04-01-2012, 10:12 PM | #5501 | |
Member#: 312313
MWSOC
Vehicle:2010 WRX Hatchback White |
04-02-2012, 02:16 AM | #5502 |
Member#: 264713
Vehicle:04 wrx psm |
hey guys I got some new tires 225 40 18 re960 bridgestone that are in really good condition worth probably around 800 if not more new and I also have a extra set of 245 40 18. The wheels are 18x8.5t48 as I posed earlier for sale for 1100 or 1500 with coilovers. Also let me know since Im new to this sub-forum if I should not post stuff like this on here. Just thought Id let y'all know whats available. oh ya these pics are with the old tires
04-02-2012, 08:50 AM | #5503 |
Member#: 179216
MWSOC
Vehicle:2011 SWPSTI 04G35x Forced4s.com |
The ol saabaru is looking clean.. Your making me regret selling it! lol
04-02-2012, 11:52 AM | #5504 |
Member#: 259430
MWSOC
Vehicle:2018 STI WRB |
Were any of you guys at the geauga lake auto cross yesterday? I met a guy with a 04-05 blue Sti that said he was selling it and my buddy is interested in it. But I forgot to get his name, the Sti had rota grids on it and he said he also had an evo. His name might have been rob, but I forget. If anyone in here knows him could you pm me his user name so I get a hold of him. Or if any of you know the guy from willowick with a 06-07 blue Sti, rally pigs on the mirrors can you hook me up with his user name, they were friends. Im not trying to be creepy or hunt down the guy, but his Sti was clean as hell and my friend wants to check it out. Thanks!
04-02-2012, 11:56 AM | #5505 |
Member#: 107076
MWSOC
Vehicle:'06 WRX STi (WRB) '06 Outback 2.5 (WGO/MGM) |
That would be Dirty25RS. He made a post a page back or so and his FB is linked right under his screen name if you need to get a hold of him.
04-02-2012, 02:10 PM | #5506 |
Member#: 301599
MWSOC
Vehicle:03 WRX PSM |
any one in or near parma good with open source tuning/data logging? my car recently started to run a little rough, could feel it cutting power on the highway and my a/f was tuned to run at 12, now if i run wide open it start at 12.2 then jumps to 13. trying to get an idea of what i can look into.
04-02-2012, 02:29 PM | #5507 |
Member#: 56731
MWSOC
Vehicle:2004 STi, 00 Insight 10 Volvo C30R-d 11 F150 |
yep, thats me
04-02-2012, 02:32 PM | #5508 | |
Member#: 210165
MWSOC
Has anything changed? Maintenance? |
04-02-2012, 02:49 PM | #5509 |
Member#: 301599
MWSOC
5th gear on the highway, it happens in any gear under full throttle. yes, that going off the wideband. the only thing thats changed is the rear suspension from a small accident. and it's been tuned by the previous owner not a pro, it's ran fine for months.
04-02-2012, 03:11 PM | #5510 |
Member#: 56731
MWSOC
log injector duty cycles, and boost, If you could log fuel pressure that'd help to but i doubt you can.
04-02-2012, 03:22 PM | #5511 |
Member#: 301599
MWSOC
do you know of anyone who have a cable that i can do logging with?
04-02-2012, 03:29 PM | #5512 | |
Member#: 210165
MWSOC
I don't know much about the 5sp on the maps, you traditionally just scale overdrive and don't tune due to the rarity of full throttle/high RPM in OD Also I have a tactrix 2.0 cable but not a laptop I can loan you, should work with the 03s but youd need the reflash connectors which I don't think I have (but I might) if you change the map |
04-02-2012, 04:05 PM | #5513 |
Member#: 301599
MWSOC
yeah, i've ran a few tanks of gas on it. I also have laptops that i can use, im going to be getting all the different tunes from the previous owner. I just noticed it within the last 10 days, (3 tanks of gas) even when running half throttle in 3rd or 4th it sits around 12.2 which is ok for 10-13psi, but when running wideopen 22psi (tuned at that) the ratio climbs to 13. when cruising on the highway just maintaining speed it sits at 14.7 which is what it's tuned for.
jmikolich shoot me a text if your going to be in or around strongsville, i pick my kid up from daythere at 5:15 everyday. thanks jeremy Last edited by silver03rex; 04-03-2012 at 01:51 PM. |
04-02-2012, 05:05 PM | #5514 | |
Member#: 56731
MWSOC
2. stock injectors? 22psi on the stock turbo is too high for a WRX, you're just making a lot more heat than airflow, but thats beside the point. The point is that its my understanding that the stock injectors are just maxed out around 18-19psi. I bet you find 100% duty cycles when you log. |
04-02-2012, 06:56 PM | #5515 |
Member#: 301599
MWSOC
it's a stock turbo yes, it's been ported n polished, from what i was told is 850cc injectors, ported polished heads, it's not stock by any means. as soon as i can get some logging done i will post it up in here. i know nothing about tuning or maps.
04-02-2012, 07:39 PM | #5516 |
Member#: 312313
MWSOC
Do you notice your Kartboy shifter further forward than the original shifter? Neutral is now like 3rd gear for me now with the new shifter. Still feels great, just different.
04-02-2012, 09:25 PM | #5517 | |
Member#: 296210
MWSOC
Vehicle:2013 STI WR Blue Pearl |
04-02-2012, 09:37 PM | #5518 |
Member#: 312313
MWSOC
04-02-2012, 09:41 PM | #5519 | |
Member#: 296210
MWSOC
04-02-2012, 10:37 PM | #5520 |
Member#: 312313
MWSOC
Neutral Position Everything off. Last edited by MouseMarine; 04-02-2012 at 10:46 PM. |
04-02-2012, 11:07 PM | #5521 | |
Member#: 296210
MWSOC
04-03-2012, 07:41 AM | #5522 |
Member#: 107076
MWSOC
Is the stalk bent or is it straight? What would happen if you rotated it 180 degrees front to back?
04-03-2012, 08:11 AM | #5523 | |
Member#: 292760
MWSOC
Vehicle:2005 CGM STi '02 Impreza OBS |
04-03-2012, 08:29 AM | #5524 |
Member#: 312313
MWSOC
It is supposed to be bent backwards. I even did turn it 180 degrees to make sure and it was crazy angled forward in neutral.
04-03-2012, 08:45 AM | #5525 | |
Member#: 296210
MWSOC
Similar Threads | ||||
Calling All Cleveland Area Scooby owners!!! | nick32 | Mid West Subaru Owners Club Forum -- MWSOC | 21 | 04-03-2008 04:55 AM |
Cleveland Ohio I-Club | jayfressh | Mid West Subaru Owners Club Forum -- MWSOC | 9 | 04-02-2002 06:44 PM |
Vin #11 1998 SOA 2.5L RS at Cleveland Ohio AutoRama!!!! | black99gt | Member's Car Gallery | 4 | 01-21-2002 10:31 PM |
Need WRX-help in Cleveland, Ohio... | Shaka | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 3 | 11-12-2001 10:05 AM |
('93-'01) Cleveland, Ohio - A day at the drag strip event! | Shaka | Impreza Forum | 9 | 10-04-2001 11:58 AM |
