06-11-2012, 11:51 AM | #726 |
Member#: 184485
Vehicle:'06 STi AW '08 FXT Sport 4EAT DGM |
06-11-2012, 11:58 AM | #727 |
Member#: 279449
Vehicle:2004 8.78 E/T WRX Platinum Silver |
^^^ beautiful
07-03-2012, 07:56 PM | #728 |
Member#: 316092
South East
Vehicle:2012 Impreza Hatch Dark Gray Metallic |
When installing these do most people remove the stock horns or leave them in? Reason I ask is with the stock security system ( i assume the horns and security are connected) how would the alarm be integrated into the Hellas if the stock horns are pulled?
07-03-2012, 08:23 PM | #729 | |
Member#: 182114
TXIC
Vehicle:1996 Nissan HARDbody 1931 Ford Model A |
07-03-2012, 10:38 PM | #730 |
Member#: 301179
BAIC
Vehicle:2013 WRX Limited SWP |
In my 09 I left the stocks that's near the dlr connector.
07-04-2012, 06:46 AM | #731 |
Member#: 64405
E. Canada
Vehicle:2018 STi WRB |
Of the two stock horns wires, I used one to trigger the relay powering the hellas, and I kept the lower note stock one in place. After trying them I felt that the hellas needed a little more low end frequencies, and it probably makes for an even more dissonant tone
Fred |
07-08-2012, 09:15 PM | #732 |
Member#: 237190
South East
Vehicle:2003 Matte White Wrx 2006 WRB STi 2007 SWP STi |
does anyone know if u could buy a new relay at any autozone/advanced?
07-08-2012, 10:27 PM | #733 | |
Member#: 195739
SWIC
Vehicle:2002 wrx wagon silver |
07-09-2012, 04:08 AM | #734 |
Member#: 237190
South East
07-15-2012, 01:53 PM | #735 |
Member#: 297651
Does anybody have a link/tips on how to wire the 4 horns. I am willing to delete or keep the stock horns. Do not want a switch. I couldn't find one last night and right now I'm at work so I dont have the time till I'm off. Thanks in advance guys
07-15-2012, 03:01 PM | #736 | |
Member#: 64405
E. Canada
It is pretty much the same as you would do with 2. |
07-15-2012, 04:20 PM | #737 | |
Member#: 94070
South East
Vehicle:05 LGT PSM |
Takes about 30 or so minutes for an easy install |
07-16-2012, 12:58 AM | #738 | |
Member#: 131787
Vehicle:06 STI,OB,OME XJs Merkur Junkyard |
Additional wire length will inevitably increase the total circuit resistance, especially as the cable degrades from environmental exposure after the first year. |
07-16-2012, 01:14 AM | #739 |
Member#: 131787
12345
07-19-2012, 04:02 AM | #740 |
Member#: 297651
i was worried about the horns losing power if i spliced all 4 from one line, and as for the harness set up i made my own a while ago when i hooked up 2, now i am (will be) hooking up the second set. i have 12 gage wire, will this be an issue with resistance? and also is there any problems with that so far? and yea im pretty sure i get exactly what your saying but i wasnt sure if there was a better way, or a diagram. but thank you all!
07-19-2012, 04:13 PM | #741 |
Member#: 317114
SWIC
Vehicle:'12 WRX Hatch Silver |
This is regarding the SuperTones. Where do you guys recommend buying these? I saw a vendor selling them in a bunch of different colors. I looked and could find that vendor. whats is a good price for these. Car is a '12 WRX. thanks again.
07-19-2012, 04:29 PM | #742 | |
Member#: 259508
NWIC
Vehicle:2015 WRX Limited WRB |
07-19-2012, 04:49 PM | #743 | |
Member#: 123843
NESIC
Vehicle:2016 STI LTD CWP Let LED's light your way! |
07-21-2012, 01:11 PM | #744 |
Member#: 318648
NESIC
Vehicle:2007 Impreza 2.5i UGM |
To those who used the stock wiring harness, how were you able to lengthen the wires? I just unplugged them and have no slack to bring them to where the are supertones mounted?
07-21-2012, 03:50 PM | #745 | |
Member#: 301179
BAIC
10-12-2012, 09:49 PM | #746 |
Member#: 126749
made a video how to here
10-13-2012, 04:28 PM | #747 |
Member#: 156723
Vehicle:17 2.5i foz dgm rip wrx/rs/2.5i/foz1 |
All you need to make your own harness is a male to female wire, and female to ground(spade) wire for each horn.
I just got the jna green Hellas and some 18 gauge green wire from pep boys with a few connectors and put about a foot extension for each wire and was able to reach. It's actually quite easy using stock power connector, and I didn't realize gc's only had one puny stock horn. |
10-21-2012, 07:42 PM | #748 |
Member#: 232169
Vehicle:2002 Hawkeye World Rally Blue Pearl |
does the size of the wire matter? i ran out of 14 gauge wire but i have a lot of 18 gauge wire, could i just use the 18 instead of the 14??? would this decrease the sound????
10-23-2012, 04:43 PM | #749 |
Member#: 74392
Vehicle:2010 STI DGM |
10-24-2012, 09:29 PM | #750 |
Member#: 64405
E. Canada
These looks like a small pair of boxing gloves haha
How is the tone of these compared to the regular supertones ? |
How to: Install Alpine HU-Currently Have Sony | gtwagon941 | Car Audio, Video & Security | 13 | 02-15-2006 01:35 AM |
How to: install Megan coilovers? | spooledwrx | Interior & Exterior Modification | 12 | 01-20-2006 12:14 AM |
How to: Install a new clutch | no_rex_yet | Off-Topic | 11 | 11-12-2004 02:45 PM |
How To: Install WRX Turbo/IC on a 2.2L | Pepo | Normally Aspirated with bolt-on Forced Induction Powertrain | 12 | 10-08-2004 11:18 AM |
how to: install rear trailing arm bushings | Scott F. Williams | Brakes, Steering & Suspension | 4 | 11-06-2002 11:37 AM |
