Welcome to the North American Subaru Impreza Owners Club Wednesday September 27, 2023
Old 04-16-2002, 12:18 PM   #1
SillyAssKilby
Member#: 9559
Question Lets Talk About Sway Bars
I have a set of Cusco sway bars on the way. I am just trying to get a little info on the adjustable settings. You have three holes on the ends of the rear bars. Lets call them 1-3. Hole 1 is at the end, and hole 3 is the farthest in. What would the settings be then. Which would be the most benificial(sp?) to get rid of the stock understeer.
Thanks for any help.
By the way I did a search.:monkey:
SillyAssKilby is offline   Reply With Quote
Old 04-16-2002, 12:54 PM   #2
Jaxx
Member#: 177
The 93 W/EJ20K-sold
Subaru-less :(
think about it live a see saw .. the further out you are teh less weight you have to have to balance the see saw .. or the further you the greater mechanical advantage you have ...
so by your numberin setup 1 is the lowest 3 is the highest
with stock suspension.. start at 1 then work your way up
Old 04-16-2002, 12:57 PM   #3
SillyAssKilby
Member#: 9559
Thanks for the help. I get it now.
Old 04-16-2002, 02:48 PM   #4
Coati
Member#: 9106
2015 FXT - DGM
2008 STI - Aspen White
Dont forget that three holes on each side means you have 5 possible resistance levels.
Well, six really, but who would put one at each extreme?
Coati is offline   Reply With Quote
Old 04-16-2002, 02:49 PM   #5
Siper2
Member#: 1134
2015 Outback H-6
Exactly. I have the Whiteline adjustable rear bar, and the hole furthest out is the 18mm setting. Center is 20mm, and the furthest in is 22mm.
I've had it set at 18mm since day one.
-S2-
Siper2 is offline   Reply With Quote
Lets talk about head work and raising the redline Red Rocket Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 14 06-14-2002 04:41 AM
Lets talk about headers JaMa Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 23 04-22-2002 01:35 AM
Ok lets talk about TEC III or II WRBLUEWAGON Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 29 04-04-2002 12:10 PM
Lets talk about brakes JaMa Brakes, Steering & Suspension 44 01-15-2002 08:40 AM
