06-09-2004, 11:56 PM | #101 |
Member#: 50488
Vehicle:1999 GC8 ej20g! Black |
Have you gotten into your project yet Matt? You are the uber Subu-Guru. I'd like to see a work in progress or a working product :P AND PICS!
06-10-2004, 12:41 AM | #102 |
Member#: 832
RMIC
Vehicle:99 2.5RS, '85 911 '73 914 and 2012 BRZ |
There's a thread here in conversions. And it has pics. Old engine is out. New engine is pretty much ready for insertion. I pulled the dash and started to strip the wiring harness the other day. I need to get it out, replace the fuel pump and drop the engine, and it is done. The only thing I am missing is the pump and exchanger for the AWIC and the wastegate control solenoid/pressure sensor stuff. The first two are easy. The other stuff has been challenging. every local Legacy turbo I have found for 2 months has already had them stripped from the car...
06-10-2004, 04:37 AM | #103 |
Member#: 43916
RMIC
Vehicle:2001 Impreza 4.7 Blue Ridge Pearl |
wheres the meet and when? ill try to come. i want to see all of the other scoobies.
also, where are the presure sensors and wastgate control solenoid on the cars. there are 2 legacy turbos at my local junkyard, but they dont have engines. i can check the harnesses for you. |
06-10-2004, 11:47 AM | #104 |
Member#: 50488
Man that stinks, you wouldnt think they would all be stripped :P
06-10-2004, 12:37 PM | #105 | |
Member#: 832
RMIC
The meet is at Flat4 in Thornton on 104th on friday from 6-10pm. ESX will have their 9 second drag subby there as well as a car show, a DJ and a GT3 competition. Shoot me a PM and we can discuss further... |
06-16-2004, 08:36 PM | #106 |
Member#: 50488
I tried PMing you for pics. Though the car isn't "totally" done because it has to be repainted
Damn Smacksube's little brothers friend and his bee-bee gun. Law Suit takes a month or so too |
06-18-2004, 11:37 PM | #107 |
Member#: 53243
06-19-2004, 10:22 AM | #108 |
Member#: 50488
Cool. I am going to my mechanics today. I goto take pics to post stuff for sale and I will try to snap a few others as well of the finished product. Sucks though all the damn marks on the body from smacksube
06-30-2004, 04:13 AM | #109 |
Guest
Member#:
hi every one,
i am new to this forum and i just got done with a EJ207 Sti onto my 2.5 RS. Everything is fine, beside that my CEL constantly flashing. It doesn't seems to try to show a code, but just constant flash. It will only start flashing if i put it in gear and drive it and the flash will stay on until i plug up the "green plug". Also i can't read codes with US OBD2 machines. Is that normal?Does anyone know what's wrong with it? Thanks |
06-30-2004, 12:01 PM | #110 |
Member#: 50488
OBD 1 lets off 5 fast flashes for an OK code. OBD2 I am not sure of.
06-30-2004, 03:23 PM | #111 |
Guest
Member#:
ic....thank you....do you happen to know anyone that run into the same problem?
06-30-2004, 03:40 PM | #112 |
Guest
Member#:
also let say if my constantly flashing code is a OK code, then what should i do to clear it? Thanks
06-30-2004, 08:48 PM | #113 |
Member#: 50488
It will continue to flash atleast as soon as you turn it on. Then stop. Again this is with OBD1. As for OBD2 I am not sure. You can put the ECU into reset mode though and it clears all the error codes from the ROM.
06-30-2004, 11:13 PM | #114 |
Member#: 832
RMIC
Do you have your diagnostic mode connectors still connected? Once you have run the diagnostics, you are supposed to disconnect them...
07-01-2004, 04:00 AM | #115 |
Guest
Member#:
u mean the green plug? I connect it to start the car, that will take off my engine light. Then i unplug it. But when i put it in gear and drive it, CEL comes on again. Also how can i put the ECU into rest mode?
10-19-2004, 11:39 PM | #116 | |
Member#: 64125
Vehicle:2007 WRX Urban Grey Metallic |
i know im bringing an old post from the dead..... shh... |
10-20-2004, 12:34 AM | #117 |
Member#: 2289
Vehicle:1998 11.87@112mph Subaru L Ver 6 STi Type R |
Its been a while since i seen any go that cheap. I was looking at engines on ebay the other night and i saw the ej20tt going for a grand and people bidding on it too. Back in the day you couldnt get 600 for them. I guess i am old school. I can remeber typing subaru in ebay and only getting 150 matches and not one of them being anything remotely performance related.
10-20-2004, 05:35 PM | #118 |
Member#: 832
RMIC
yeah,
$300 was back in the day before the WRX hit and got popular. Now a basic EJ20G out of a Legacy runs $650, minimum... |
05-15-2005, 06:40 PM | #119 |
Member#: 85384
Vehicle:1997 Impreza Black |
why didnt you just get a front clip?
10-31-2005, 10:01 AM | #120 |
Member#: 8399
Vehicle:GC8 JDM STI V swap cardinal red |
sensors plug in a EJ20G
Will the sensors from my 95 1.8 ECU plug into the EJ20G ok?
What about a EJ20TT (If all the twin turbo crap was ripped off it and it converted to a single turbo setup with my turbo kit I already have). What difference would it make if I got an engine with a cut wiring harness what does that mean? It is cut before the adapter harness leaving just a string of multi-colored wires. I wouldn't need to use the harness if I was just plugging the sensors from my 1.8 to the new engine would I ? |
12-14-2015, 03:56 PM | #121 |
Member#: 427121
Throttle cable
Currently doing a 98 JDM wrx swap to my 2000 Legacy. Having some trouble with the throttle cable, I know this is a thread from forever ago but does anyone know how to make it work? Currently using an 02 wrx cable but it doesn't seem to have enough exposed cable. Any advice?
01-03-2016, 05:58 PM | #122 |
Member#: 101865
NWIC
Vehicle:88 GL-10 STi silver |
i have done a number of swaps. i have used different cables. but have always had to cut and modify the bracket to make it fit. AKA cut and weld it.
01-03-2016, 07:08 PM | #123 |
Member#: 369969
Vehicle:1998 Impreza Outback Black |
Bump.
10-15-2017, 04:23 AM | #124 |
Member#: 373757
Vehicle:2009 Forester XT Dark Grey Metallic |
Awesome thread! I'm looking to do a swap like this on my 99 Forester and this will definitely help me out!
step by step tsx projector swap instructions | verdee | Interior & Exterior Modification | 8 | 04-02-2008 06:39 PM |
help me!! pls give me the step by step process!! | Mr. SUAVE | Electrical & Lighting | 3 | 12-20-2005 04:51 PM |
help me!! pls give me the step by step process!! | Mr. SUAVE | General Community | 17 | 12-20-2005 01:04 PM |
step by step swap | stu | Subaru Conversions | 3 | 09-08-2005 06:33 PM |
EJ20G swap done, minor questions now... | Structure828 | Subaru Conversions | 4 | 05-17-2004 06:34 PM |
