06-14-2012, 11:10 PM | #1 |
Member#: 282906
Vehicle:2011 420/445 '11 sti Obsidian Black |
420 / 445 , 2011 sti 20gxt Topspeed SS1
Numbers Dyno: Dyno Jet
Shop: Topspeed,Alpharetta GA Tuner: Douglas Wilks Wheel HP: 419.75 (25 psi) Wheel TQ: 444.55 Ambient Temp: 87 F Elevation: 1000ft (EST.) Car Info Year: 2011 Sti OBP 5dr Turbo: Blouch 20GXT 7cm Engine: Topspeed SS1 block Intercooler: ETS TMIC FUEL: E85 Injectors: Injected Dynamics 1000cc Intake/Inlet: Cobb SF / Perrin 2.4 Headers: Invidia Race Headers *Ceramic coated* and wrapped Uppipe: Invidia *Ceramic coated* Downpipe: Invidia Catted CBE: Nameless Performance Now I just need some wheels! Car feels great and is flying! Super Quick Spool Another great experience at Topspeed for me!
06-15-2012, 10:52 AM | #2 |
Member#: 172698
Vehicle:11 STi BW 8374 E85 02 v8 Spec C E85 |
Nice power!
What are you running for a fuel pump? Any other changes to the fuel system? I'm thinking about this turbo for my car as well. |
06-15-2012, 04:51 PM | #3 | |
Member#: 282906
Thanks!
Power: Engine- Topspeed SS1 built block with CP forged coated pistons Turbo - Blouch 20gxt Cobb ACcessport pro tuned NGK plugs Moroso Oil Pickup Cobb SF intake DEI wrapped Injector dynamics 1000cc injectors Aeromotive 340 fuel pump Aeromotive fuel pressure regulator Grimmspeed EBCS Crawford Air Oil Seperator Invidia Catted Downpipe Cobb Turbo Heatshield Nameless Performance Catback ACT street clutching Invidia Equal Length Race Header swaintech coated, wrapped Invidia Up pipe swaintech coated, wrapped ETS Top Mount Intercooler Perrin Turbo Inlet E85/93 Protuned by Topspeed's Doug Wilks 420/445...e85 372/373.... 93oct suspension/handling Whiteline front/rear swaybars Kartboy Endlinks Hawk pads Interior: SMY Clustermaker Instrument Panel Maddad Boost gauge Maddad EGT gauge PLX Devices DM-6 multi gauge PLX Devices wideband A/F Cobb Shift knob Subaru Underseat Subwoofer Redline shift boot JDM stitch Redline e brake JDM stitch Pioneer Avic Z-130 BT Navigation JDM A/V trim panel Dynamat front door panels Exterior: Subaru Exhaust finishers 3M window tint Headlight Armor Yellow Fogs Cusco Short Antenna Perrin plate delete JDM front Lip spoiler Upcoming: thought list " stop making this list " |
06-15-2012, 08:51 PM | #4 |
Member#: 280744
South East
Vehicle:2009 CTSV 1,216whp Black Raven |
Told you it would go above 415.
06-16-2012, 08:01 AM | #5 |
Member#: 282906
Rob- ha!! Check is in the mail
I'll send you good copies of Mitch and my E85 dyno charts for you to see. I lost my up pipe plug bolt on the way home. Car sounded bad, but I figured it out quick and fixed. Now if I could just find an m12 p1.25 that's short and stainless. Ahhh!!! Post your chart! |
06-16-2012, 08:02 AM | #6 | |
Member#: 282906
What our yours Work WSD? |
06-16-2012, 08:41 AM | #7 |
Member#: 103232
Vehicle:GTX 3071R'd 11WRX PPG,4.44,LSD,E85,6spdx3 |
so your scoob is still IWG, and running a catted downpipe with a 7cm hot side on the turbo. Thats some nice results!!!!!
Whats your injector duty cycle on E85, and what kind of AFRs is it running at WOT? |
06-16-2012, 09:49 AM | #8 | |
Member#: 280744
South East
http://forums.nasioc.com/forums/show....php?t=2368796 Work Emotion 11R's in 18x9.5 +38 |
06-16-2012, 04:28 PM | #9 |
Member#: 282906
Thanks! I actually read all your threads earlier.
I want to see you in an SS1 E85 killer! Your car would pull some big numbers!! |
06-19-2012, 12:23 AM | #10 |
Member#: 305890
NWIC
Vehicle:2005 STI WRB |
That curve is amazing I must say. That thing must really put you back in your seat between 3-4000 rpms.
06-19-2012, 08:54 AM | #11 |
Member#: 170602
Vehicle:06 Wrx RWD Auto 76MM-AEM-2200's |
doug is a beast.
06-19-2012, 11:55 AM | #12 | |
Member#: 172698
I've looked at that turbo as well. I'm thinking about the 20g XT-R for even better spool though. I want my power to be right about where you're at but with as early spool as possible. What actually broke on your stock block? A piston, sleeve, etc? We're you on E85 at the time? I'm kind of surprised you broke it. I was hoping to be able to push my stock block for a while before it needs rebuilding. |
06-19-2012, 02:56 PM | #13 |
Member#: 130990
NWIC
Vehicle:06 Red Ltd.Wagon Dom 1.5xtr JJ tuned |
06-19-2012, 04:17 PM | #14 | |
Member#: 172698
On the other hand, maybe the newer EJ257's just aren't built like they use to be. Who knows. I've got a shortblock fund, I'm just hoping to not need it right away. |
06-19-2012, 04:26 PM | #15 | |
Member#: 289606
Vehicle:06 WRX white |
06-19-2012, 05:02 PM | #16 |
Member#: 172698
Well that's a new one for me. I though the OEM top ring gap is supposed to be ~ .008 - .010. Are you saying Subaru messed up and installed rings with a smaller gap and this is what breaks ringlands rather than too much knock on pump gas?
06-19-2012, 05:06 PM | #17 | |
Member#: 289606
Poor tuning, bad gas, knock, etc.... are all problems, my opinion is just that ring gaps have as much to do with it as anything. |
06-19-2012, 05:32 PM | #18 | |
Member#: 172698
Thanks for sharing. |
06-19-2012, 05:50 PM | #19 | |
Member#: 289606
In my opinion thats why you see so many people with mild setups breaking ringlands. It isn't a tune issue as much as it is the ringland issue. First time they really beat on it the rings butt and break the second ringland. Usually they don't notice it right away, its usually not till they have an oil consumption problem. |
06-19-2012, 09:15 PM | #20 | |
Member#: 282906
especially at idle. I feel that the stock headers are also part of the equation so I went with Equal Lengths this time around. I know, less subie rumble but it's honestly pretty sweet sounding. Added power and better VE, I'll take it. The XTR Will spool even better with a good tune! That DOM 1.5 xtr is worth the consideration too. When I originally drove to Cobb last summer they pushed the 7cm XT pretty hard for its streetability ( is that a word?- ha). Then the XTR's came out and I was they guy going " oh well". Good luck on the build!! If you go E85 do tune on summer blend! That way if you run spring/fall or winter blend less than 80% ethanol you'll be rich rather than lean! If you are tuned on winter blend and run summer blend you can run lean. |
06-19-2012, 09:15 PM | #21 | |
Member#: 282906
06-19-2012, 10:16 PM | #22 |
Member#: 305890
NWIC
I would rather be tuned on winter blend and run rich in the summer. I would never want to knowingly set my car up to run lean. During the winter with lower ambient temps your vehicle will be running a lot better and having a crappy blend on a tune for a better blend might cause some damage.
06-19-2012, 10:53 PM | #23 | |
Member#: 282906
If tuned on winter blend, you will run lean in summer. ( winter= rich blend more gas, less ethanol, summer: lean blend less gas, more ethanol). So, if you are tuned on a rich winter blend your car will run lean on summer blend= bad. |
06-19-2012, 11:34 PM | #24 | |
Member#: 282906
AFR at WOT I'll have to check. I've seen high 10-11 readings on my wideband at WOT. I'll log tomorrow AM. |
06-20-2012, 07:20 AM | #25 |
Member#: 170602
Wow that's rich for Doug and e85 it seems. Did he tune off your wideband or his? Jw.
TopSpeed Motorsports - **2011 STI** Invidia Race Header Tested!! | TopSpeed | NASIOC Project Cars | 79 | 02-22-2016 07:37 PM |
TopSpeed Motorsports - Now offering 2011 STI Shelf Maps | TopSpeed | Engine Management | 5 | 04-01-2011 12:55 PM |
TopSpeed SS1 \ RR1 Built Engines | TopSpeed | Engine/Power/Exhaust | 86 | 03-24-2011 10:39 PM |
TopSpeed Motorsports - 2011 STI Baseline & Protune Results! | TopSpeed | Proven Power Bragging | 18 | 01-15-2011 05:03 PM |
Topspeed SS1 Built Engines | TopSpeed | Engine/Power/Exhaust | 8 | 06-28-2010 08:51 AM |
