03-12-2019, 06:43 PM | #26 | |
Member#: 4562
Vehicle:2014 Electric Datsun 2005 Adventure van |
Arguing against things you made up, again?
03-12-2019, 08:13 PM | #27 |
Member#: 163775
Vehicle:2023 BRZ CWP |
03-13-2019, 10:35 AM | #28 |
Member#: 43748
TXIC
I have zero idea wtf youre talking about. Every thing I said is an opinion based off of one svelte dancer that felt someone's desire to have a "masculine" vehicle is wrong in some way.
The response to you was opinion based, there is nothing to make up. You realize we don't have to agree to have a civil convo, right? I think I pretty much demonstrated that in the post you quoted. But you be you |
03-13-2019, 01:28 PM | #29 |
Member#: 4562
What in the **** are you even on about?
We're done, back to ignore with you. |
03-13-2019, 02:07 PM | #30 |
Member#: 67807
Not to squeeze in here too much but I’ve read and reread what he has said in this thread and I’m not sure where you’re getting so bothered. I think a great example of what’s being stated is what Honda has done with the Ridgeline and Pilot. Some people have taken issue with the more sleek styling and don’t care for it compared with the boxiness of the previous gen. Call it less masculine if you will, but that’s the sense of what Honda did to them. Many people have made this claim. Including the media. Or perhaps I completely missed the point.
03-13-2019, 02:14 PM | #31 |
Member#: 4562
I have no clue what he's even on about.
I pointed out it can still be big burly etc.... while not being masculine with a few small tweaks. He went on his usual personal attacks and arguing against points never made. I'm equally as confused, but it's not his first time on my ignore list, but it is the last time he gets removed from it. |
03-13-2019, 02:23 PM | #32 |
Member#: 67807
Ah. Yeah I think he was just generally responding to the masculine feminine preference statements more than anything else and saying whatever someone likes and how they like it is cool either way. Anyone can assign their own feelings of what constitutes masculine and feminine etc. when applying it to the same vehicle.
03-13-2019, 04:07 PM | #33 |
Papi Chulo
Moderator Member#: 53794
RMIC
Vehicle:... 2017 BMW M2 2017 F-150 |
Just read through the posts and I don't see where he went on personal attacks. You two are just having some rather ridiculous discussion on "masculinity" of a truck and I think you might be taking him out of context.
03-13-2019, 05:20 PM | #34 | ||
Member#: 43748
TXIC
Ive never personally attacked you.....or anyone for that matter. I think you have me confused with someone else. You should re-read what I typed from the get-go Quote:
See Honda this man gets it. That's all I was saying. |
03-14-2019, 10:02 PM | #35 |
n00b Moderator
Moderator Member#: 4263
SCIC
03-21-2019, 12:49 PM | #36 |
Member#: 378822
Vehicle:2021 Supra 3.0 Prem. Nitro Yellow |
My MIL just got an EX trim so I'll have to try it out this weekend. |
03-21-2019, 01:30 PM | #37 | |
Merci Buckets
Moderator Member#: 88606
Vehicle:2018 Grand Cherokee Velvet Red Pearl |
As for torque vectoring, that has to be brake-based. An open differential can't provide torque vectoring. Magna has a different drive module for that, and I think it's outside the pricing window of a Kia. This torque vectoring corner control has to be minor tugging of the brake on the inside wheel to help initiate a turn, much like nearly everyone else does these days as it's become an almost universal feature from brake control suppliers. |
03-22-2019, 07:13 AM | #38 | |
Member#: 35985
Vehicle:20 Supra 16 Jeep Wrangler Unltd. |
03-22-2019, 11:04 AM | #39 | |
Member#: 378822
Where I do see an issue is KIA has intentions to offer some aftermarket off-road bits (as seen in some of the concepts) and the AWD system could be a weak point then. |
03-25-2019, 01:34 PM | #40 | |
Merci Buckets
I don't know if it just has "lock mode" or if there's also a separate "off-road" mode, but that doesn't change the potential for doing something different at the push of a button. Having multiple options makes it easier to vary the response. In any case, that push of a button can tell the AWD system completely change the profile for when and how much torque is transferred to the rear axle. Without a ratio offset you'll never have more than 50%, but changes to the base torque / pre-load on the coupling will impact how quickly the system reacts. Assuming the driver pushed the button because they are on a low mu surface the first big change is telling the coupling to carry more torque at higher steering angles which would normally causing binding on dry pavement. In parallel the brake controls may allow more dive in the wheel speeds under braking prior to activating ABS, so you can build up that little pile of gravel under braking on a dirt road. They can also change thresholds for TCS, allowing less side-to-side speed difference across the axles and doing more with brake-based limited slip differential functions. They can disable engine-based reductions with ESC and TCS or allow a bit more engine output when they do intervene. Look up videos of people rock crawling with a Jeep Renegade Trailhawk and then realize it has open differentials and fancy AWD / brake controls. This is a pretty good one. You can see wheels off the ground and very little slip / spin before the brakes clamp down on the airborne wheel and generate torque transfer to the wheel still on the ground. |
03-25-2019, 03:32 PM | #41 |
Member#: 102793
Vehicle:2016 WRX Ugly Sedan |
I would just like to say thanks for sharing your insider/technical expertise on these various systems in multiple threads over the years, much appreciated
03-26-2019, 04:02 AM | #42 |
n00b Moderator
SCIC
03-26-2019, 09:50 AM | #43 |
Member#: 378822
This isn't the best reviewer but is a good look at the Moss Green and Silver colors. The silver has some blue in it. I was hoping for a medium or dark blue but it looks like the Palisade will get that. The burgundy is also not available on the SX which is disappointing.
I can't find and pictures of the Black Copper. I'm assuming is a warm/brown charcoal. I drove the EX over the weekend and when comparing everything else out there there isn't much else I'm interested in. I like the CX-9 but it's smaller (cargo and passenger volume) and the LCD and tech interface is small/slow. The Atlas is a pretty close match and with $10k off MSRP is compelling. It is just is a little under powered and a bit blandly designed. The new Explorer is too expensive and I don't care for the design and the Pilot/Highlander are not even close for me. Hopefully the Palisade comes out soon so I can compare. |
05-11-2020, 10:43 AM | #44 |
Member#: 453
Vehicle:2020 Kia Telluride 2021 Porsche Taycan |
Traded in my old DD (Kia Niro hybrid) for the Telluride EX AWD, really enjoying it so far.
Anyone who is interested in the car feel free to ask me questions. Also I did cross shop with that Pallisade but at a higher starting price point and the fact the outer styling looked like visual cancer to me, I wrote that one off. Pretty much no other 3 row SUV currently in the market interests me. Plus my sister's family uses a current model year Honda Pilot which is a main segment competitor of the Telluride and I was pretty 'meh' on the whole vehicle, exterior and interior styling. |
05-11-2020, 11:53 AM | #45 |
Member#: 88924
South East
Vehicle:2014 Cadenza, Sedona Past: Tribeca LGTx2 Justy |
Nice looking ride! I haven't ridden/driven one, but did sit in two at my local auto show a year ago. I like the roominess in the 2nd & 3rd rows. Much better than the Sorento.
05-11-2020, 12:51 PM | #46 |
Member#: 1654
Vehicle:2019 GoCycle GX MV Agusta Brutale S |
Do you get the Beatles "Ticket to Ride" song playing in your head when you see the name of this car? Just me? yeah, probably.
05-11-2020, 01:08 PM | #47 | |
Member#: 453
Very roomy in the first 2 rows and the 3rd row is tolerable even for an adult like myself almost 6 ft |
05-11-2020, 06:38 PM | #48 | |
n00b Moderator
SCIC
I really like these. Even the brown ones don't look bad, which is what my friend got. I think it's a base model, and it's quite nice as-is. What's your avg fuel economy? I'm in my first Kia, a 2020 Soul GT Turbo. It's very comfortable and quiet when off-turbo. |
05-11-2020, 08:01 PM | #49 | |
Member#: 453
Now im back to constantly eyeing the tank and watching that needle droo as I drive, at least I feel like a boss when I drive. |
05-11-2020, 10:45 PM | #50 |
Member#: 161333
Vehicle:135i vert fast leaf |
Were they willing to deal?
Local dealers aren't marking anything down and the Telluride isn't listed as being part of their financing deal. . Conversely, I can go pick up a fully loaded VW Atlas for 5K off MSRP at the local dealer, plus financing incentives. |
