Welcome to the North American Subaru Impreza Owners Club Friday March 29, 2024
Go Back   NASIOC > NASIOC Subaru Models > Baja Forum
Old 04-18-2021, 02:40 PM   #301
Chi_San
Member#: 53558
2005 Baja Turbo
White/Silver/Black 3tone
Originally Posted by 2-fast View Post
see some turbo kits on Xcceleration's website: https://www.xcceleration.com/engine-packages.html
they are for the NAs, might be worth checking with them to see if they fit the Baja Sport...
If you're gonna boost a NA Subaru, you might as well get a supercharger kit. https://raptorsc.com.au/subaru/impre...y00-myo5-kits/
Chi_San is offline   Reply With Quote
Old 08-26-2023, 04:15 PM   #302
Zadok
Member#: 38360
2006 Baja Turbo 5MT
Atlantic Blue Pearl
Default What about sway bars???
Been looking into sway bar options recently and not finding a whole lot of info.
I heard that the Tribeca front swaybar is 25mm and will work, but nothing other than Whiteline 20mm for the rear.
What have you guys done on yours?
I’m sure the guys with the slammed bajas put something bigger on.
Zadok is offline   Reply With Quote
Old 12-30-2023, 12:24 PM   #303
deanrocker
Member#: 536525
Thanks for the info. I have an 06 MT Baja Turbo. I need to swap the ECU. HOWEVER, the engine was swapped from 2.55 to a JDM 2.0. Everything was working great, except cruise control, until the vehicle was briefly flooded up the seats. I'm told the ECU is likely damaged.
What should I get for a replacement ECU? One that is a straight swapout for the one currently in it, that was for the 2.55 engine, or one that is geared for a 2.0 engine?
Thanks.
deanrocker is offline   Reply With Quote
clutch and flywheel what works with what?!?! scobaru Subaru Conversions 10 01-06-2005 10:21 PM
What Works with Borla Hush? HerculesPeanut Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 06-28-2004 04:21 PM
ej20's and what works with what scobaru Subaru Conversions 4 10-24-2003 07:28 PM
Advan RG works with what brakes??? Subaruist Brakes, Steering & Suspension 1 10-22-2002 11:23 PM
Which cold air intakes work with what FMICs? Diversion Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 14 07-15-2002 07:55 AM
