08-23-2010, 04:45 PM | #1201 | |
Member#: 36033
SCIC
Vehicle:CEO PhatBottiTuning 2006 STi GTX3582 + Meth |
e85 is like 105-109 octane....so its like running race gas all the time. Therefore you can run more boost, more timing and a leaner AFR, which all equate to more power. So if by "more driveable" you mean "make more power" then the answer is yes. I think what you may be experiencing are some of the intake air temperature (IAT) compensations....when its hot out and your IATs get over 104* the ecu starts taking out 4-6* of timing.....so hot intake air in conjunction with 4-6* less timing will make your car feel like a turd when its hot outside.
08-23-2010, 04:55 PM | #1202 | |
Member#: 147637
International
Vehicle:HJ's Ask Hobbs. He knows. |
08-23-2010, 04:58 PM | #1203 |
Member#: 36033
SCIC
^ Then the ecu will pull 8*. Your IAT's easily get over 150* while sitting at a stoplight with a CAI.....with a hot ram they go even higher.....but the most timing that table pulls in an unmodified IAT comp table is 8*, IIRC.
08-23-2010, 05:00 PM | #1204 |
Member#: 165141
08-23-2010, 05:51 PM | #1205 |
Member#: 135252
Vehicle:2002 WRX Wagon |
08-23-2010, 06:15 PM | #1206 |
Member#: 36033
SCIC
^^ You dont like being in a perpetual state of swamp azz?
People always give people from the desert (AZ, NM, CA high desert) crap for saying "but its a dry heat" out here.....well once you've been in both environments you realize its true. I will take 115* and 2% humidity over 90* & 90% any day of the week. |
08-23-2010, 08:06 PM | #1207 |
Member#: 165141
^That could be true, but i've gotta imagine that there are a lot of people down there that smell like complete crap all of the time from all the sweating. At least up here we dont have to rely on AC 90% of the time
08-23-2010, 08:11 PM | #1208 |
Member#: 165141
Here's some pics of the air/oil seperator, the top metal part seems to be the place that most of the oil condenses since that the part that get clogged after a couple weeks. I just cleaned it out after a month of neglect and it was NASTY! The water smells like alcohol, i've tried to light it on fire But its not flammable
As you can see on the last picture, there's almost no oil in the bottom, just a lot of water. If there's any questions on routing LMK, its pretty simple though |
08-23-2010, 08:18 PM | #1209 |
Member#: 183480
South East
i bet you get some baffling in there and you will catch some oil. also, i had a catch can setup similar to that one originally, and i traded it out for a vta setup because i was actually pressurizing the crankcase due to the hoses just not being able to evacuate the pressure fast enough.
08-23-2010, 08:28 PM | #1210 |
Member#: 165141
Yeah, I'm debating on whether to try to make some kind of vent coming off of a valve cover or to make a vacuum pump out of a smog pump
08-23-2010, 09:00 PM | #1211 |
Member#: 135252
Wisconsin isn't the SE We have crazy seasons here. Summer lasts forever, fall/spring only last 2 weeks each, and winter is the rest, but we only get snow once a year if that.
08-29-2010, 05:42 AM | #1212 |
Member#: 227300
NWIC
Vehicle:2006 WRX STi PTE 6262 E85 |
could i run 25 psi on my blouch dom 3? straight e85? built block
08-29-2010, 08:13 AM | #1213 |
Member#: 139385
sure if you have the fuel system to handle it
08-29-2010, 11:27 AM | #1214 |
Member#: 240076
RMIC
I have been on E85 for a year or so now.
fuel-E70 car- 03 wrx mods- vf39, tbe, cobb intake/intake box,walbro elevation- 5000ish injectors- dark blue 565 boost- 16.3 @ peak afr's-11.4-11.9 road dyno- 243hp@ 6200, 241ft-lbs@ 4600 Timing- 15*@ pk trq, 27*@ redline idc- max of 92.5% |
08-29-2010, 11:31 AM | #1215 |
Member#: 183480
South East
get some bigger injectors and turn that thing up
08-29-2010, 11:37 AM | #1216 |
Member#: 240076
RMIC
thats the plan
08-29-2010, 03:43 PM | #1217 |
Member#: 227300
NWIC
08-29-2010, 10:17 PM | #1218 |
Member#: 165141
How many degrees of timing are you guys running while cruising at low loads, such as on the highway?
08-30-2010, 12:39 AM | #1219 |
Member#: 240076
RMIC
08-30-2010, 08:08 AM | #1220 |
Member#: 165141
What kind of fuel economy are you getting just cruising on the highway? I average between 18-20 mpg with around 36* of timing
08-30-2010, 10:42 AM | #1221 |
Member#: 183480
South East
i'm averaging about 21mpg highway with 36*...i plan on playing with the timing a little bit to see if i can get anything better out of it, but i am pretty happy overall with what i have so far.
08-30-2010, 11:30 AM | #1222 |
Member#: 36033
SCIC
Try using the OL/CL time delay to increase gas mileage. Most people make them zero, but if you leave values in there between 1-5 you will stay in CL for small throttle changes.
08-30-2010, 12:59 PM | #1223 |
Member#: 165141
Yeah, i've got mine zero'd for safe enrichment, I might add a little bit to the delays in the future, but at this point i'd like to see how the relation of timing equates the the fuel economy that people are experiences.
08-31-2010, 01:13 PM | #1224 |
Member#: 103473
South East
Vehicle:99 RSTi |
I'm seriously thinking about switching to e85. My motor is being built now and I'm already running DW 850's and walbro 255. I'm going to be shooting for low to mid 500's with the built motor and a stock location 30 or 35r.
What else would I need to get to run e85 at those power levels. More injector? Bigger pump? Fuel rails? Thanks in advance to the army. |
08-31-2010, 01:34 PM | #1225 |
Member#: 165141
For mid 500 WHP you'd need about 1200cc injectors or larger (Injector dynamics 2000cc's would work nicely and leave room for future upgrades) You'd also need some sort of fuel supply system to keep up with the injector demands.
Is E85 readily available in FL? |
Motion Lab Tuned: Juanmedina's 2007 WRX E85 ARMY | Motion Lab Tuning | Proven Power Bragging | 125 | 04-12-2010 02:57 AM |
jid2 Track Car - e85 ARMY | jid2 | Member's Car Gallery | 38 | 01-22-2010 10:44 PM |
The Honduran army is the bravest in the world... | wrxcelent | Off-Topic | 36 | 07-07-2009 08:21 AM |
Spacific E85 Tuning thread Here ? | discopotato03 | Engine Management & Tuning | 1 | 09-09-2008 11:01 AM |
Did anyone hear the one about the Italian army and the IRAQI satiation? | Asinine | Off-Topic | 3 | 09-20-2005 07:06 PM |
