Welcome to the North American Subaru Impreza Owners Club Monday June 17, 2019
Old 06-12-2019, 06:03 PM   #1
pcampbell
Member#: 437670
2005 2.5 SC OB
Default Timing/boost vs RPM chart
Been working on tuning this thing on the street.... Still increasing timing with no knock on EJ253 with 12psi supercharger. Any thoughts on where I should focus or where I can get away with adding a bit more timing? AFRs are fat, 10.5 but that includes lots of 50/50 water meth, meaning the gas AFR is more like 12:1.
If timing increases with RPM but decrease timing with boost, should the timing line look more flat?
pcampbell is offline   Reply With Quote
Old 06-15-2019, 12:40 PM   #2
pcampbell
Member#: 437670
2005 2.5 SC OB
Iím trying to pull the bottom end timing up, that is where it feels a bit sluggish. Iím not knocking at all though so the question is when do I call it good enough? Keep in mind this is a 10:1 static CR motor, not 8.x. Iíve seen people talk about 30 deg timing at redline on a 257 with 15psi. Maybe I will try to get it around 20deg across the board and tinker with it from there. Iím doing it on the road so I really donít know when I hit max torque.
