Welcome to the North American Subaru Impreza Owners Club Sunday December 16, 2018
Old 08-22-2010, 08:33 PM   #1
caleb04STi
Member#: 233751
04 STi
Default 04 STi Intercooler Spray Not Working
So when I bought the car the tank in it was cracked, bought a replacement from a guy this weekend. Got home and installed it and to my displeasure I still didn't have a functioning system. I have blown out the lines, tried 2 switches, and 2 motors, I'm thinking the relay is the culprit possibly. Anyone know which relay operates the sprayer? I'm not so great with decyphering service manuals and would appreciate the help.
caleb04STi is offline   Reply With Quote
Old 08-24-2010, 05:46 PM   #2
Web Foot STi
Member#: 39086
2004 STi
Can you adjust your side mirrors? They are on the same fuse as the intercooler spray. #4 behind the change pocket to the left of the steering wheel.
The relay (INTERCOOLER WATER SPRAY TIMER in suby speak) is a 4 pole plug to the right of the glove box under the dash. It looks like you have to pull the glove box to get at it. It's only 13 screws... If you are that far into a PIA job I would change out the cabin air filter too. Odds are it's 6-7 years old and you will be in the neighborhood. There are threads on changing that filter if you need instructions.
Edit: The plug is B286 if you care.
Web Foot STi is offline   Reply With Quote
Old 08-24-2010, 10:48 PM   #3
05Scooby
Member#: 153216
could you by any chance have a pic?
05Scooby is offline   Reply With Quote
Old 08-24-2010, 10:53 PM   #4
Web Foot STi
Member#: 39086
2004 STi
Service manual just has a drawing of where the harness plug is. It is in Adobe and I only have the reader. Sorry.
Old 08-25-2010, 12:24 AM   #5
caleb04STi
Member#: 233751
04 STi
Appreciate the help, I'll give it a try tomorrow evening after work and let you know how it turns out. I checked all fuses to make sure that wasn't the case before posting.
Old 08-25-2010, 09:34 PM   #6
caleb04STi
Member#: 233751
04 STi
Well contacts aren't corroded or anything and relay seems to be in working condition, however I can't feel it clicking over when I press the switch unless it is a solid state relay (probably now that I think of it). Unless someone has some good insight I'll probably end up taking it to PIA.
Old 08-29-2010, 01:50 PM   #7
caleb04STi
Member#: 233751
04 STi
Turns out the fog light dongle was plugged into the I/C spray switch.
Old 08-29-2010, 07:19 PM   #8
Web Foot STi
Member#: 39086
2004 STi
At least you found it.
Old 09-28-2010, 04:27 PM   #9
Badler
Member#: 133597
Thank you!!!!
Cigarette lighter is on there as well.
Badler is offline   Reply With Quote
Old 09-07-2018, 08:25 PM   #10
Chris424
Member#: 491179
Default Spray not working
2004 STI intercoller spray isn't working.. where is the intercooler spray motor
Chris424 is offline   Reply With Quote
Old 09-08-2018, 12:17 AM   #11
Homemade WRX
Member#: 33782
96 in the garage
search FIRST, then PM!!!
The motor is on the side of the sprayer tank, in the right side of the trunk. Check voltage going to it.
04 STI intercooler spray tank. EvanOT SCIC Private Classifieds 0 09-24-2009 10:04 PM
JDM STI intercooler spray switch/V7 sti scoop rear windsheld spray pump spliter. subrandon Private 'Wanted' Classifieds 1 07-07-2006 01:45 AM
04 STi intercooler spray switch, headlight leveling motors my04sti Private 'For Sale' Classifieds 5 06-26-2006 10:10 PM
04 STI Tach wire not working for eBoost2, anyone? bboy Electrical & Lighting 5 04-19-2006 07:32 PM
MRT Intercooler Spray - FINALLY WORKS! hotsam Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 10-21-2001 01:21 AM
