Welcome to the North American Subaru Impreza Owners Club Thursday October 18, 2018
Old 01-26-2009, 03:09 PM   #1
Cyclops
Member#: 95017
2000 2.2RSTI stroker
2010 SWP STI
Default 2002 WRX to 2000 2.5rs swap, will it work?
Hey guys,
I have a 2002 WRX wagon with an 07 6 speed and a bunch of other stuff. I am taking out the tranny and I need another stock replacement. Will a 2000 2.5rs tranny, clutch, flywheel, rear diff, axles, control arms, lateral links, knuckles, and hubs fit my 2002 WRX? Are the ABS sensors the same? I've got a 2000 2.5rs that runs and drives and I thought maybe I'd just swap it all over to the wagon. I know the rear tophats are different on the RS but I can probably figure that out.
Cyclops is offline   Reply With Quote
Old 02-03-2009, 06:49 PM   #2
Cyclops
Member#: 95017
2010 SWP STI
Bump to see if anyone knows.
Old 02-03-2009, 09:35 PM   #3
mannac
Member#: 161038
2014 FiST
I don't know how the lengths on most of those parts compare. In addition, you would need the rs starter and a stage 1 rs clutch which will run you around $400.
Why do you want to do all of this?
mannac is offline   Reply With Quote
Old 02-04-2009, 12:29 AM   #4
Cyclops
Member#: 95017
2010 SWP STI
I have a 2002 WRX with a 6 speed and all the goodies. I have a 2000 RS that will be the new home for the 6 speed. I thought maybe I could just trade between them instead of putting the 6 speed in the RS, selling the RS tranny, then buying the WRX tranny.
Old 02-04-2009, 03:19 AM   #5
kaos200
Member#: 2692
Yes it will work.
What rear subframes are on both cars at the moment? The RS I'm assuming stock, but the WRX?
Edit:
What ABS pump/wiring in the WRX? 07 STi? You'll transfer that over to the RS, and then what? I wouldn't put the RS ABS unit/wiring etc into the WRX wagon.
kaos200 is offline   Reply With Quote
2000 2.5rs Swap to Ver. 4 STi w/ Goodies boostin05blacksti Member's Car Gallery 50 11-25-2011 12:01 AM
2000 2.5RS swapped sidewayz Tri-State Area Private Classifieds 20 03-04-2010 03:52 PM
02 2.0 WRX flywheel in an 03 2.5 Legacy, will it work? meandean Transmission (AT/MT) & Driveline 3 11-15-2006 11:45 PM
04/05 STi ecu swap...will it work? SupraScooby Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 10 11-08-2004 12:30 PM
Tranny Swap...Will it work? Boost4U Transmission (AT/MT) & Driveline 1 07-30-2003 01:41 PM
