05-19-2006, 12:25 AM | #1 |
Member#: 66510
NWIC
Vehicle:2003 wrx 18g JBP |
Data logging gurus, need your help reading log.
After a crappy night at the track i felt the need to see whats going on. So i data logged a run in 4th gear (This is 4th gear with a US STI transmission). Can anyone tell me what is going on and why I am not hitting full boost. Test was with 71 degree outside temp.
I have an 03 WRX with following mods. cobb accessport w/OTS 2.5 map VF34 STI pinks STI tmic gutted up/down pipe STI turboback US STI 6spd trans K&N filter snorkus removed Engine speed (rpm) Ignition Timing (btdc) Knock correction (btdc) Boost (psi) Wastegate duty cycle (%) Air fuel (afr) Advanced multiplier Injector duty cycle (%) Code:
3371 26 9 5.078 44.31 14.47 15 18.7 3374 23 7 5.659 49.41 14.93 15 18.71 3418 21 7 3.918 18.43 14.81 15 18.23 3400 32 0 -3.773 0 11.6 15 6.53 3414 31 0 -6.239 0 14.93 15 5.1 3412 24 0 -7.4 0 18.38 15 5.1 3406 17 0 -8.271 0 18.26 15 0 3485 2 -1 -2.612 18.43 25.5 15 11.89 3374 28 6 1.306 23.53 17.57 15 15.83 3488 30 8 2.612 28.63 12.86 15 20.84 3529 27 9 3.627 33.73 11.94 15 21.83 3488 24 7 4.643 38.43 11.94 15 23.07 3521 21 7 5.514 43.53 11.83 15 24.79 3573 21 7 6.675 48.63 11.71 15 26.68 3618 20 8 7.69 53.73 12.06 15 28.56 3642 18 8 9.286 61.18 11.48 15 31.86 3691 17 8 10.592 65.1 11.37 15 34.64 3776 16 7 11.608 65.1 11.25 15 37.86 3807 15 7 12.624 65.1 11.25 15 38.98 3882 14 7 13.204 65.1 11.25 15 40.58 3910 14 7 13.494 65.1 11.25 15 40.87 3983 14 7 13.639 65.1 11.25 15 42.48 4041 14 7 13.784 65.1 11.25 15 43.1 4094 15 7 13.929 65.1 11.25 15 43.67 4116 15 7 13.929 65.1 11.25 15 44.78 4204 16 5 13.929 65.1 11.25 15 45.74 4254 12 5 14.075 65.1 11.25 15 47.19 4269 13 5 14.075 65.1 11.25 15 48.26 4350 13 5 14.22 65.1 11.25 15 50.11 4386 13 5 14.075 65.1 11.25 15 50.52 4491 13 6 14.22 65.1 11.25 15 52.69 4488 13 6 14.365 65.1 11.25 15 52.66 4554 13 6 14.365 65.1 11.25 15 52.46 4638 14 6 14.365 65.1 11.25 15 54.42 4690 14 7 14.51 65.1 11.25 15 55.03 4765 15 7 14.51 65.1 11.25 15 54.89 4786 16 7 14.51 65.1 11.25 15 55.13 4879 16 7 14.51 65.1 11.25 15 56.21 4915 16 7 14.655 65.1 11.25 15 57.66 4987 15 6 14.8 64.71 11.25 15 58.51 5037 13 4 14.8 64.31 11.25 15 59.1 5057 13 3 14.945 63.53 11.25 15 60.41 5147 12 2 14.8 63.53 11.25 15 61.49 5133 13 1 14.8 63.14 11.25 15 61.33 5223 13 1 14.8 62.75 11.25 15 62.39 5274 13 1 14.655 62.75 11.25 15 64.13 5357 13 2 14.655 62.75 11.25 15 65.14 5338 13 2 14.8 62.75 11.25 15 64.91 5415 14 2 14.655 62.75 11.25 15 65.85 5482 14 2 14.655 62.75 11.25 15 66.66 5506 14 3 14.655 62.75 11.25 15 68.13 5560 15 3 14.51 62.75 11.25 15 68.79 5622 15 3 14.51 62.35 11.25 15 69.56 5665 15 2 14.51 61.96 11.25 15 70.09 5769 16 3 14.51 61.57 11.25 15 71.38 5756 16 3 14.51 61.18 11.25 15 71.22 5823 15 2 14.365 61.18 11.25 15 72.05 5864 16 2 14.365 60.39 11.25 15 72.55 5896 15 2 14.365 60 11.25 15 72.95 5995 16 2 14.22 60 11.25 15 74.18 5986 16 2 14.22 59.22 11.25 15 74.06 6019 16 2 14.075 58.82 11.25 15 74.48 6078 16 2 14.075 58.43 11.25 15 73.9 6173 16 2 13.929 58.43 11.25 15 75.06 6158 17 2 13.784 58.04 11.25 15 74.88 6198 17 2 13.784 57.65 11.25 15 74.05 6308 19 3 13.639 57.25 11.25 15 75.36 6345 19 3 13.639 56.86 11.25 15 74.45 6388 19 3 13.639 56.47 11.25 15 74.96 6350 19 3 13.494 56.47 11.25 15 74.51 6449 20 3 13.639 56.08 11.25 15 75.67 6488 20 3 13.639 55.69 11.25 15 74.74 6527 20 3 13.494 55.29 11.25 15 75.19 6556 21 3 13.349 54.51 11.25 15 74.12 6585 21 3 13.349 54.12 11.25 15 74.45 6661 21 3 13.349 54.12 11.25 15 75.31 6702 21 3 13.349 53.73 11.25 15 75.78 6745 22 3 13.204 53.73 11.25 15 74.82 6781 22 3 13.204 52.94 11.25 15 75.22 6781 23 3 13.059 52.94 11.25 15 75.22 6781 23 3 13.204 52.55 11.25 15 73.78 6862 23 3 13.204 52.55 11.25 15 74.65 6843 23 3 13.059 52.55 11.25 15 72.99 6931 23 3 13.059 52.55 11.25 15 73.93 6874 41 0 -0.145 0 11.25 15 32.26 6931 12 0 -8.706 0 12.86 15 0 6579 12 0 -9.431 0 25.5 15 0 6083 12 0 -9.867 0 24.81 15 0 5850 12 0 -10.012 0 24 15 0 |
05-19-2006, 12:56 AM | #2 |
Member#: 82378
South East
Vehicle:<--- Hot Donuts Now |
im kinda a n00b at this too, but it looks like youre starting to knock around 5k....
05-19-2006, 08:33 AM | #3 |
Member#: 56321
NESIC
Vehicle:2006 Honda El Camino Green |
What do your boost targets and wastegate duty cycle targets look like the 100% columns? Your wastegate duty cycles are increasing towards redline as your boost is falling off. There could be a couple of reasons for this. I'm curious to see what your map looks like first.
Also, your car appears to be pulling timing in a few places (at 4200 rpm and then at 5000 as wrxblubayou said). It would be good to smooth out your timing curve a bit so that it's non-decreasing once you hit peak load. Are you running on 91 octane gas? Thanks, Mike |
05-19-2006, 06:25 PM | #4 | |
Member#: 66510
NWIC
05-21-2006, 04:19 PM | #5 |
Member#: 66510
NWIC
anyone else have some info??
05-22-2006, 01:19 AM | #6 |
Member#: 103320
Vehicle:1998 swapped Forester L |
here's a side by side comparison with mine. Pull done in 4th gear, 91 oct. map. Same exact mods except Perrin downpipe and stock WRX transmission:
Code:
Engine Speed (RPM) Knock Correction (°BTDC) Fuel Injector #1 Duty (%) Primary Wastegate Duty Cycle (%) Air/Fuel Sensor #1 (AFR) Advance Multiplier (020124) () Manifold Relative Pressure (Corrected) (BAR) Ignition Timing (°BTDC) Manifold Relative Pressure (Corrected) (PSI) 3139 9 23.44 50.2 11.6 16 0.47 20 6.91 3156 9 24.91 57.65 11.6 16 0.57 20 8.38 3170 10 26.37 62.75 11.37 16 0.63 20 9.26 3193 10 28.61 67.45 11.37 16 0.7 19 10.29 3215 9 30.17 67.45 11.25 16 0.81 18 11.91 3264 9 34.11 67.45 11.25 16 0.87 16 12.79 3297 9 35.87 67.45 11.25 16 0.94 15 13.82 3299 8 36.6 67.45 11.25 16 0.99 14 14.55 3326 8 37.6 67.45 11.25 16 1.04 13 15.29 3371 8 38.83 67.45 11.25 16 1.06 13 15.58 3409 8 39.27 67.45 11.25 16 1.07 12 15.73 3417 7 40.09 67.45 11.25 16 1.08 12 15.88 3459 7 40.59 67.45 11.25 16 1.08 12 15.88 3493 7 41.73 67.45 11.25 16 1.09 12 16.02 3544 7 42.34 67.45 11.25 16 1.1 12 16.17 3568 7 43.38 67.45 11.25 16 1.11 11 16.32 3573 7 43.45 67.45 11.25 16 1.11 11 16.32 3595 7 44.49 67.45 11.25 16 1.12 12 16.46 3639 7 45.02 67.45 11.25 16 1.13 12 16.61 3662 7 46.09 67.45 11.25 16 1.13 12 16.61 3696 7 46.52 67.45 11.25 16 1.14 12 16.76 3713 7 46.73 67.45 11.25 16 1.15 12 16.91 3769 7 48.24 67.45 11.25 16 1.15 12 16.91 3799 7 48.63 67.45 11.25 16 1.16 13 17.05 3821 7 48.09 67.45 11.25 16 1.16 13 17.05 3872 7 48.73 67.45 11.25 16 1.15 13 16.91 3890 7 48.96 67.45 11.25 16 1.15 13 16.91 3947 7 48.84 67.45 11.25 16 1.15 14 16.91 3972 7 50 67.45 11.25 16 1.15 14 16.91 3951 5 49.73 67.45 11.25 16 1.16 12 17.05 3977 5 50.9 67.45 11.25 16 1.16 12 17.05 4045 5 52.64 67.45 11.25 16 1.17 12 17.2 4058 5 52.81 67.45 11.25 16 1.17 12 17.2 4076 5 53.04 67.45 11.25 16 1.17 12 17.2 4096 5 53.3 67.45 11.25 16 1.17 12 17.2 4216 5 55.76 67.45 11.25 16 1.17 12 17.2 4235 5 56.01 67.45 11.25 16 1.17 12 17.2 4216 5 55.76 67.45 11.25 16 1.16 12 17.05 4269 5 56.46 67.45 11.25 16 1.17 12 17.2 4296 5 56.82 67.45 11.25 16 1.17 12 17.2 4325 5 58.13 67.45 11.25 16 1.17 12 17.2 4325 5 58.13 67.45 11.25 16 1.17 12 17.2 4376 6 59.74 67.45 11.25 16 1.18 13 17.35 4414 7 60.27 67.45 11.25 16 1.17 14 17.2 4412 7 61.17 67.45 11.25 16 1.17 14 17.2 4467 7 60.99 67.45 11.25 16 1.18 14 17.35 4496 7 62.35 67.45 11.25 16 1.18 14 17.35 4507 7 62.5 67.45 11.25 16 1.18 14 17.35 4559 7 62.25 67.45 11.25 16 1.19 14 17.49 4568 8 63.34 67.45 11.25 16 1.19 14 17.49 4624 7 64.12 67.45 11.25 16 1.19 15 17.49 4638 8 63.32 67.45 11.25 16 1.2 15 17.64 4653 8 63.52 67.45 11.25 16 1.2 15 17.64 4720 8 64.44 67.45 11.25 16 1.2 15 17.64 4729 8 64.56 67.45 11.25 16 1.2 15 17.64 4756 8 64.93 67.45 11.25 16 1.21 16 17.8 4774 8 65.18 67.45 11.25 16 1.2 16 17.64 4814 9 65.72 67.45 11.25 16 1.2 17 17.64 4845 7 66.15 67.45 11.25 16 1.21 15 17.8 4861 7 66.36 67.06 11.25 16 1.2 16 17.64 4876 7 67.62 67.06 11.25 16 1.2 15 17.64 4944 7 67.5 66.67 11.25 16 1.21 15 17.8 4960 7 67.72 66.67 11.25 16 1.2 15 17.64 4980 7 67.99 66.67 11.25 16 1.2 16 17.64 4967 6 67.81 66.27 11.25 16 1.2 16 17.64 4996 6 68.22 65.88 11.25 16 1.19 16 17.49 5067 6 69.18 65.88 11.25 16 1.19 16 17.49 5092 6 69.52 65.49 11.25 16 1.18 16 17.35 5088 6 69.47 65.49 11.25 16 1.18 16 17.35 5126 6 69.99 65.1 11.25 16 1.18 17 17.35 5162 6 70.47 65.1 11.25 16 1.17 17 17.2 5187 6 70.81 64.71 11.25 16 1.17 17 17.2 5201 6 71.01 64.71 11.25 16 1.16 17 17.05 5274 6 72.01 64.71 11.25 16 1.16 17 17.05 5308 7 72.47 64.71 11.25 16 1.17 18 17.2 5319 7 72.62 64.71 11.25 16 1.16 18 17.05 5319 7 72.62 64.71 11.25 16 1.17 18 17.2 5369 5 74.44 64.71 11.25 16 1.16 16 17.05 5403 5 74.93 64.71 11.25 16 1.17 16 17.2 5399 5 74.87 64.71 11.25 16 1.17 17 17.2 5450 5 75.58 64.71 11.25 16 1.17 17 17.2 5446 6 75.52 64.71 11.25 16 1.17 17 17.2 5490 6 77.3 64.71 11.25 16 1.17 17 17.2 5523 6 77.76 64.71 11.25 16 1.18 17 17.35 5568 6 78.39 64.71 11.25 16 1.17 17 17.2 5535 6 77.93 64.71 11.25 16 1.17 17 17.2 5568 6 78.39 64.71 11.25 16 1.17 17 17.2 5614 6 79.04 64.31 11.25 16 1.17 18 17.2 5626 6 79.22 64.31 11.25 16 1.17 18 17.2 5669 6 79.82 63.92 11.25 16 1.17 17 17.2 5725 6 80.61 63.53 11.25 16 1.16 17 17.05 5708 6 80.36 63.14 11.25 16 1.17 18 17.2 5708 6 80.36 63.14 11.25 16 1.16 18 17.05 5756 6 81.04 62.75 11.25 16 1.15 18 16.91 5760 6 79.88 62.35 11.25 16 1.15 17 16.91 5837 5 82.18 62.35 11.25 16 1.14 18 16.76 5864 6 82.56 62.35 11.25 16 1.15 18 16.91 5827 6 80.8 61.57 11.25 16 1.15 19 16.91 5896 6 81.76 61.57 11.25 16 1.14 19 16.76 5910 6 81.95 61.18 11.25 16 1.14 19 16.76 5896 6 83.02 61.18 11.25 16 1.13 19 16.61 5929 6 82.21 60.39 11.25 16 1.14 19 16.76 5976 6 82.86 60.39 11.25 16 1.13 19 16.61 5943 6 82.41 60.39 11.25 16 1.12 19 16.46 5976 6 82.86 59.61 11.25 16 1.12 19 16.46 6029 6 83.6 59.61 11.25 16 1.12 19 16.46 6058 6 84 58.82 11.25 16 1.11 19 16.32 6029 6 83.6 58.43 11.25 16 1.12 19 16.46 6043 6 83.8 57.65 11.25 16 1.11 19 16.32 6102 6 84.62 57.65 11.25 16 1.11 20 16.32 6112 6 83.45 57.65 11.25 16 1.11 20 16.32 6158 6 84.07 57.25 11.25 16 1.1 20 16.17 6122 6 83.59 57.25 11.25 16 1.09 20 16.02 6117 6 83.52 56.86 11.25 16 1.1 20 16.17 6193 6 84.56 56.08 11.25 16 1.1 23 16.17 6173 6 84.28 55.69 11.25 16 1.09 20 16.02 6224 6 84.98 55.29 11.25 16 1.09 23 16.02 |
Similar Threads | ||||
Xbox360 Gurus! Need your help/input! | ITSME4G63 | Off-Topic | 5 | 11-24-2006 01:54 AM |
OT IT gurus - need your help | Leadfoot77 | Off-Topic | 14 | 11-11-2005 06:17 PM |
Insurance agents/gurus, need your help. | aod | Off-Topic | 16 | 07-20-2005 12:58 PM |
SQL gurus, need your help! | Alpine | Off-Topic | 44 | 02-16-2005 10:29 PM |
IT and or SCSI gurus need your help | ChosenWon | Off-Topic | 7 | 11-07-2003 12:36 PM |
