. Look in your local nasioc forum section
Sent from my SCH-I545 using NASIOC mobile app |
#16 |
Member#: 402154
![]() Don't know what type i should get or what i should look for when getting one
#17 |
Member#: 401864
![]() Does having a JDM car that runs OBD1 effect the ability to tune or my options for choosing an access port?
What is involved when tuning a JDM car to North American specs? 03 TS wagon 99 JDM sti RA full powertrain swap 3" turbo back GDB suspension/brakes swap Walbro 255 fuel pump Sent from my iPad using NASIOC |
#18 |
Member#: 452766
MWSOC
Vehicle:2005 Impreza CGM |
![]() M. Ushz
#19 |
Member#: 479255
![]() I am looking to buy for my 2017 sti limited:
Perrin CAI Invidia R400 catback Invidia catless divorced down pipe Perrin A/O separator Cobb Accessport v3 I contacted Cobb to see if they can do a custom tune for those and they basically said no. They recommended me to a pro tuner and also said I would HAVE to upgrade my fuel system for these. Any thoughts or knowledge on this? I didn’t think I’d have to upgrade my fuel system as well for these mods. If so about how much would it cost to upgrade the fuel system and what all would I have to upgrade to make this happen?! |
#20 |
Member#: 375462
NWIC
Vehicle:2006 Impreza WRX STI WR Blue |
![]() With an open exhaust, you'll max the stock 565cc injectors. You don't *need* a new pump and bigger injectors... but I would be dropping the intake and AOS for these two parts as they are definitely a higher priority.
#21 |
Member#: 485249
MWSOC
Vehicle:2005 Saab 9-2x Aero Regal Blue Pearl |
![]() My 04 2.5TS has a bad head gasket. To fix this, i plan on purchasing an ej25 and rebuilding it with some TWE cams/ pistons/ springs. I'd also like to install a stock wrx catback.
Since the 03-04 ecu's can't be flashed, would a tuner need to use a standalone unit? would that mean switching the wiring harness as well? If thats the case, i might as well forget about TWE parts and just do what i can without a tune. Sorry in advance for any ignorant questions, just not very familiar with this subject. *Constructive criticism always welcome, especially from people who have done something like this before ![]() |
#22 | |
Member#: 375462
NWIC
![]() Quote:
Posting a random, unrelated question on a FAQ post from 2008 is not how you internet. |
#23 |
Member#: 485249
MWSOC
![]() This site is really confusing and i can't find any informative threads that aren't ancient... and now i can't figure out how to delete my post
sorry |
#24 |
Member#: 425021
![]() For anybody currently looking for a tuner in a rural area, you can always go with a remote tune as an alternative option to traveling to a tuner. I had Delicious Tuning in California tune my turbo FRS in Indiana and it was an incredibly pleasant experience. Zach there was extremely helpful and was quick with the updates following data logs. It's also easy to troubleshoot new builds on your own time without having to give up precious dyno time to find the gremlins. We went back and forth with data logs on my own time until it was dialed. You pay a standard fee for the tune, and they will work with you and the data logs until it is running perfect. You may not have dyno numbers, but since it was street tuned, my FRS has far greater drivability than my WRX that was dyno tuned at AWD.
In preparation for pro tune questions. | TheSomethingorother | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 16 | 03-17-2009 01:42 AM |
FS: Houston:: Nvidia 7800GTX two of them and one 7900GTX video cards | el tekk-O | TXIC Private Classifieds | 7 | 01-11-2009 05:34 PM |
Finally preparing for a tune | Cannonbolt | General Community | 7 | 02-05-2008 02:06 AM |
How To Prepare For a Tuning Session | Mach V Dan | Mid Atlantic Impreza Club -- MAIC | 9 | 06-18-2007 12:18 AM |
All knowing OT: How to book vacations like the best of them? | fuzzycuffs | Off-Topic | 4 | 05-06-2006 07:14 PM |
