Welcome to the North American Subaru Impreza Owners Club Saturday November 17, 2018
Old 08-26-2005, 11:08 PM   #1
mpower22
Member#: 58352
04 20G STI(SOLD)
08 z51C6 (growing mullet)
Default Yeah almost blew up my car again ( oil leak on 20g at sbr feed line)
okay had a leak on my feed line where it meets the turbo.....the line came with two washers but they were not the crush type....I replaced the washers with one crush...(mistake)..and proceded to blow a tone of oil all over the place.....
I assume you need two washers, one on each side....should they be crush or regular?
I havr the sbr feed line...
anyone have a good pic of how they go on and remail oil leak free?
Help...(now cleaning up the mess)
mpower22 is offline   Reply With Quote
Old 08-26-2005, 11:38 PM   #2
PeteDucati
Member#: 44629
CNC 'd heads, cams
DB18g/EWG - F/S $8K
I've only seen one washer on each side.
PeteDucati is offline   Reply With Quote
Old 08-26-2005, 11:59 PM   #3
dwx
Member#: 8343
2005 2012 Jeep
2013 DGM BRZ
If it's a banjo bolt use one washer on each side, copper.
Old 08-27-2005, 11:19 AM   #4
mpower22
Member#: 58352
04 20G STI(SOLD)
thats what I thought...they sent stainless steel ones...
Old 08-27-2005, 12:49 PM   #5
dwx
Member#: 8343
2005 2012 Jeep
2013 DGM BRZ
Well if you use one one each side it will probably still be okay, but copper is going to seal things better.
Old 08-27-2005, 03:58 PM   #6
vtecTHIS
Member#: 48048
. Nasioc, serious
Bidnazz
you want the same metal to prevent corrsion,copper doesn't seal better than a reg washer... steel on copper won't last very long.same thing on trannies...
vtecTHIS is offline   Reply With Quote
Old 08-27-2005, 09:36 PM   #7
mpower22
Member#: 58352
04 20G STI(SOLD)
but using the regular washers caused a leak.....should I use crush washers?
Matt
Old 08-27-2005, 09:48 PM   #8
GeorgeRex
Member#: 51695
2004 STi
this is bad advice you are giving. Copper is the material used by the manufacturer, probably for its softness and therefore good sealing properties.
GeorgeRex is offline   Reply With Quote
Old 08-27-2005, 09:48 PM   #9
GeorgeRex
Member#: 51695
2004 STi
Matt
YES !
Old 08-28-2005, 10:27 AM   #10
Stiguy247
Member#: 69301
2xx5 STi-R..
Crystal Grayish Metallic
I have never seeen copper washers rust out. On rusted cailpers the only thing not rusted is the copper washers
Stiguy247 is offline   Reply With Quote
Old 08-28-2005, 12:03 PM   #11
RiftsWRX
Member#: 6124
2000 NFR AP1 S2000
'07 Honda FIT sport (5MT)
Call Slowboy and ask....
Jorge (RiftsWRX)
www.ProjectWRX.com
RiftsWRX is offline   Reply With Quote
Old 08-28-2005, 08:33 PM   #12
fmowry
Member#: 54604
2004 FXT
Cayenne Red (sold)
I replaced the washers on Matt's car with crush washers I had laying around. One of them must have been too narrow if it blew oil out. Unfortunately we were outside and it was late, light sucked. I should have had Matt start the car.
Matt,
They blew oil out? I replaced the ones from slowboy with a crush on each side of the fitting. You should have come back by. That's what we get for doing it so late at night.
You should have called me up. I didn't want to screw you up. The only way that would have happened is if one of the crush washers didn't cover the hole. We should have started the car and check for leaks.
Frank
fmowry is offline   Reply With Quote
Old 08-28-2005, 08:53 PM   #13
mpower22
Member#: 58352
04 20G STI(SOLD)
Matt,
Frank
Not your fault man I'm not pissed....actually didn't start smoking until I was halfway home.....I was just about home and I made it okay.....just a pain in the azz....do you remember if we used one or two washers? either way no biggie....cleaned up most of the mess today...just need to have a final fix....I still think this is the issue....
Matt
Old 08-29-2005, 02:17 PM   #14
SlowboyNRS
Member#: 78865
05 WRX STi, 90 GSX
10.05 @ 145.5
On all the 20g's, and every 14b/16g on a DSM for that matter, we only use factory copper crush washers, which is what you should have gotten with the oil supply line. Make sure their tight and they won't leak.
Nate
SBR
SlowboyNRS is offline   Reply With Quote
Old 08-29-2005, 06:14 PM   #15
fmowry
Member#: 54604
2004 FXT
Cayenne Red (sold)
Nate
SBR
Nate,
They were definately not crush washers. They were light, cloudy silver in color.
Frank
Old 08-29-2005, 07:32 PM   #16
[email protected]
Member#: 67
1999 Outlasting
the competition.
also never resse the crush washers. install a new set each time. its well worth the extra 50cents.
for the clean up try a diluted simple green solution
tom
Old 08-29-2005, 10:30 PM   #17
Tuning Factory Inc.
Vendor
Member#: 3600
I use a straight fitting on my oil feed lines to avoid such headaches. I know that not only is installing those Banjo fittings a pain but I like to use new washers each time to assure a good seal and that gets pricey over time. I use copper washers and have never had any problems sealing up the banjo fitting on top of the turbo.
Tuning Factory Inc. is offline   Reply With Quote
Old 08-30-2005, 03:31 PM   #18
SlowboyNRS
Member#: 78865
05 WRX STi, 90 GSX
10.05 @ 145.5
Nate,
Frank
If you didnt get the copper ones, give me a call, and we'll get you the right ones!
Nate
SBR
Old 08-30-2005, 03:50 PM   #19
mpower22
Member#: 58352
04 20G STI(SOLD)
no biggie I went to autozone and got them...just been a pain to track down this oil leak for the last two weeks and the problem was a 50 cent pair of washers....
+1 for no more spy hunter like smokescreens out of the back of the car!
Old 08-30-2005, 03:55 PM   #20
WrxWonderWagon
Member#: 67265
04 35r Sti meth
What Spelluring?
slow boy bah
WrxWonderWagon is offline   Reply With Quote
Old 08-30-2005, 03:58 PM   #21
mpower22
Member#: 58352
04 20G STI(SOLD)
Originally Posted by WrxWonderWagon
slow boy bah
I'm not hating...overall I have been very happy with them....its kinda my own fault as the spider sense when off when using the silver washers.....should have called them the next day...
Matt
OMG, I almost freaking blew up my car, I need some help PLEASE!!!!! sticrazy Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 19 07-08-2006 07:20 PM
i blew up my car bobert517 Mid Atlantic Impreza Club -- MAIC 53 01-15-2006 09:18 PM
So I blew up my car, remember??? WRXGuyInUSA Off-Topic 2 02-15-2004 08:22 AM
WOOT!!!! I just blew up my car!!! RiftsWRX Mid West Subaru Owners Club Forum -- MWSOC 31 01-02-2002 04:50 PM
My car is at the dealer again - Oil leaking, wheels bearings BoomerRS New England Impreza Club Forum -- NESIC 14 06-07-2001 10:50 AM
