![]() Tire & Wheel Forum sponsored by The Tire Rack |
#5876 |
Member#: 498642
Vehicle:'19 WRX Ltd 6M dgm '08 Mustang GT (the toy) |
![]() When chasing wide wheel widths, you have to put function over form. Find out what fits and only then choose a wheel mfr or model from among the choices that fit.
Start by searching for wheels that do not need any spacer to clear the Brembos. Usually the clearance issue is the back side of the spokes not clearing the faces of the calipers, though for some wheels there is taper in the barrel that fouls the outer "diameter" of the calipers. So that's two more things to check (in addition to strut and fender clearances). Norm
#5877 |
Member#: 339923
Vehicle:2006 Impreza WRX STi grey |
![]() ^ i get that. i'm looking more for who has and what can i do to modify front fenders and can i modify them to fit a 275/35 tire functionally. i have heard of people putting washers on the fenders so they are pushed out further. and of course rolling and pulling. am i missing something?, i just cant find anyone running that setup that has discussed what was done up front.
#5878 |
Member#: 339923
#5879 |
Member#: 490131
South East
Vehicle:2005 Impreza WRX WRB |
![]() year: 2005
model: WRX wheel model: Method Race Wheels MR502 wheel size/offset: 17x8 5x100 +38 tire brand/model: Michelin Pilot Sport 4S tire size: 225/45ZR17 suspension: Tein Type HG Coilovers 1in lower than stock alignment: stock fender mods: S11 WRC fenders (+80mm per side) spacers: None Recommendations on this set up? still the daily driver right now, but want a configuration to do tarmac and rally. Basically run it and still be able to drive it home. |
#5880 | |
Member#: 339923
![]() Quote:
for rally people typically use suspension to lift the cars, and a narrower tire. i cant speak much to that. |
#5881 |
Member#: 142954
Vehicle:2003 |
![]() Will 18x9.5 +10 with 275/35 tires fit my 2015 wrx with stock suspension without rubbing?
#5882 |
Member#: 498642
![]() I've got serious doubts . . . here's how what you're proposing compares to OE (well over 2" further out on the outside, with about 30 mm of unused space on the inboard side that could be used to cut the amount of poke down to something that might work).
![]() Norm |
#5883 |
Member#: 339923
![]() i doubt so with that offset. that would poke quite a bit. i did have a friend who ran 18x9.5+35 with 275/35 tires on his 2016 sti. although he did have coils and i think he rolled his fenders too. i dont believe they were pulled but i'm not sure about that
#5884 | |
Member#: 490131
South East
![]() Quote:
#5885 | |
Member#: 339923
![]() Quote:
with a wrc style widebody i believe you could fit an 18x10.5 and run like a 295 tire. but double check that and dont take my word on it. i'd have to double check myself to be sure. |
#5886 |
Member#: 258227
![]() I have been searching around and hopefully someone can help out. I am looking at a set of 17 inch Enkei PF01's on a 2017 Base WRX. I want it to be a as close to the stock 17 inch wheel size so I can keep the stock tire size of 235/45r17. Would the 45 inset on an 8 inch wheel fit without rubbing? Thank you .
#5887 |
Member#: 497907
Vehicle:2019 WRX STi White |
![]() year: 2019
model: WRX STi wheel model: Work Emotion CR Kiwami wheel size/offset: 18x9.5 +38mm tire brand/model: Michelin Pilot Sport AS4 tire size: 255/35/18 suspension: Tein Flex A with about 1.5 inch drop camber: -1.7 front, -1.4 rear fender mods: None spacers: None I thought it would be flush, but it looks like it pokes slightly in the rear. Not rubbing yet, but kind of worried that it will. |
#5888 |
Member#: 514502
![]() Year: 2017
Model: WRX Wheel Model: Fifteen52 Turbomac Wheel size/offset: 18x8.5 +30 Tire size: Recommendations? Suspension: Stock Alignment: Stock Fender Mods: Don't really want to do any Thanks! Last edited by fn5jason; 10-28-2020 at 09:36 PM. |
#5889 |
Member#: 326759
Vehicle:00 JDM Impreza WRX WR Blue |
![]() I’m wondering if a 225/65R17 setup would work on a stock height bugeye.
I was about to install whiteline springs and KYB struts, but didn’t know if it would fit under that too. So I can keep it stock height or if they will fit the lowered set up I’d like to do that. Can anyone confirm fitment? |
#5890 |
Member#: 411914
Vehicle:2004 Sti Black |
![]() Hoping someone can help!!! I have an 04 sti, I’m the original owner too. It’s been in storage for a few years and I think it’s time to pull her out. Car is on tein mono coilovers with oem bbs powder coated cherry blossom “pink” I’m really wanting a set of volk te37 in bronze 17x8.5 5x100 +45 for tires Advan ao52 255/40r17. Will these wheels clear the brembo’s? Will I have to roll the rear fender? I can’t find a confirmation this combo works.
#5891 | |
Member#: 517135
![]() Quote:
#5892 |
Member#: 521946
![]() Hi Guys
Noob here... tried to search first! But didn't turn up a result. 2006 Legacy Wagon 2.5i, dead stock suspension/ride height. Have some very crappy 205/50/17's on it now, and they are terrible in even light snow. Found a great deal on the more common size, Continental DWS which are 215/50/17. Will these fit on the stock 17" wheels, and suspension? I've measured with my hand, and seems like lots of space in the rear - front I can easily get my hand in from the tire to strut, I can't see any issue with going 10mm wider, and concerns with the slight height difference? From what I can tell my existing tire diameter measure just a hare over 25" but the setup with the Conti's will be 25.5". This tire doesn't show up as an alternate size option (215/45/17 is) but I know that if anybody knows what fits its you guys. Thanks! |
#5893 |
Member#: 497749
![]() Hi,
If you have a 2015-2019 WRX or STI, you can try this wheel calculator : https://wheel-it-fit.com Thank you Dominic |
#5894 | |
Member#: 498642
![]() Quote:
Be nice if you could at least get a demo view . . . Norm |
#5895 |
Member#: 392890
Vehicle:2005 STI Silver |
![]() I think last time I posted I was on Tein Basics. Now I'm on RCE T0. Wheels are Gram Lights 57DR 18x9.5 +38, 255 35 Firestone Firehawk. Other suspension mods: whiteline sways and lateral links.
#5896 | |
Member#: 497749
![]() Quote:
Thanks |
#5897 | |
Member#: 498642
![]() Quote:
Just to make sure we're talking about the same thing . . . does it include about a 40% of rim width change as rim width varies from "measuring width"? Both sidewall shape and clearances are affected. I'm using curve fits for the upper and lower sidewalls. ![]() Norm |
#5898 |
Member#: 497749
the motorsport fitment thread: because race car! | nhat | Tire & Wheel | 45 | 11-20-2011 04:21 PM |
the official wheel/tire fitment thread: all fitment questions go here! | nhat | Tire & Wheel | 1086 | 06-15-2011 02:02 AM |
where did the wheel fitment chart go? | PoopRSkupe | Brakes, Steering & Suspension | 0 | 01-26-2004 02:36 PM |
A thread in the STi forum to keep it alive (because STi forum is closing) | Eric SS | Off-Topic | 6 | 09-10-2003 04:54 PM |
