Welcome to the North American Subaru Impreza Owners Club Thursday March 21, 2019
Old 03-14-2019, 09:22 PM   #2801
Homemade WRX
Member#: 33782
96 in the garage
search FIRST, then PM!!!
Was hoping they had something in here on it but I don't see anything.
http://www.turbos.borgwarner.com/fil...ical_brief.pdf
Old 03-14-2019, 09:52 PM   #2802
Waddlz
Member#: 395275
2012 STi
yeah I checked there first and seen nothing.
I found this post from a couple of years ago on another forum,
"Jon from Full Race got me the answer. So FYI
-max EGT for the EFR turbos is 950C
-max turbine speed is rated in terms of "tip speed" and 560/ms. The specific RPM that 560m/s tip speed occurs depends on the diameter of the specific compressor wheel in question.
-oil pressure is regulated by the built in oil control orifice. Pressure range is stated as 30-100psi. we've had motorcycle and ATV customer engines at 15-20psi oil pressure and no issue surprisingly.
-bearings are m50 races with ceramic balls in aluminum cages (silver plated). Dimensional Tolerances are considered BW proprietary information and not shared outside of their internal engineering center.
-most of the EFR compressor wheels have 14 blades which corresponds to 2917 Hz (except the 6758 which uses a 12 blade wheel)"
but it just strikes me odd that, I had 40 PPM silver content and the zinc content in my oil was 1700 after 3000 miles, so probably 1800 for a VOA
prior to that, running Motul 5w-40 I only had a 3 ppm silver content and I was hard on the turbo for those 3 months I ran motul.
nothing changed between mechanical wise between the Motul and the RLI 5w-40.
Waddlz is offline   Reply With Quote
Old 03-15-2019, 11:30 PM   #2803
brecks
Member#: 435142
2004 STi
Java Black Pearl
How did you like the RLI altogether? Have been considering switching from Motul xcess 5w-40 as UOA show it shearing to a 30. Although if its going to eat my EFR bearings... that's an issue
brecks is offline   Reply With Quote
Old 03-16-2019, 12:59 AM   #2804
Waddlz
Member#: 395275
2012 STi
it stayed in spec very well. but I still think the high zinc content is eating the bearings
Old 03-16-2019, 06:00 PM   #2805
brecks
Member#: 435142
2004 STi
Java Black Pearl
Isn't the Motul pretty high in zinc too though? I wonder if there's some other component to the RLI that causes the reaction with silver
Old 03-16-2019, 08:03 PM   #2806
Waddlz
Member#: 395275
2012 STi
my motul was 1160 zinc.
Old 03-16-2019, 09:11 PM   #2807
brecks
Member#: 435142
2004 STi
Java Black Pearl
Hmm, are you switching back to Motul?
Old 03-16-2019, 09:13 PM   #2808
yamahaSHO
Member#: 73932
2005 STi EFR 6758
04 S2000 EFR 7064
If you want lower zinc, yet really good oil, 300v substitutes their zinc with boron.
yamahaSHO is offline   Reply With Quote
Old 03-16-2019, 09:21 PM   #2809
Waddlz
Member#: 395275
2012 STi
No. Just going to stick with my amsoil. Not convinced the RLI is better
Old Yesterday, 10:26 AM   #2810
Snow_Shovel
Member#: 344498
Not sure if this has been mentioned before in the thread, but Iíve got an IRL EFR7163. I should be able to swap the compressor housing out for a standard one so that i can fit a filter/inlet on there, correct? Much cheaper than machining a flange and inlet piece.
https://www.ebay.com/itm/Borg-Warner...4383.l4275.c10
Snow_Shovel is offline   Reply With Quote
Old Yesterday, 10:37 AM   #2811
PDXREALTOR
Member#: 468393
2017 STI
Yep. I was going to do the same thing with my stock location 7163 so I could get the bigger inlet.
PDXREALTOR is online now   Reply With Quote
Old Yesterday, 11:25 AM   #2812
Hyper
Member#: 15822
1999 WRB GM6
2.34 LR destroker
anyone wants to trade housings?
I've got TS 7163 with 2-port turbosmart actuator
I am considering going to v-band with EWG
Hyper is offline   Reply With Quote
Old Yesterday, 11:47 AM   #2813
Waddlz
Member#: 395275
2012 STi
yes it will
Old Yesterday, 12:00 PM   #2814
Snow_Shovel
Member#: 344498
Good, because i already bought one.
