02-16-2005, 05:15 PM | #1 |
Member#: 10960
NWIC
Vehicle:2002 Impreza WRX Silver |
SQL gurus, need your help!
This has me stumped for almost a day now... I have a table with the following columns in MySQL 4.13 (some names slightly changed, others omitted).
+------------+-------------+------+-----+---------------------+-------+ | Field | Type | Null | Key | Default | Extra | +------------+-------------+------+-----+---------------------+-------+ | name | varchar(25) | | PRI | | | | actionDate | datetime | | PRI | 0000-00-00 00:00:00 | | | x | float(8,2) | | | 0.00 | | | y | float(8,2) | | | 0.00 | | | z | float(8,2) | | | 0.00 | | +------------+-------------+------+-----+---------------------+-------+ Users will be entering new values for x,y, and z on different dates for the same "name," so we end up with rows like this: +----------+---------------------+-------+------+------+ | name | actionDate | x | y | z | +----------+---------------------+-------+------+------+ | bear | 2005-02-05 11:59:43 | 10.00 | 9.00 | 8.00 | | axe | 2005-02-04 14:38:17 | 0.00 | 0.00 | 0.00 | | axe | 2005-02-04 14:54:23 | 0.00 | 0.00 | 0.00 | | axe | 2005-02-04 14:54:33 | 0.70 | 0.00 | 0.00 | | axe | 2005-02-04 15:28:54 | 0.00 | 0.00 | 0.00 | | axe | 2005-02-04 15:29:09 | 0.00 | 0.00 | 0.00 | | axe | 2005-02-04 15:43:49 | 0.00 | 0.00 | 0.00 | | axe | 2005-02-04 15:44:34 | 0.00 | 0.00 | 0.00 | | axe | 2005-02-04 16:02:45 | 0.00 | 0.00 | 0.80 | | worm | 2005-02-04 16:03:23 | 0.00 | 0.00 | 0.00 | | worm| 2005-02-04 16:03:28 | 0.00 | 0.00 | 0.00 | | axe | 2005-02-04 16:05:05 | 0.00 | 0.00 | 0.80 | | axe | 2005-02-04 16:08:50 | 0.00 | 0.00 | 0.80 | | axe | 2005-02-04 16:09:12 | 0.00 | 0.00 | 0.80 | | axe | 2005-02-09 12:05:39 | 0.00 | 0.00 | 0.81 | +----------+---------------------+-------+------+------+ I want to get the most recent values of x, y, and z for each name, ie +----------+---------------------+-------+------+------+ | name | actionDate | x | y | z | +----------+---------------------+-------+------+------+ | bear | 2005-02-05 11:59:43 | 10.00 | 9.00 | 8.00 | | worm| 2005-02-04 16:03:28 | 0.00 | 0.00 | 0.00 | | axe | 2005-02-09 12:05:39 | 0.00 | 0.00 | 0.81 | +----------+---------------------+-------+------+------+ I've tried so many combinations of havings and group bys and wheres it's not even funny. The one I thought would work: mysql> select name, actionDate, x, y, z from tbl group by name HAVING actionDate=MAX(actionDate); +----------+---------------------+-------+------+------+ | name | actionDate | x | y | z | +----------+---------------------+-------+------+------+ | bear | 2005-02-05 11:59:43 | 10.00 | 9.00 | 8.00 | +----------+---------------------+-------+------+------+ And I can't use nested queries or views because this is MySQL 4.13 and it sucks. Anyone have any ideas, queries, hints, tips other than "use a better db," etc?
02-16-2005, 05:17 PM | #2 |
Member#: 12391
NESIC
Vehicle:I did her 5 times then 7 times, then 5 more |
Can you do an inner join on a query?
02-16-2005, 05:21 PM | #3 |
Member#: 10960
NWIC
yes, MySQL 4.13 supports it
02-16-2005, 05:21 PM | #4 |
Member#: 15103
VIC
Vehicle:2000 2.5RS BRP |
Try this?
select distinct name, actionDate, x, y, z from tbl group by name HAVING actionDate=MAX(actionDate); |
02-16-2005, 05:26 PM | #5 |
Member#: 10960
NWIC
Thanks - I'm not 100% sure why this returns the same results as without the "distinct."
mysql> select distinct name, actionDate, x, y, z from tbl group by name having actionDate=MAX(actionDate); +----------+---------------------+-------+------+------+ | name | actionDate | x | y | z | +----------+---------------------+-------+------+------+ | bear | 2005-02-05 11:59:43 | 10.00 | 9.00 | 8.00 | +----------+---------------------+-------+------+------+ |
02-16-2005, 05:27 PM | #6 |
Member#: 22958
SWIC
Vehicle:2017 Forester 2.5 Li Silver |
I know you don't want to hear this, but you should really have only one observation field in the table, along with an ObservationType field that is valued x, y or z.
Then, since you're using MySQL, you would have to create a query containing three subqueries, each subquery criteria'd on Max(actionDate) and joined by Name. |
02-16-2005, 05:29 PM | #7 | |
Member#: 22958
SWIC
02-16-2005, 05:37 PM | #8 |
Member#: 7121
Just make another table with name and most recent actiondate.
02-16-2005, 05:41 PM | #9 |
Member#: 31976
Vehicle:2004 WRX STi World Rally Blue |
really you should have a table with a numeric (dunno the data types in mysql) id column as a primary key and the name. and then you should have another table with the id (indexed of course) and the actiondate, and x, y, z, so then you can join on the id, and not on a string which is totally slow. and also you are really wasting space by storing those names over and over again.
02-16-2005, 05:52 PM | #10 | |
Member#: 22958
SWIC
And you should never store what you can calculate. |
02-16-2005, 05:59 PM | #11 | |
Member#: 7121
02-16-2005, 06:03 PM | #12 |
Member#: 22958
SWIC
Then you are storing the same date in two different tables. And if an event occurs that updates the transaction record without updating the redundent table, you have no data integrity.
02-16-2005, 06:20 PM | #13 |
Member#: 37288
RMIC
Vehicle:2005 G35 |
I've spent a good deal of time a while back to do something like this. I couldn't find any way of doing this elegantly without using views or nested queries. I think the only way around this now is for you to make a temporary table each time you run that query to simulate a view, and then deleting that table afterwards. Does that version of MySQL support "Insert Into temptable Select ....."?
02-16-2005, 06:46 PM | #14 | |||||
Member#: 10960
NWIC
02-16-2005, 06:48 PM | #15 |
Member#: 34852
Vehicle:04 WRX STI White / Gold |
Can you do more than one query?
-Ollie |
02-16-2005, 06:52 PM | #16 |
Member#: 22958
SWIC
mysql> select name, actionDate, x, y, z from tbl group by name HAVING actionDate=MAX(actionDate) GROUP BY Name;
Did you try that? |
02-16-2005, 06:53 PM | #17 | |
Member#: 15384
NWIC
you need to pm me your address... got something to send you. |
02-16-2005, 06:55 PM | #18 |
Member#: 22958
SWIC
snail-mail?
You gonna parcel-post me your woman? |
02-16-2005, 06:56 PM | #19 | |
Member#: 7977
Vehicle:100% Abuse |
02-16-2005, 06:56 PM | #20 | |
Member#: 15384
NWIC
02-16-2005, 06:57 PM | #21 | |
Member#: 7977
02-16-2005, 06:59 PM | #22 |
Member#: 22958
SWIC
Yeah, I'm taking wild stabs now. I'm spoiled by Query Design Grid.
02-16-2005, 06:59 PM | #23 | |
Member#: 22958
SWIC
02-16-2005, 07:09 PM | #24 |
Member#: 6997
South East
does mySql support local variables?
declare @var datetime select @var = max(actiondate) from tbl select * from tbl where actiondate=@var |
02-16-2005, 07:11 PM | #25 | |
Member#: 10960
NWIC
Xbox360 Gurus! Need your help/input! | ITSME4G63 | Off-Topic | 5 | 11-24-2006 01:54 AM |
Data logging gurus, need your help reading log. | vortectoy | AccessPort | 5 | 05-22-2006 01:19 AM |
OT IT gurus - need your help | Leadfoot77 | Off-Topic | 14 | 11-11-2005 06:17 PM |
Insurance agents/gurus, need your help. | aod | Off-Topic | 16 | 07-20-2005 12:58 PM |
IT and or SCSI gurus need your help | ChosenWon | Off-Topic | 7 | 11-07-2003 12:36 PM |
