Welcome to the North American Subaru Impreza Owners Club Tuesday August 21, 2018
Old 03-18-2018, 11:07 PM   #1
SpeedlineWRX
Member#: 480811
2018 WRX
CWP
Default 2018 Base Wrx / Morimoto LED Fog Lights
Hey guys! I have a 2018 Base model WRX. The other day I purchased a pair of Morimoto XB LED fog lights. My question is besides having to purchase the bezels with the cutout in them do I need to get anything else? I have heard mixed things that the wiring is there already for them and also read that I have to buy harnesses and switches and other parts.
SpeedlineWRX is offline   Reply With Quote
Old 03-19-2018, 08:24 AM   #2
JDMSTA
Member#: 310615
1213 12'Sport+13'STi
I believe you only need to purchase the stock switch, relay, and possibly fuse. The wire harness should be all there already behind the bumper.
JDMSTA is offline   Reply With Quote
Old 03-19-2018, 06:04 PM   #3
SpeedlineWRX
Member#: 480811
2018 WRX
CWP
What type of fuse do I need? Sorry im a complete noob when it comes to lighting stuff..
Also this relay? http://www.morimotohid.com/wire-harn...relay-h11.html
Old 03-20-2018, 02:52 AM   #4
MrWRX17
Member#: 458676
2017 WRX
Did fog lights on my 17 and the plugs were not there. Not sure if they are the same. I am sorry to say this but check out subispeed their foglight harness may help you out.
MrWRX17 is offline   Reply With Quote
Old 03-20-2018, 09:50 AM   #5
JDMSTA
Member#: 310615
Its an oem relay that plugs right under the steering wheel dash area. Not an aftermarket one.
Old 05-31-2018, 10:38 PM   #6
Sean110822
Member#: 399632
Speedline, did you ever get to install the morimoto fog lights? I also have a 2018 base wrx that and I really want to install quality LEDs on without buying a $350 kit. I’m hoping to purchase the lights, relays, fuse and switch. I’d even be interested in a clean method to remove the uncut slot of the bezel instead of buying JDM or OEM bezels. I’d really appreciate any parts numbers, lessons learned, etc.
Sean110822 is offline   Reply With Quote
