02-10-2018, 07:22 AM | #1 |
Member#: 479808
Vehicle:02 Impreza wrx 2.0 Grey |
p0103 cel help
Hello, i recently put a lot of mods on my car, including a custom CAI that goes out the front of my passenger side fog light back up to my turbo inlet 3"tubing on my ej205 2002 2.0l wrx... i got my car tuned for a bss map, everything running good. Then i floored it yesterday, car started cutting out and CEL came on with P0103, car immediately started idleing ****ty, would not accel for crap... sooo i had a spare MAF (ebay brand) it seemed to work at first start up, but when i would go to drive the car, same thing would happen only the ebay one would accel at all... CEL came back on, on that MAF also...we had heavy rain the day before. My car was parked in my garage...i just would find it hard that both MAF sensors are bad, but then again the ebay one i wouldnt be surprised... anyone have any suggestions on what it could be? Im going to go out today and start her up and see if it will do the same thing.
02-11-2018, 10:59 AM | #2 |
Member#: 436768
E. Canada
Vehicle:2004 WRX Silver |
i had this issue on my GTI; WOT caused the car to bog down, eventually couldn't get it started. turned out ****ty grounds caused the injectors to open wide like they were at the dentist filling my cylinders with fuel.
02-11-2018, 11:29 AM | #3 |
Member#: 479808
Hmmm i moved one of my grounds to the other intake manifold side, but my car was running fine. Ot through the CEL during a shift, which what makes me believe it hit the MAF limit. But immediately my idle was rough and car would bog on WOT, upon further inspection the bottom side of my throttle body tube felt like it slipped off or had a slit. So i replaced that and cleaned my MAF sensor its veen raining here, so i need to wait till tomorrow to see if its fixed i cant post pics or i would show u the location of my intake
03-20-2018, 08:58 AM | #4 |
Member#: 479808
Any update on this? Cause i have a rich tune for a base map...decent upgrades, bigger injectors, custom cai going to fog light... WoT cause same issue...cel p0103, so im wondering, could a rich tune be causing this?
03-20-2018, 09:47 AM | #5 |
Member#: 21145
NESIC
Vehicle:2002 Enemy of Aku |
Base maps are just that - a base map. They are not intended to allow you to drive the car hard.
Point of a base map is to allow you to drive the car in a reasonable manner until such time you go for a real tune. Impossible to tell anything when you say " i recently put a lot of mods on my car, including a custom CAI '. This tells us nothing about your set-up. Could be anything from you are causing your own issue by romping around on a base tune to the addition of the CAI to anything in between. |
03-20-2018, 10:18 AM | #6 |
Member#: 479808
16g turbo, cai worked to fog light postiton, fmic 2.5", 565 inject, 250lph walboro fuel pump, silicone inlet, pnp tgv deletes, pnp oem intake manifold, pnp throttle body, a/c delete,fullexhaust header back straight pipe... sorry just figured the only culprit couldve been the intake or maf
03-20-2018, 10:20 AM | #7 |
Member#: 479808
And a aftermarket dual port bov...btw its a 4EAT
03-20-2018, 12:43 PM | #8 |
Member#: 21145
NESIC
16G turbo, 565cc injectors, 255lph Walbro fuel pump, silicone turbo inlet, PnP stuff - all pretty standard
I would have gone larger injectors FMIC will add lag and really not necessary for a 16G Full catless exhaust? Hope you don't mind losing your hearing All the above look fairly normal. Along with the FMIC, you don't need a CAI Why a dual-port BOV? You don't need it and the OEM BOV works perfectly fine. Issues look related to the following, in no particular order: 1. CAI 2. Dual port BOV 3. Base tune I'd dump the CAI I'd dump the dual-port BOV and go back to OEM I'd get a real tune It's your car and do whatever you want with it but CAIs and non-OEM BOVs have always shown to be culprits. |
03-20-2018, 12:59 PM | #9 | |
Member#: 479808
Think that overboosting could be a possible culprit? |
