06-01-2005, 02:40 PM | #1 | |
Member#: 2992
Vehicle:02 WRX Sedan Silver |
2006 Forester XT
When I heard the 2006 Forester XT makes the same peak torque as the 2005 version (235@3600) but was rated 20 hp higher in power, I assumed (along with many others, I think) that Subaru was merely assigning a more realistic power rating and didn't really change much with the engine.
But I was wrong. According an SOA press release: Quote:
BTW, Subaru has now begun referring to its AVCS as "i-Active Valve Control System" and calling its 2-stage variable valve lift system "i-Active Valve Lift System." What's with the "i-" stuff? Intake? Intelligent?
06-01-2005, 02:49 PM | #2 |
Member#: 37003
Vehicle:2015 WRX DGM |
sweet
06-01-2005, 03:09 PM | #3 | |
Member#: 49134
SWIC
Vehicle:2007 FXT WRB |
06-01-2005, 03:29 PM | #4 |
Member#: 58031
TXIC
06-01-2005, 09:22 PM | #5 |
Top Scoob 024
Member#: 56364
International
Vehicle:RIP stompr :( bagged vulvva |
can't wait to find some scrapped wrx's for a 2.5 shortblock...
06-01-2005, 10:45 PM | #6 |
Member#: 524
Vehicle:04 STi White |
Jon, My guess is that indeed the FXT will be no more powerful than the older cars, they just made changes to make it more capible of meeting the durablity requirements of the EPA while also cleaning it up a bit more.
Honestly the stock WRX turbo was so far out of its range on the FXT I can't see that as really having the 100K mile duriblity for emissions equipment that the EPA requires. Which likely subaru is starting to find out on its own. Lol 9.5-9.8:1 stock A/F ratios on boost. |
06-01-2005, 11:15 PM | #7 | |
Member#: 69264
BAIC
Vehicle:05 LGT White |
exactly! |
06-01-2005, 11:25 PM | #8 | |
Member#: 84809
Vehicle:2005 Forester XT Black |
06-01-2005, 11:34 PM | #9 |
Member#: 17851
edit: found what i was looking for
06-02-2005, 11:29 AM | #10 |
Member#: 177
Vehicle:The 93 W/EJ20K-sold Subaru-less :( |
hmm secondary air pump system?... hmmm egr?
06-02-2005, 11:59 AM | #11 | |
Vehicle:OK buy Nates beans westcoastroasting.com |
.....took long enough for someone to post on that one |
06-02-2005, 12:26 PM | #12 | |
Member#: 2992
Secondary air is only used during cold start. |
06-02-2005, 12:35 PM | #13 |
Member#: 2992
BTW, the 2006 FXT specs, including the new gear ratios, can be found at:
http://vocuspr.vocus.com/VocusPR30/D...7-ef90923db36d |
06-02-2005, 01:47 PM | #14 |
Member#: 25905
SCIC
Vehicle:2003 Silver Wagon Tuned with Enginuity |
The engine and gearing changes have also bumped up EPA fuel economy ratings, especially on the AT model where the gear ratios look pretty high:
05 MT: 19/24 06 MT: 19/25 05 AT: 20/23 06 AT: 21/26 I'd expect the 06 WRX to get the same or maybe even better gas mileage than previous models even with the bigger engine and more power. |
06-02-2005, 01:49 PM | #15 | |
Member#: 25905
SCIC
06-04-2005, 11:06 AM | #16 | |
Member#: 25587
Vehicle:2004 Forester XT PSM |
The 05MT and 06MT gear ratios are exactly the same. The difference in mpg is due to aerodynamics and the difference power curve most likely.
The 05AT and 06AT differ only with the final drive, it's now 4.11 instead of the 4.44 of the 05. Quote:
06-04-2005, 02:38 PM | #17 |
Member#: 8343
Vehicle:2005 2012 Jeep 2013 DGM BRZ |
Gear ratios are identical to the current WRX ratios...How not surprising. Hopefully they stick the 4.44 final in the WRX as well, it will make a big difference.
06-04-2005, 04:50 PM | #18 | |
Member#: 78539
Vehicle:2005 Subaru STi K&N Typhoon HKS CarbonTi |
06-04-2005, 08:43 PM | #19 | |
Those numbers are rated power at the crank.....just like everybody else rates their HP in sales literature........ |
06-04-2005, 11:32 PM | #20 | |
Member#: 2992
06-05-2005, 03:00 AM | #21 |
Member#: 524
I agree. The FXT's I've seen on a dyno show 230HP crank. STi's range from 300 to one I saw that hit 315 crank. My LGT was 260 crank IIRC. WRX's usualy turn about thier 227 crank rating. Dyno does a coast down measurement to calculate crank numbers.
06-05-2005, 03:08 AM | #22 | |
Member#: 4190
BAIC
Vehicle:2008 Impreza WRX STi Aspen White |
Before you take a car like that in for smogging...drive like a mad man to get EGT's high enough to burn off any carbon deposits off of the air injector so that it can work well for emissions purposes...someone told me this was referred to as an 'Italian tuneup' :P |
06-05-2005, 06:02 PM | #23 |
Member#: 82856
Sweet..
06-05-2005, 09:22 PM | #24 | |
Member#: 29735
Vehicle:2011 JSW TDI - DSG 2008 EVO X MR |
06-05-2005, 10:09 PM | #25 |
Member#: 38220
Vehicle:2004 WRX STi 20G Silver/Silver |
Have the look changed at all?
Similar Threads | ||||
asap help on 2006 forest xt prices... | janikphoto | Forester Forum | 4 | 03-31-2006 07:57 PM |
Can I connect an Ipod on a 2006 forester XT?? | BBBsti LTD | Forester Forum | 0 | 01-19-2006 09:31 PM |
2004 vs 2006 Forester XT | chrisww2 | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 6 | 12-05-2005 12:07 AM |
2004 vs 2006 Forester XT | chrisww2 | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 4 | 12-03-2005 12:54 PM |
