Welcome to the North American Subaru Impreza Owners Club Thursday March 28, 2024
Old 11-25-2019, 07:52 AM   #376
bluesubie
Member#: 767
04 FXT
20 OB Onyx XT
Originally Posted by acsclio View Post
Hello I have a sti ej257b enginne
I been use 5/30 redline with 1.5 qt at oil consumption between 6000 kms oil intervals.
Thinks swicht at summer
5/40 xcesss motul
5/40 amoils European cars (the long life I'm not extend the oil intervals)
I can't get here in Chile the Rotella t5.
Only the hellix 5/40
Any experience with motul or amoils European.
Or just is better continue with redline
Also I was thinking go 5/40redline but I thinks the hths goes to high?
Thanks
All of the oils you mentioned are great choices. If Shell Helix 5W-40 is the least expensive option, I’d go with that. You’re right, RL 5W-40 has a higher HTHS than you probably need.
Old 11-27-2019, 09:32 AM   #377
acsclio
Member#: 317366
Excelent thanks
the helix is the expensive of those.. almost 100uss the 5 quarter
The motul is the cheapest one...
acsclio is offline   Reply With Quote
Old 11-27-2019, 01:37 PM   #378
bluesubie
Member#: 767
04 FXT
20 OB Onyx XT
Wow!
Also, the only that that helped with my consumption was switching to 10W-40. Even when using 0W-40 in winter I’ll use 10W-40 for top ups.
Old 11-28-2019, 08:38 PM   #379
acsclio
Member#: 317366
Wow!
I try liqui molly 10/40 for 3 times
and the oil consumption was just 1/2 quart of oil..at 6000 kms interval
But i don't know if run a 10/40 at ej257 turbo engine is ok
here the winter we got -3 celsius and summer around 35 c of peak.
thanks
Old 01-04-2020, 06:29 PM   #380
turboblew
Member#: 508225
2006 Subaru
Fusia
who do you think is producing this oil for Kirkland???
https://www.costco.com/kirkland-sign...100527865.html
10 quarts for $30 is a deal! Thats 1990s earl prices!!
turboblew is offline   Reply With Quote
Old 01-05-2020, 10:12 AM   #381
bluesubie
Member#: 767
04 FXT
20 OB Onyx XT
Default The NASIOC Oil Selection Guide
A good bargain oil that meets the same specs as the big names. Made by Warren Distribution which makes dozens of private label brands like Super Tech and Amazon Basics. They even share the same dexos license number across the same viscosities.
https://www.bobistheoilguy.com/forum...f-youre-intere
Old 02-01-2020, 07:06 PM   #382
GK1707
Member#: 373868
'04 STi
Anyone have any feedback on Motul Xcess 8100 5W40?
I picked up a jug of it and gonna be changing it next weekend to give it a try. Switching over from T6 on my built motor.
GK1707 is offline   Reply With Quote
Old 02-03-2020, 12:17 AM   #383
Speed Assault
Member#: 289598
2008 impreza wrx
You are moving up into quality thats good.
I used it and had great results among the usuall oils on the nasioc list, no burning, good MGP
Im now on the best oil you can buy which is Liqui Moly 10w 40.
Liqui Moly 85w 90 for Trans and rear
Speed Assault is offline   Reply With Quote
Old 02-03-2020, 07:48 AM   #384
bluesubie
Member#: 767
04 FXT
20 OB Onyx XT
You’re good.
APPROVALS
BMW LL-01
MB-Approval 229.5
Porsche A40
Renault RN0700 under N° RN0700-10-70 Renault RN0710 under N° RN0710-10-43 VW 502 00 – 505 00
Old 02-03-2020, 01:40 PM   #385
Waddlz
Member#: 395275
2012 STi
Wow!
10w-40 helped consumption?
The wifes WRX seems to consume about 1 quart per 3500 miles.
I've tried:
Mobil 1 0w-40
Rotella T6 5w-40
Amsoil 0w-40
I may try 10w-40 to see if it helps at all.
Waddlz is offline   Reply With Quote
Old 03-12-2020, 06:56 PM   #386
GK1707
Member#: 373868
'04 STi
Just wanted to get some input from everyone on oil pressures. Whats the norm you guys are seeing?
When I ran Rotella T6 i had consistent
- 80-90psi cold start
- 15-17psi at warm idle
- roughly ~66psi highway pressure driving at 3K RPM
I just switched over to Motul Xcess 5W40 about a month ago and see
- 80-90psi at cold starts.
- 13-15psi warm idle
- 62-64psi highway pressure at 3k RPM
Nothing else on the car has change but the oil and OEM filter. Seems with Motul, PSI has dropped at warm idle and highway driving not by a significant amount but just a few PSI which makes me wonder is it thinner? What could be the cause?
What's the normal oil psi you all are seeing at idle (cold and warm) as well as highway cruising?
Old 03-12-2020, 10:43 PM   #387
bluesubie
Member#: 767
04 FXT
20 OB Onyx XT
If you’re talking about the recent version of RT6 5W-40, the kinematic viscosity of both oils @100C is the same. 14.2 cSt’s. The HTHS is actually lower on the X-cess at 3.7. I understand that the old version of RT6 is 4.0 and not sure on the newer version.
This could explain your minor difference in oil pressure. See Section 3 of the Oil Selection guide for info on viscosity.
For more detailed reading on HTHS check out:
https://www.bobistheoilguy.com/forum...Number=1988816
And an HTHS history lesson:
https://www.bobistheoilguy.com/forum.../530501/1/hths
Old 03-24-2020, 08:59 PM   #388
allturbos
Member#: 512862
Default Oil consumption and test of high mileage oil
Hi All,
Just posting this incase someone was wondering specifically Valvoline Full Synthetic MaxLife, a high mileage oil really works or not.
Some background, I'm driving a 2009 Forester 2.5 non turbo. For several years it's been consistently consuming about 1L of oil every 4000KM driving. Mind you the car has nearly 220,000km on it. I was not the first owner of the car, I had it since 2011 eventually developed a bad head gasket which was replaced.
On a side note, I noticed that many people seem feel oil consumption is something really bad, and maybe it is in some cases, but for me, as i mentioned, my foresters been consuming oil since as long as I can remember. I was shocked though when i first discovered, when I slightly missed an oil change interval that, the dipstick didn't register anything.
Anyhow this is just a post for those interested. I've been using Motul Synthetic 8100 X-Clean for 9 years.
And for interest sake I decided to try out the Valvoline Full Synthetic MaxLife. I found it on walmart once at a good price, like 3 x 5l for 75$ in Canada.
Currently I am about 500km into this oil. And these are my observations.
My mileage has increased. Before I was averaging 11.6 L/100km. And now i've been getting 10.6 L/100km. Now for the test, this is my wife's daily driver, and she doesn't know I'm experimenting, so she drives the way she usually does.
I will probably post up another post at 3000km. Specifically because I will check the oil level at that point. If this oil is worse than the motul I'd want to make sure i don't run low. I'm kind of hoping this high mileage oil has some real benefits. Especially for it's occasional good prices. And if it is better than maybe I've helped others who worry about oil consumption.
allturbos is offline   Reply With Quote
Old 03-24-2020, 10:09 PM   #389
bluesubie
Member#: 767
04 FXT
20 OB Onyx XT
I wouldn’t even bother with Full Synthetic in a 2009 Forester. I just looked up the specs on MaxLife and the viscosity of the 5W-30 Synthetic Blend is actually thicker at operating temp than the Full Synthetic.
Although a 10W-30 is usually more stable and should be better at curbing consumption. Sometimes HM oils work and sometimes they don’t. Like I mentioned above, I have the lowest consumption running HM 10W-40.
Old 03-25-2020, 10:09 PM   #390
allturbos
Member#: 512862
I've been told that as well that heavier weight oil will slow down consumption. I haven't gone that route because the problem isn't all that bad yet. I mean again many people seem to worry that it's consuming oil at all. But in practicality if I do an oil change with a 5L package, I still have about 1L left over, if i consume 1L during the 4000km , I can just top it up with the remaining oil.
Also I read from a 5W to a 10W might change the characteristics at cold start up which keep the oil from flowing well. It does get pretty cold up here in Canada so, better not risk it, for now.
Still though.. I'm interested in whether this particular product works or not since it is occasionally priced very well for a synthetic let alone a HM synthetic.
As well, it might help in identifying the problem in the first place. Since HM oils claim to help rejuvinate seals, if it works maybe it's the seals. If it doesn't, then perhaps it's something else, maybe just cylinder/piston ring wear of age.
And yes i saw the specs, it's definitely not as good as motul for driving hard. And it's an old car, I don't really drive it like that.. I have an STI for that purpose =) although, I also really don't drive my STI hard either.
Old 03-31-2020, 11:20 PM   #391
Arcanum_STI
Member#: 511103
2021 WRX STI
I've got a 2019 STI with just a catback exhaust. currently at 9,000 miles & I use:
-Castrol Edge Titanium Full-Synthetic 5W-30
Arcanum_STI is offline   Reply With Quote
Old 04-12-2020, 09:08 PM   #392
LaneT
Member#: 513640
***128077;***128077;bet that took along time to type
LaneT is offline   Reply With Quote
Old 04-13-2020, 11:12 PM   #393
GK1707
Member#: 373868
'04 STi
Anyone have any experience with the new Rotella T6 15w40?
Old 09-23-2020, 05:46 AM   #394
boxerbug
Member#: 518829
Talking Liqui Moly 10w40?
Anyone know how well Liqui Moly 10w40 would stand up to the other oils mentioned in this thread?
HTML Code:
https://pim.liqui-moly.de/pidoc/P000315/1300-SuperLeichtlauf10W-40-41.0-en.pdf
This is the oil's information. It has a HTHS of 3.5.
Thanks!
boxerbug is offline   Reply With Quote
Old 10-20-2020, 11:33 AM   #395
Fino
Member#: 417685
'03 V7 EJ207, 6MT
Sonic Yellow
Is it worth switching to Motul Xcess 8100 5W40 from Rotella T6? I have a 400whp JDM EJ207 that doesn't burn a drop of oil between OCI's and I'm a little hesitant to switch because the Motul is much more expensive and T6 seems to work really well. Winter is coming and temps can get as low as 0*, so maybe I should look into a 0W-40? Thoughts?
Fino is offline   Reply With Quote
Old 10-21-2020, 11:39 AM   #396
bluesubie
Member#: 767
04 FXT
20 OB Onyx XT
HTML Code:
Thanks!
Yes, it should stand up well.
You'll be fine with a 5W-40. My FXT owner's manual actually lists 10W-40 as being acceptable down to -4F. With the exception of something like 300V or Red Line 0W-40, most 0W-40's are thinner at operating temp and have a lower HTHS than a 5W-40.
Personally, I like the specs on Euro oils better since they meet the toughest specs in the industry. X-cess meets Porsche A40, MB 229.5, and VW502. RT6 is fine too if that's what you've been running and just want to stick with it, even though it no longer meets API gasoline specs.
Old 11-19-2020, 08:30 PM   #397
Big-E
Member#: 123843
2016 STI LTD CWP
Let LED's light your way!
I've been using Schaeffer Supreme 9000 series full-synthetic 5w-40 for quite some time now: https://www.schaefferoil.com/documents/244-9000-td.pdf
I see that they now offer a 0w-40: https://www.schaefferoil.com/documents/316-9040-td.pdf
Any feedback is appreciated regarding the 0w-40 oil.
Old 12-01-2020, 10:28 PM   #398
Tyjamo87
Member#: 520275
2007 Impreza WRX Wag
Pearl white
Newb Q
Today's Rotella T6 is STILL the correct specification for an '07 WRX??
Still ONE of the forums favorites? Or, at least a known adequate option?
Thanks all!
Tyjamo87 is offline   Reply With Quote
Old 12-02-2020, 01:24 AM   #399
jakesubie
Member#: 511228
2017 Subaru WRX
Red
Wow, this is a ton of great information.
I've been using Mobil 1. If I'm understanding, since the Mobil 1 Extended Performance has a slightly lower HT/HS than regular Mobil 1, it's technically worse? I'd never go 10k miles let alone 15k without changing the oil...
jakesubie is offline   Reply With Quote
Old 12-02-2020, 02:09 PM   #400
600hpSTI
Member#: 520674
2008 WRX STI Hatch
Hyper Blue
Default Castrol
You cant go wrong with Castrol 5w30 GDI Turbo Formula.
600hpSTI is offline   Reply With Quote
