Welcome to the North American Subaru Impreza Owners Club Tuesday August 21, 2018
Old 05-15-2018, 08:13 PM   #51
Crawford Performance
Member#: 42075
Here is a link that may help those of you installing the S0699 on a WRX: https://cdn.shopify.com/s/files/1/11...02367727621114
Crawford Performance is offline   Reply With Quote
Old 05-17-2018, 12:59 AM   #52
Subie_Jake
Member#: 479006
Hi, I'm trying to install a V3 on my 2015 WRX and I'm stuck trying to figure out how to connect the cooler lines to work in conjunction with the mishimoto oil cooler kit. Mishimoto provides a bypass valve that deletes the stock oil cooler lines. Would I need some connectors to make the two work together?
Subie_Jake is offline   Reply With Quote
Old 06-19-2018, 08:58 PM   #53
keiksmt
Member#: 295243
2011 WRX 5 door
Gun Metal Gray
Awesome updates on instruction, thanks.
However, mine did not include those 13" and 17" hose. Do I just cut from 43" and re-use it?or is there other way?
keiksmt is offline   Reply With Quote
Old 06-20-2018, 07:20 PM   #54
D3monicTun3r
Member#: 443609
2016 WRX
So does the V3 for the 15+ wrx use the coolant lines to heat the unit ?? i think i read something about its location no longer requiring the coolant lines ?
D3monicTun3r is offline   Reply With Quote
