11-20-2015, 07:09 PM | #1 |
Vendor Sales Rating: (80)
Member#: 141043
MWSOC
Vehicle:2011 STI black af |
MAPerformance Phase 2 93 Oct and 91 Oct Tune with Cobb Accessport!
Many of you may have seen, or are currently following our tuning thread from a few months ago. Our goal was to produce an OTS tune for the WRX
that would out perform the Cobb OTS maps, to help owners enjoy their cars that much more. We are extremely happy with the results, and all of the great customers who have backed us up and supported us along the way. So first and for most, THANK YOU!!! Originally we released tunes for 93 octane. Great for some of us here in the mid west, but not so great for customers out west, or the rest of the states for that matter. So we are now happy to inform you that a 91 tune is now being released! In addition to that, we went back in to take a look at areas of improvement in our existing tune. This includes focusing an extensive amount of time with the factory boost controller, working with the variable valve timing to smooth out idle, rev hang etc. Let's take a look at the results: ***Customers who purchase an Accessport from us will receive either of these tune files for free. Existing customers are eligible for a free update!*** Overall, we are pretty happy with where we landed with tuning the car, even if the car suffered too much heatsoak during dyno tuning to reflect the normal engine output. The benefits to running a refined 91 Octane tune vs. the Cobb OTS 91 octane tune is simply the smoothness, consistency with boost (no more oscillations) and moderately more power at higher RPMs. **The 91 Octane dyno testing was extremely hampered by heatsoak and the car having snow tires. This means the final tune’s dyno graph and peak HP/TQ numbers are lower than expected, however when compared against the OTS and previous tune, they are considerably higher. Dyno and street testing took place next in order to explore the complaints voiced by customers and Cobb OTS or MAP tunes. The complaints are generally: 1) “With the OTS/MAP Tunes and the stock boost controller, there are boost spikes at spool up, and also significant boost oscillations throughout the RPM range.” 2) “The Stock boost controller can’t run higher boost at higher RPM.” It was confirmed that the stock cars and the OTS /MAP v1 Tunes do have overshoot and oscillations, and that their boost drops off well below target at higher RPMs. However, I was able to remedy practically all of these issues through tuning alone, and the result is steady spool up with no overshoot or oscillations throughout the RPM range. It was also demonstrated that through tuning alone, I was able to run 18-19psi at higher RPMs. However, dyno testing showed that once the engine built up any real heatsoak, this added boost pressure at higher RPMs did not have a positive effect on power output. Here is a comparison to demonstrate power differences between several of the tunes throughout testing. But Ian, none of these graphs "excite" me. I need more! Well, before you judge too quickly, let me just show you a little behind the scenes of what REALLY goes down with our tuning: Again, our ultimate goal with this revision, was NOT to try to extract even more power, but to improve on drivability, and to smooth out the power band. We also wanted to see what we could do with the stock boost controller to provide a better, smoother boost curve to reduce spike, and to hold boost at higher RPMs, similar to what some 3-ports on the market do. Now, I am not saying EBCS is not worth it. We will see if it's required once we add our catless downpipe. Thanks again, and feel free to ask any questions you may have!
__________________
MAPerformance 1-888-627-3736 To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. I want to earn your business, PM me and tell us how we can become your one stop shop for performance parts today! ACL / AEM / ACT / Cosworth / Grimmspeed / Invidia / Ksport / Manley / Mishimoto / PTE / Tomei / Turbosmart / Wiseco |
11-20-2015, 07:16 PM | #2 |
Member Sales Rating: (2)
Member#: 164043
Tri-State
Vehicle:2015 WRX and FozzyXT White |
What I look for in all my tunes is a factory pedal sensitivity. (high). Is this new 91 tune like most of them, where it removes most of the sensitivity of pedal?
11-20-2015, 07:17 PM | #3 |
Member#: 141043
MWSOC
__________________
11-20-2015, 08:58 PM | #5 | |
Member Sales Rating: (11)
Member#: 117767
RMIC
Vehicle:2014 Audi S4 DP Stage 2 (~420whp) |
I think you might be one of ~3 people on the forum who liked that from the s*** factory tune. |
04-07-2017, 12:20 PM | #7 |
Member#: 465622
Vehicle:2016 wrx |
this actually happened to my 2016 wrx , once I put my cobb tune all the sensibility went away and I was kind of disappointed because it doesn't feel as responsive as it did stock.
11-20-2015, 07:24 PM | #10 |
Member#: 141043
MWSOC
__________________
11-23-2015, 09:33 AM | #12 |
Member#: 141043
MWSOC
I should have the tune files ready by the end of the day. If you are interested in purchasing the tune, please PM me, or email me directly at [email protected].
__________________
11-23-2015, 09:34 AM | #14 |
Member#: 141043
MWSOC
__________________
11-23-2015, 09:36 AM | #16 |
Member#: 141043
MWSOC
__________________
11-21-2015, 01:55 PM | #18 |
Member#: 418558
Vehicle:2015 WRX |
Is the 91 octane tune available now for those who already purchased the AP and have the 93 tune. I would like to use the 91 to compare since I am limited to 92 WA St octane or local 91/94 CND octane
11-22-2015, 09:18 PM | #20 |
Member#: 429757
Vehicle:2015 WRX WR Blue |
Can't wait for the new tune!! Have you guys done testing on the crappy winter 93 octane yet to see if it has any issues when using winter blend gas?
11-23-2015, 09:35 AM | #21 |
Member#: 141043
MWSOC
__________________
11-23-2015, 01:58 PM | #25 |
Member#: 141043
MWSOC
__________________
