04-03-2002, 03:03 PM | #1 |
Member#: 13901
Vehicle:2002 WRX Sedan WRB |
Help, can't find part for boost gauge
I bought the Defi HUD boost gauge kit. The T-fitting that comes with it is too loose for the WRX. So I need a 1/4, 1/4, with 1/8 (middle) T-connector. 1/4 Connector for WRX side, 1/8 connector for sender unit. I've been to 5 auto parts stores (including 2 different napa's) in the area and they all look at me like ***. Haven't been to pep boys, the nearest one to me is Nashua and will try that when I have a free weekend to dedicate a long trip to and see if they have it. Can anyone recommend a decent store in the boston area that might have this part? Online even?
Thanks! No univeral connector either, please! They had this universal connector that you can cut down to size, but the size drops from like 1/16 to 1/4 and the holes are internal holes are small even for the 1/4 size on this connector, then the chamber opens up, causing what I think is some kind of turbluance because the readings I get from this universal connector is whacked! Boost goes starts to increase as I accelerate above 1000 rpm, but above 2000 rpm it goes more negative.
04-03-2002, 03:30 PM | #2 |
Member#: 10821
NESIC
Vehicle:2008 WRB STi |
I have the same problem (so no solution here in this post ). But I am currently using the universal T as a temporary solution. I clamped all the 1/4 inch ends and all is well.
I tried to find metal T's of that size and came empty handed from various auto-parts stores (yes, the glazed look ). I do know that Omori sells a brass T that fits. (part # P-94) But they charge $12 for it... Let me know if you found a good solution. take care, - Alex |
04-03-2002, 03:39 PM | #3 |
Member#: 4347
NESIC
Vehicle:2006 2.5i Wagon Aspen White |
I just used very small hose clamps, but then again I'm not sure where you tapped into. Mine is tapped off the manifold.
-John |
04-03-2002, 03:40 PM | #4 |
Member#: 1501
NESIC
Vehicle:2009 WRX wagon Dark grey |
That's weird. The piece I got with my Defi boost gauge worked just fine.
04-03-2002, 03:48 PM | #5 |
Precious ❄
Member#: 603
NESIC
Try a hardware store. I found all sorts of weird fittings at Sears Hardware when I was putting the boost controller in my Galant.
04-03-2002, 05:17 PM | #6 |
Member#: 1676
NESIC
Vehicle:98RS w/ EJ257/Dom 2014 Tesla Model S P85 |
Home Depot also has a good selection of Ts and adapters in the plumbing section.
04-03-2002, 05:18 PM | #7 |
Member#: 15986
Vehicle:2002 WRX wagon |
I found various T fittings (plastic and then I used hose clamps) at the Pep Boys in Dedham off of Rte 1. You might want to try them.
Good luck! |
04-09-2002, 09:20 AM | #8 |
Member#: 13901
Did some more running around last week.
Hardware store... No Sears... No Home Depot... No Would up going to Pep Boys in Nashua, got 1/4-1/4-1/4 T connector then a 1/4-3/16 connector and did it that way. Now to figure out if I hooked up the illumination wire corrector. The HUD is impossible to see during dusk, and it doesn't adjust when you adjust the rest of interior brightness. |
04-09-2002, 03:44 PM | #9 | |
Member#: 4347
NESIC
Also, you can't change how dim/light it is with the rest of the interior lights. It's either full bright, or partial. The wire only tells it to run in dim mode. -John |
04-09-2002, 04:40 PM | #10 | |
Member#: 13901
That's good to know that there's only one dim mode, so maybe I did pick the right wire, providing that orange 'illumination -' doesn't make it brighter. |
04-09-2002, 05:46 PM | #11 |
Member#: 4347
NESIC
If you can see it fine during the daytime, then you hooked it up correctly. I remember not being able to see it if it was raining and I had my lights on. It gets alot darker.
-John |
Where to find restrictor for boost gauge? | ringe | Newbies & FAQs | 4 | 02-01-2008 02:41 PM |
Help me find replacements for stock gauge | TylerTR | Interior & Exterior Modification | 7 | 12-12-2005 12:35 AM |
NEED HELP, lost all parts for boost gauge, what do i need? | RossWRX | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 3 | 10-05-2002 12:38 PM |
Need help finding parts for turbo gauge install | scoot1212 | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 2 | 08-15-2002 03:30 PM |
Parts for boost gauge install in Nebraska? | Verist | Mid West Subaru Owners Club Forum -- MWSOC | 3 | 08-03-2001 11:20 AM |
