Welcome to the North American Subaru Impreza Owners Club Tuesday August 21, 2018
Old 04-26-2018, 08:23 PM   #251
mikeyPSF
Member#: 236475
I didn't get a notification of a reply either. That's odd. I'll try to see if I can figure this out tomorrow for you. Yes, I do recall us swapping a support email last week.
mikeyPSF is offline   Reply With Quote
Old 04-27-2018, 09:31 AM   #252
TyranosaurusWRX
Member#: 25731
02 wrx(sold)/2005
Sti/ 93 Leg Wag
Thanks!
I'm anxiously awaiting my DLP....
TyranosaurusWRX is offline   Reply With Quote
Old 04-30-2018, 07:03 PM   #253
TyranosaurusWRX
Member#: 25731
02 wrx(sold)/2005
Sti/ 93 Leg Wag
My 05 ECU is unbricked (albeit not worth much atm) and my 04 is unCobbed, I'm super grateful! After 7 years this thread still provides.
Old 04-30-2018, 08:35 PM   #254
teds-rex
Member#: 400886
2004 STi
Originally Posted by TyranosaurusWRX View Post
Actually that was my original ecu, I have an 05. There are about 6 different wires to move to make the 04 work per the pinouts. So to clarify, the 05 ecu is burnt, the 04 from the scrap yard appears to be locked.
Yeah but I don't think that the 04 is "locked"... The 04 didn't have an emobilizer and the 05 does, so not sure on compatibility.
teds-rex is offline   Reply With Quote
Old 04-30-2018, 09:23 PM   #255
TyranosaurusWRX
Member#: 25731
02 wrx(sold)/2005
Sti/ 93 Leg Wag
Yeah the 04 was locked. I couldn't even connect to it via ecuflash, it would reject it every time. I can ID it now and I flashed my speed density map. The car is running on the 04 as we speak. With the 04 not having the immobilizer it bypasses it in the newer models as long as you rewire the harness per the 2004 pinouts, which was 6 wires. You just cant go the other way, and use a 2005+ without the chipped key, key barrel, and immobilizer box to go with it.
Old 06-28-2018, 09:01 PM   #256
Scotty4
Member#: 487723
Anyone still available to unbrick a 2004 STI ECU? I haven't got the time to build a kit.
Scotty4 is offline   Reply With Quote
Old 07-12-2018, 07:45 PM   #257
MadmanSean
Member#: 488256
Hi Scotty, this may or may not help you.
I'm able to do this, however i'm located in Australia. For anyone that might be interested and needs help with a bricked ECU please feel free to PM me
Here's a link to more Info: Subaru ECU Unbrick, Unlock, Recovery Service
http://forum.liberty.asn.au/viewtopic.php?f=56&t=35489
MadmanSean is offline   Reply With Quote
Old 07-12-2018, 09:14 PM   #258
teds-rex
Member#: 400886
2004 STi
Where are you located? No info in your profile
Old 07-23-2018, 05:23 PM   #259
Noah
( ͡ ͜ʖ ͡)
Member#: 111510
05 WRX 16 Xtrek
03 SV650S
Had an interesting one today. 2011 WRX. Tried using FDT and got the following:
Code:
Configuration:
'BOOT Mode' connection - using emulated interface
Opening port 'COM3' ...
Loading Comms DLL
Loaded Comms DLL
Initiating BOOT SCI sequence
Attempting 9600
Received immediate response from device: 0x80
Attempting 4800
Attempting 2400
Attempting 1200
Error No 15024: Boot failed
Error No 16132: Device does not support Protocol C
The board on this ECU is different from others I've done. I gave the ECUFlash SH boot mode recovery a shot but I got an error about
there are more memory areas in this CPU that will be erased than the ROM file you have has data for. write process aborted.
This is the 2nd ECU that I've had troubles reflashing. Has anyone seen a similar issue?
Noah is offline   Reply With Quote
How to Make an STI Look Like a Sleeper? FostersAFB General Community 92 10-12-2017 09:24 PM
How to remove an ecu Quackyboy Newbies & FAQs 9 04-22-2010 09:26 AM
How bad is it on the tranny to treat an auto like a manual? thrillho Transmission (AT/MT) & Driveline 8 06-07-2004 08:23 AM
Want to learn how to tune an ECU...and actually do it on a real dyno? 2000vfr800 Engine Management & Tuning 9 03-19-2003 02:20 PM
How long for an ECU to reset w/ no flash? Keith99RS New England Impreza Club Forum -- NESIC 0 08-22-2002 03:28 PM
